在进行Android开发的过程中,免不了,要开发TCP/UDP通讯的程序,下面这两段代码,分别介绍了TCP/UCP通过的一个实例: 代码一: private void tcpdata() { try { Socket s = newSocket("192.168.0.25", 65500); // outgoing stream redirect to socket OutputStream out = s.getOutputStream(); // 注意第二个参数据为true将会自动flush,否则需要需要手动操作out.flush() PrintWriter output = new PrintWriter(out,true); output.println("Hello IdeasAndroid! 伪IP为:" +SIMCardToIP("13512345006")); InputStream inputStream = s.getinputStream(); DataInputStream input = newDataInputStream(inputStream); byte[] b = new byte[10000]; int length = input.read(b); inputReader = newInputStreamReader(inputStream); String Msg = new String(b, 0, length,"gb2312"); Toast.makeText(TcpTest.this, Msg,1000).show(); Log.d("Tcp Demo", "message FromServer:" + Msg); s.close(); } catch (UnknownHostException e) { e.printStackTrace(); } catch (IOException e) { e.printStackTrace(); } } 下面的代码是UDP通讯的过程: public String send(String msg) { StringBuilder *** = new StringBuilder(); InetAddress local = null; try { local = InetAddress.getByName("192.168.0.25"); // 本机测试 } catch (UnknownHostException e) { e.printStackTrace(); } try { dSocket = new DatagramSocket(); // 注意此处要先在配置文件里设置权限,否则会抛权限不足的异常 } catch (SocketException e) { e.printStackTrace(); } int msg_len = msg == null ? 0 : msg.length(); DatagramPacket dPacket = new DatagramPacket(msg.getBytes(),msg_len, local, SERVER_PORT); try { dSocket.send(dPacket); } catch (IOException e) { e.printStackTrace(); } try { dSocket.receive(dPacket); ***.append(new String(dPacket.getData())); } catch (IOException e) { // TODO Auto-generated catch block e.printStackTrace(); } dSocket.close(); return ***.toString(); } |
3474个成员聚集在这个小组
3342 浏览 1 评论
3993 浏览 0 评论
3496 浏览 0 评论
4073 浏览 1 评论
20743 浏览 11 评论
896浏览 2评论
1186浏览 2评论
1117浏览 1评论
1295浏览 1评论
457浏览 1评论
GMT+8, 2025-2-25 06:21 , Processed in 0.746911 second(s), Total 71, Slave 54 queries .
