扫一扫,分享给好友
我也很想知道答案,希望有大神能解决这个问题。
另外一条曲线的开始几个点用null代替,graph不绘制null的点,试一试 sorry:应该是NaN,记错了。graph不绘制NaN的点。 |
试了多种方法还是不能创建带null结点的数组,能否贴个小程序呢 |
Sorry,我记错了,是NaN; ![]() ![]() 关于NaN的官方解释: http://labviewwiki.org/NaN NaNNaN is the notation in LabVIEW for the floating-point value Not-a-Number. LabVIEW implements the IEEE-754 standard for floating-point calculations, which specifies unique values for the outputs of mathematical operations which have no meaningful numerical result. A few examples of calculations which produce NaN are:
One salient feature of the NaN value is that all comparison operations involving NaN return FALSE, including the equality operator (in other words, NaN != NaN). LabVIEW provides the Not A Number/Path/Refnum? primitive, which is the proper way to test for NaN.
Use Cases
太厉害了,学习学习
前几天弄出来过,这几天又给忘了
谢谢了,刚好急用,谢谢
感谢!
NI USB-6008/6009双通道AO输出及AI输入显示
857 浏览 0 评论
713 浏览 1 评论
1019 浏览 1 评论
4020 浏览 2 评论
2304 浏览 5 评论
GMT+8, 2025-3-5 06:09 , Processed in 0.686925 second(s), Total 96, Slave 76 queries .
