最近做了个8*8光立方,硬件电路做好后写了一个测试程序,可是程序主循环循环几次后就卡死了,显示也是乱码,重新上电后程序就不能运行了。难道我写的程序可以把自己给改了?不然怎么卡死一次就不能再用了呢?极度迷茫中....
10个回答
没有看到你的程序呀,别人怎么帮你呀!传上来让大家一起看一下呀!
没程序。这不是白问
不好意思啊,失误 /*****************main.c*****************/ #include #include #define uchar unsigned char uchar data a[64];//={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; uchar idata d[64];//={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; ***it st_cp=P3^3; ***it st_clr=P3^2; //显示串口清除 uchar clock=0; uchar ram=0; void display(); void delay(); void asm(char asm) { #pragma asm MOV P0,R7 MOV R3,#0FEH LOOP1: MOV R5,#10 MOV R6,#255 LOOP: MOV P2,R3 MOV A,R3 RR A MOV R3,A DJNZ R6,LOOP DJNZ R5,LOOP #pragma endasm } void play() { uchar i=0; TR0=0; //关T0 TH0=62869/256; TL0=62869%256; //34ms if(ram) //是否请求显存复制 { for(i=0;i<64;i++) //显存复制 { a=d; } ram=0; } if(!clock) //是否是锁显 { display(); } TR0=1; //开T0 } void display() { uchar i,j,y,x; P2=0xff; P0=0; x=1; y=0; for(i=0;i<8;i++) //第一层 { y=8*i; st_cp=0; for(j=0;j<8;j++) //第一列 { SBUF=(~a[7+y-j]); while(!TI); TI=0; } st_cp=1; asm(x); x=(x<<1); } P2=0xff; P0=0; } void delay() { uchar j,k; for(k=0;k<255;k++) for(j=0;j<255;j++); } void delay1() { uchar j,k; for(k=0;k<127;k++) for(j=0;j<255;j++); } void main() { uchar i,j; /*******t0初始化 显示 *********/ TMOD=0x01; //方式1 TH0=63869/256; //20ms TL0=63869%256; ET0=1; //T0允许 EA=1; TR0=1; //T0运行 clock=0; while(1) { for(i=0;i<64;i++) { d=a1; ram=1; while(!ram); } delay(); delay(); delay(); for(i=0;i<64;i++) { d=a2; ram=1; while(!ram); } delay(); delay(); delay(); for(i=0;i<64;i++) { d=a3; ram=1; while(!ram); } delay(); delay(); delay(); for(i=0;i<64;i++) { d=a4; ram=1; while(!ram); } delay(); delay(); delay(); for(i=0;i<64;i++) { d=a5; ram=1; while(!ram); } delay(); delay(); delay(); for(i=0;i<64;i++) { d=a6; ram=1; while(!ram); } delay(); delay(); delay(); for(i=0;i<64;i++) { d=a7; ram=1; while(!ram); } delay(); delay(); delay(); for(i=0;i<64;i++) { d=a8; ram=1; while(!ram); } delay(); delay(); delay(); for(i=0;i<64;i++) { d=a9; ram=1; while(!ram); } delay(); delay(); delay(); for(i=0;i<64;i++) { d=a10; ram=1; while(!ram); } delay(); delay(); delay(); for(i=0;i<64;i++) { d=a11; ram=1; while(!ram); } delay(); delay(); delay(); for(j=0;j<3;j++) { for(i=0;i<64;i++) { d=a12; ram=1; while(!ram); } delay1(); for(i=0;i<64;i++) { d=a13; ram=1; while(!ram); } delay1(); for(i=0;i<64;i++) { d=a14; ram=1; while(!ram); } delay1(); for(i=0;i<64;i++) { d=a15; ram=1; while(!ram); } delay1(); for(i=0;i<64;i++) { d=a16; ram=1; while(!ram); } delay1(); } } } void T_0() interrupt 1 //显示中断T0 { play(); //显示动作函数 } /****************aa.h****************/ #define uchar unsigned char uchar xdata a2[64]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0x18,0x24,0x7e,0x99,0x99,0x99,0xbd,0x66,0x18,0x24,0x7e,0x99,0x99,0x99,0xbd,0x66,0x18,0x24,0x7e,0x99,0x99,0x99,0xbd,0x66}; uchar xdata a1[64]={0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0,0xff,0}; 都是类似的编码 |
汇编那块我看不懂,为什么要用汇编啊?是卡死的话,大多是卡在死循环里吧while(!ram);,建议你一步一步来调试,先把后面一大块东西注释掉,一个一个小动画地来调试,看看是哪里出问题了 |
CrazyMCU 发表于 2013-8-23 20:52 c里没有循环左移,在keil里debug没事,到单片机里就不行了。 |
的开始不乱的。
225 浏览 0 评论
129 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-Pinctrl和GPIO子系统之ioctl介绍
567 浏览 0 评论
1195 浏览 1 评论
《DNESP32S3使用指南-IDF版_V1.6》第五十九章 人脸识别实验
1448 浏览 0 评论
12660 浏览 31 评论
GMT+8, 2025-3-31 04:54 , Processed in 0.686419 second(s), Total 89, Slave 72 queries .
