用汇编写的,12864显示,用中断方式检测开始、暂停、复位24秒按键。开始暂停都没有问题,但是复位按键按下后出现BUG,有时会暂停(本来按下复位不应该暂停),有时还会在12864其他地方出现乱码,求大神解答
LEDRS EQU P2.6 LEDRW EQU P2.5 LEDEN EQU P2.7 LEDPSB EQU P3.2 LEDRST EQU P3.4 ;------------------控制端定义标号 LED_X EQU 30H LED_Y EQU 31H COUNT EQU 32H DP0 EQU 33H DP1 EQU 34H FUNC EQU 35H MINUTE EQU 36H SECOND EQU 37H SECOND_24 EQU 38H _1S EQU 39H DAT EQU 40H DAT_SEC EQU 41H DAT_SEC24 EQU 42H DAT_MIN EQU 43H FORR EQU 44H _STOP EQU 45H _RST24 EQU 46H ;------------------坐标、计数定义 ORG 0000H LJMP MAIN ORG 0003H LJMP INT_INT0 ORG 0030H MAIN: MOV SP,#60H MOV P0,#0FFH MOV IE,#81H ;开总中断,外部中断0,定时器0 MOV TCON,#01H;外部中断才用边沿触发方式 MOV TMOD,#01H;设置定时器0工总方式1 CLR LEDRST ;复位 LCALL DELAY4 SETB LEDRST ;开始 NOP SETB LEDPSB ;并行方式 ;***************初始化************** LCALL INILED ;***************开始显示************** START: MOV R1,#100 MOV MINUTE,#27 MOV SECOND,#121 MOV SECOND_24,#49 MOV TL0,#0F0H MOV TH0,#0D8H CALL CHANGESEC CALL CHANGESEC_24 CALL CHANGEMIN MOV FORR,#0FFH MOV _1S,#00H CHECK_1S: JNB TF0,$ CLR TF0 MOV TL0,#0F0H MOV TH0,#0D8H DJNZ R1,CHECK_1S MOV R1,#100 STARTCHAN:CALL CHANGESEC MOV A,FORR JZ NEXT CALL CHANGEMIN MOV FORR,#00H NEXT: MOV A,SECOND ADD A,#01H JNZ START_24 RST_SEC: MOV SECOND,#121 CALL CHANGESEC CALL CHANGEMIN MOV A,MINUTE ADD A,#01H JNZ START_24 JMP RST_MIN START_24: CALL CHANGESEC_24 MOV A,SECOND_24 ADD A,#01H JNZ CHECK_1S RST_24: MOV SECOND_24,#49 CALL CHANGESEC_24 JMP CHECK_1S RST_MIN: MOV MINUTE,#27 MOV SECOND,#121 MOV SECOND_24,#49 CALL CHANGESEC CALL CHANGESEC_24 CALL CHANGEMIN MOV FORR,#0FFH JMP CHECK_1S CHANGESEC: MOV DAT_SEC,SECOND MOV LED_X,#02H MOV LED_Y,#88H MOV COUNT,#01H MOV DPTR,#TABLE_SEC MOV DP0,DPH MOV DP1,DPL MOV DAT,DAT_SEC CALL LINE MOV A,SECOND CLR C SUBB A,#01H SUBB A,#01H MOV SECOND,A RET CHANGESEC_24: MOV DAT_SEC24,SECOND_24 MOV LED_X,#04H MOV LED_Y,#88H MOV COUNT,#01H MOV DPTR,#TABLE_24 MOV DP0,DPH MOV DP1,DPL MOV DAT,DAT_SEC24 CALL LINE MOV A,SECOND_24 CLR C SUBB A,#01H SUBB A,#01H MOV SECOND_24,A RET CHANGEMIN: MOV DAT_MIN,MINUTE MOV LED_X,#00H MOV LED_Y,#88H MOV COUNT,#01H MOV DPTR,#TABLE_MIN MOV DP0,DPH MOV DP1,DPL MOV DAT,DAT_MIN CALL LINE MOV A,MINUTE CLR C SUBB A,#01H SUBB A,#01H MOV MINUTE,A RET JMP CHECK_1S ;***************各行写入数据************** LINE: MOV A,LED_X ADD A,LED_Y LCALL SENDCODE MOV DP0,DPH MOV DP1,DPL LCALL GETDATA RET ;***************初始化子函数************** INILED: MOV A,#30H LCALL SENDCODE MOV A,#01H LCALL SENDCODE MOV A,#06H LCALL SENDCODE MOV A,#0CH LCALL SENDCODE ;***************清屏子函数************** CLEAR_LED: MOV A,#01H LCALL SENDCODE MOV A,#34H LCALL SENDCODE MOV A,#30H LCALL SENDCODE RET ;***************查表取数据子函数************** GETDATA: MOV A,DAT MOV R3,A NEXTGET: MOV DPH,DP0 MOV DPL,DP1 MOVC A,@A+DPTR LCALL SENDDATA LCALL DELAY4 DEC R3 MOV A,R3 MOVC A,@A+DPTR LCALL SENDDATA LCALL DELAY4 DEC R3 MOV A,R3 DJNZ COUNT,NEXTGET RET ;***************写指令子函数************** SENDCODE: LCALL CHECKBUZY CLR LEDRS CLR LEDRW MOV P0,A SETB LEDEN NOP NOP CLR LEDEN RET ;***************写数据子函数************** SENDDATA:LCALL CHECKBUZY SETB LEDRS CLR LEDRW MOV P0,A SETB LEDEN NOP NOP CLR LEDEN RET ;***************查询忙碌子函数************** CHECKBUZY: MOV P0,#0FFH ;先写1 CLR LEDRS SETB LEDRW SETB LEDEN JB P0.7,$ CLR LEDEN RET ;***************延时子函数************** DELAY4: MOV R6,#100 D41: MOV R7,#200 DJNZ R7,$ DJNZ R6,D41 RET DELAY10MS:MOV R5,#10H D101: MOV R6,#0FFH DJNZ R6,$ DJNZ R5,D101 RET ;*********定时器中断处理函数******************* ;*********外部中断处理函数******************* INT_INT0: PUSH ACC PUSH PSW CHECK_INT0: MOV P1,#0FFH MOV A,P1 ORL A,#0F8H CPL A JZ CHECK_INT0 CALL DELAY10MS MOV P1,#0FFH MOV A,P1 ORL A,#0F8H CPL A JZ CHECK_INT0 MOV FUNC,A CHECK: MOV A,FUNC CJNE A,#02H,CHECK_C T_STOP: CLR TR0 JMP RE_INT CHECK_C: JNC T_RST24 T_BEGIN: SETB TR0 JMP RE_INT T_RST24: MOV SECOND_24,#49 RE_INT: MOV FUNC,#00H POP PSW POP ACC REti ;***************************************** TABLE_MIN: DB '0000102030405060708090011121' TABLE_SEC: DB '00102030405060708090' DB '01112131415161718191' DB '02122232425262728292' DB '03132333435363738393' DB '04142434445464748494' DB '0515253545556575859500' TABLE_24: DB '00102030405060708090' DB '01112131415161718191' DB '0212223242' TABLE: DB '' END |
汇编/
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-初识设备树之设备组织架构
734 浏览 0 评论
582 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-初识设备树之设备树组成和结构
840 浏览 0 评论
【敏矽微ME32G070开发板免费体验】点亮WS2812B灯板
1039 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-Linux内核移植之内核启动流程
937 浏览 0 评论
12163 浏览 31 评论
GMT+8, 2025-1-12 09:37 , Processed in 0.381684 second(s), Total 43, Slave 36 queries .
