如题,遇到两个个问题,一是数码管显示不出来,二是max7219发烫
硬件部分,数码管是共阴极,这个脚接在DIG0-7任何一个脚都可以吗? 程序: #include #define uchar unsigned char #define uint unsigned int //定义Max7219端口 ***it Max7219_pinCLK = P0^5; ***it Max7219_pinCS = P0^6; ***it Max7219_pinDIN = P0^7; void Delay_xms(uint x) { uint i,j; for(i=0;i } //-------------------------------------------- //功能:向MAX7219(U3)写入字节 //入口参数:DATA //出口参数:无 //说明: void Write_Max7219_byte(uchar DATA) { uchar i; Max7219_pinCS=0; for(i=8;i>=1;i--) { Max7219_pinCLK=0; Max7219_pinDIN=DATA&0x80; DATA=DATA<<1; Max7219_pinCLK=1; } } //------------------------------------------- //功能:向MAX7219写入数据 //入口参数:address、dat //出口参数:无 //说明: void Write_Max7219(uchar address,uchar dat) { Max7219_pinCS=0; Write_Max7219_byte(address); //写入地址,即数码管编号 Write_Max7219_byte(dat); //写入数据,即数码管显示数字 Max7219_pinCS=1; } void Init_MAX7219(void) { Write_Max7219(0x09, 0xff); //译码方式:BCD码 Write_Max7219(0x0a, 0x0F); //亮度 Write_Max7219(0x0b, 0x07); //扫描界限;4个数码管显示 Write_Max7219(0x0c, 0x01); //掉电模式:0,普通模式:1 Write_Max7219(0x0f, 0x01); //显示测试:1;测试结束,正常显示:0 } void main(void) { uchar i,j; Delay_xms(50); Init_MAX7219(); Delay_xms(2000); Write_Max7219(0x0f, 0x00); //显示测试:1;测试结束,正常显示:0 ax7219(4,5); Write_Ma Write_Max7219(1,8); Write_Max7219(2,7); Write_Max7219(3,6); Write_Mx7219(5,4); Write_Max7219(6,3); Write_Max7219(7,2); Write_Max7219(8,1); Delay_xms(2000); for(j=1;j<9;j++) { for(i=0;i<10;i++) { Write_Max7219(j,i); Delay_xms(100); } } while(1); } |
109 浏览 2 评论
ESP32开发中,使用ADF环境,系统报错I2C Bus WriteReg Error和I2C Bus ReadReg Error
143 浏览 1 评论
在ZYNQ上跑超炫酷GUI!手把手教你移植LVGL到ZYNQ平台!
455 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之FLEXCAN
846 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之ADC
816 浏览 0 评论
12458 浏览 31 评论
GMT+8, 2025-3-6 02:29 , Processed in 0.464295 second(s), Total 68, Slave 51 queries .
