/*矩阵键盘不起作用,归根到底是矩阵键盘的问题 大神可以看看*/ #include #include #define uchar unsigned char #define uint unsigned int ***it lcdrs=P2^6; ***it lcdwr=P2^5; ***it lcden=P2^7; uchar code table[]="123456789ABCDEF"; /*0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c, 0x39,0x5e,0x79,0x71};*/ uchar table1[]="Key is"; uint key,num,num1; uint num2; void delay(uint z) //延时函数 { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); } void write_com(uchar com) //写指令 { lcdrs=0; lcdwr=0; P0=com; delay(5); lcden=1; delay(5); lcden=0; } void write_data(uchar dat) //写数据 { lcdrs=1; lcdwr=0; P0=dat; delay(5); lcden=1; delay(5); lcden=0; } void init() //初始化 { lcden=0; write_com(0x38); write_com(0x0c); write_com(0x06); write_com(0x01); write_com(0x80); } void keyscan() { uchar temp; temp=0; P1=0xf0; //高四位输入 行为高电平 列为低电平 delay(1); temp=P1; //读P1口 temp=(temp&0xf0); //屏蔽低四位 temp=~((temp>>4)|0xf0); if(temp==1) key=1; else if(temp==2) key=2; else if(temp==4) key=3; else if(temp==8) key=4; else key=16; P1=0x0f; //低四位输入 列为高电平 行为低电平 delay(1); temp=P1; //读P1口 temp=(temp&0x0f); temp=~(temp|0xf0); if(temp==1) key=key+0; else if(temp==2) key=key+4; else if(temp==4) key=key+8; else if(temp==8) key=key+12; else key=16; num2=key; } void keydown() //判断按键是否被按 { P1=0xf0; if(P1!=0xf0) keyscan(); } void main() { delay(10); init(); for(num1=0;num1<6;num1++) { write_data(table1[num1]); delay(5); } write_com(0x80+0x07); keydown(); write_data(table[key]); delay(5); while(1); } |
3个回答
顺便说下,用那么多层else if 干脆用switch case算了
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之电阻屏触摸
769 浏览 0 评论
1276 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之I2C-RTC
552 浏览 0 评论
ATK-DLRK3588开发板deepseek-r1-1.5b/7b部署指南
2890 浏览 0 评论
《DNESP32S3使用指南-IDF版_V1.6》第五十章 WiFi热点实验
876 浏览 0 评论
12394 浏览 31 评论
GMT+8, 2025-2-24 05:12 , Processed in 0.447625 second(s), Total 42, Slave 37 queries .
