Optically isolated gate drivers, that supply low level signal
voltages to drive power switches, provide many technical advantages. These advantages are: high voltage isolation, low capacitive coupling, immunity to magnetic pickup, and the ability to remotely control gate drives without the effects of inductive lead length. The gate driver must also supply the required gate voltage and output current needed to slew a specified dv/dt across a given gate capacitance. The Intersil HIP2030 MCT/IGBT Gate Driver, used with fiber-optic links or photo-couplers, provides an isolated gate drive that is ideal for switching MCT or IGBT devices in power circuits. ![]() |
1935 浏览 0 评论
5684 浏览 0 评论
3275 浏览 2 评论
6285 浏览 2 评论
4144 浏览 0 评论
GMT+8, 2024-12-24 20:38 , Processed in 0.372756 second(s), Total 38, Slave 29 queries .
