我使用的STM8S103K3, 批号是MYS932, 现在发现PB口都不能输出高电平 以下是我的程序
#include"iostm8s103k3.h" #include"compatible.H" #define _BV(A) (1<<(A)) //LED1 PD3 //LED2 PD2 //LED3 PD0 #define LED_SA PD_ODR_ODR5 #define LED_SB PD_ODR_ODR6 #define LED_SRCK PD_ODR_ODR2 #define LED_RCK PD_ODR_ODR3 #define LED_SER PD_ODR_ODR4 // a BIT5 // b BIT0 // c BIT1 // D BIT3 // E BIT2 // f BIT4 // G BIT7 //DP BIT6 char LED_DATA[10]= { 0xff-BIT6-BIT7,//0 BIT0+BIT1,//1 0xff-BIT1-BIT4-BIT6,//2 0xff-BIT2-BIT4-BIT6,//3 BIT4+BIT7+BIT0+BIT1,//4 0xff-BIT0-BIT2-BIT6,//5 0xff-BIT0-BIT6,//6 BIT5+BIT0+BIT1,//7 0xff-BIT6,//8 0xff-BIT2-BIT6,//9 }; void delay(long m) { volatile unsigned long i; for(i=0;i } //把数据送入HC595 void HC_595_input(unsigned char data) { unsigned char i; for(i=0;i<8;i++) { LED_SRCK=0;//移位寄存器时钟拉低时钟 if(data&0x80) //最高位判断 { LED_SER=1; //最高位为1,则写1到DS口 } else { LED_SER=0; //最高位为0,则写0到DS口 } LED_SRCK=1;//移位寄存器时钟拉高时钟 //delay_1us(); delay(1); data<<=1; } } //数据从595的并行口输出 void HC_595_output(unsigned char data) { LED_RCK=0;//存储寄存器时钟拉低时钟 HC_595_input(data); LED_RCK=1;//存储寄存器时钟拉高时钟 } /* -------------------------------------------------------------------------- */ /* ROUTINE NAME: TIM_Init */ /* INPUT/OUTPUT: None. */ /* DESCRIPTION: Initialize the TIM4 as LED timebase. */ /* -------------------------------------------------------------------------- */ void TIM2_Init(void) { __asm("sim"); //sim是禁止中断 TIM2_PSCR =0x07; //设置时钟分频 TIM2_ARRH = 0x00; //初值 TIM2_ARRL = 0xf6; //100uS,内部16M TIM2_IER = 0x01; //允许中断 TIM2_CR1 = 0x01; //开启定时器 __asm("rim"); //rim是使能中断 } void GPIO_Init(void) { PB_DDR = 0X00;//_BV(0)|_BV(1)|_BV(4)|_BV(5)|_BV(6); PB_CR1 = 0Xff;//_BV(0)|_BV(1)|_BV(4)|_BV(5)|_BV(6); PB_CR2 = 0x00; PC_DDR = 0XFF;//_BV(0)|_BV(1)|_BV(4)|_BV(2)|_BV(3); PC_CR1 = 0XFF;// _BV(0)|_BV(1)|_BV(4)|_BV(2)|_BV(3); PC_CR2 = 0x00; PD_DDR = 0XFF;// _BV(6)|_BV(5)|_BV(0)|_BV(2)|_BV(3); PD_CR1 = 0XFF;//_BV(6)|_BV(5)|_BV(0)|_BV(2)|_BV(3); PD_CR2 = 0x00; PF_DDR = 0XFF; PF_CR1 = 0XFF; PF_CR2 = 0x00; } void CLK_Init(void) { CLK_CKDIVR &= ~0x10; /* 01: fHSI= fHSI RC output/2. */ // CLK_CKDIVR |= 0x01; /* 001: fCPU=fMASTER/2. */ } long test=0; char test1=100; char test2=123; void main( void ) { char i; CLK_Init(); GPIO_Init(); TIM2_Init(); while(1) { //PD_ODR|=_BV(6)|_BV(5); //PC_ODR=_BV(0)|_BV(1)|_BV(3); PC_ODR=0XFF; delay(4000); test1++; test2++; //PD_ODR=_BV(2); //PC_ODR=_BV(2); PC_ODR=0; delay(4000); //PD_ODR=_BV(0); PC_ODR=_BV(4); delay(4000); //LED_SA=1; //LED_SB=1; //PB_ODR|=_BV(0); PB_ODR=0XFF; PF_ODR=0XFF; delay(4000); PB_ODR=0X00; PF_ODR=0X00; } } /******************************************************************************* * ==中断服务函数 函数== *******************************************************************************/ #pragma vector=TIM2_OVR_UIF_vector __interrupt void TIM2_UPD_OVF_BRK_IRQHandler(void) { char i; //LED1=~LED1; //翻转 管脚电平 TIM2_SR1 = 0x0E; //中断标志位,它不会自动清零 if(test>2) { test=0; } if(test==1) { //PD_ODR|=_BV(6); LED_RCK=0;//存储寄存器时钟拉低时钟 for(i=0;i<10;i++) { HC_595_input(LED_DATA[test1%10]); } LED_RCK=1;//存储寄存器时钟拉高时钟 LED_SA=0; LED_SB=1; } else if(test==0) { LED_RCK=0;//存储寄存器时钟拉低时钟 for(i=0;i<10;i++) { HC_595_input(LED_DATA[test2%10]); } LED_RCK=1;//存储寄存器时钟拉高时钟 LED_SA=1; LED_SB=0; } test++; } |
8个回答
PB_DDR = 0X00;//_BV(0)|_BV(1)|_BV(4)|_BV(5)|_BV(6); 这里的意思是输入,输出应该还是全FF。 |
PB口是真开漏,是不能输出高电平的,要外接上拉电阻
PB口设置成了输入,当然不能输出了。
未开时钟 && 主函数没加初始化
881 浏览 0 评论
国产NSI1300D05-DSWVR放大芯片放大增益8.2或41的问题
895 浏览 0 评论
STM32串口接受中断使用C++STL中的queue导致所有中断失效
8670 浏览 1 评论
3394 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1379 浏览 0 评论
GMT+8, 2025-2-24 19:13 , Processed in 0.889029 second(s), Total 85, Slave 69 queries .
