扫一扫,分享给好友
在NI-官网上下载的Modbus函数库,是个压缩包,解压后把文件拷到安装目录下,但是在程序设计是在函数中找不到Modbus函数。估计是安装不对,希望大家指导。急急急。。。
6个回答
不知道是不是记错了,VIPM里面有MODBUS库,今天找,没找到
1 条评论
Installing NI-MODBUS Library
In order to use the Library in LabVIEW, please follow these steps: Close LabVIEW. If you have version NI-MODBUS Library 1.1 on your system, it is recommended to uninstall it by going to Control Panel -> Add Remove Programs -> National Instruments Software and select NI Modbus 1.1 from the list. Copy NI Modbus.llb from the ##vi.lib folder to the LabVIEW_ROOTvi.lib directory where ## is your LabVIEW version (example 86 for 8.6) and is the root folder where you installed LabVIEW. Copy lvmodbus.chm and lvmodbus.txt from ##help to the LabVIEW_ROOThelp directory. Copy nimodbus.mnu from ##user.lib to the LabVIEW_ROOTuser.lib directory. Restart LabVIEW. You should see the NI Modbus palette in the User Libraries palette. To Uninstall the Library, remove all the files copied from the previous steps. Back to Top |
791 浏览 1 评论
2300 浏览 2 评论
2044 浏览 4 评论
labview如何实现电机位置与图像清晰度计算值相对应,或者说如何实现电机每步距计算一次清晰度值?
2247 浏览 2 评论
2774 浏览 1 评论
GMT+8, 2025-2-24 07:02 , Processed in 0.485466 second(s), Total 56, Slave 50 queries .
