大神们, 小弟在这有礼了. 我遇到一个作业,有些不会. 虽然是英文描述的,但是还是希望大神们能伸出援手. 题目如下:
The project consists on building a data acquisition VI that reads and filters data from two accelerometers. The VI will have the following characterisitcs: The control panel will prompt you for the following input: - Number of points of acquire - Scan rate - Which channels to read - Name of the file to store the data points - Calibration constant (conversion factor from volts to m/sec^2) - Filter characteristics: Choose filter type from a pull-down menu Choose order of the filter Choose filter cut-off frequency Other filter parameters if necessary Note: the sensors provide readings in Volts. You need to find the scaling factors that convert volts to m/sec^2. 我们是要求连接板子和仪器的,但是现在programming不是很会, 所以想在这里问下大神们. 小弟愚钝,还希望大神们不要嫌弃. |
4个回答
好贴就要顶一顶 ~~~
可以帮忙代做的,费用合理,有兴趣加512406490
还是学生啊,没有钱. 这里是论坛啊,不是给招商的打广告吧. 不过谢谢你了 |
960 浏览 2 评论
1362 浏览 1 评论
labview2015使用Excel报表程序打包生成后打开程序要选一个vi才能使用,否则软件就会报错,这是什么问题?
1925 浏览 2 评论
LabVIEW与单片机无法串口通信 提示串口打开错误 端口设置有问题吗?
1785 浏览 3 评论
2147 浏览 2 评论
GMT+8, 2024-12-30 02:41 , Processed in 1.009568 second(s), Total 83, Slave 64 queries .
