基于电流直接控制的光伏电池最大功率点跟踪策略
txA3gtZF.pdf
(287.64 KB, 下载次数: 51
在传统的光伏系统最大功率点跟踪(MPPT)策略中,扰动观测法是检测系统的输入电压电流,计算其输入功率并 使其达到最大。本文在分析了光伏电池特性及数学模型的基础上,提出了一种以系统输出电流最大为目标、不依赖光伏电池 输出特性检测的最大功率点跟踪策略。最后,通过电流型光伏并网逆变器和光伏充电器的实验结果,该方案的可行性和正确 性得到了验证。 Abstract: In conventional maximum power point tracking(MPPT)strategy of photovoltaic System , the disturbance observation technology needs to measure the input voltage and current in order that the input power is maximized. With the analysis of characteristic and mathematic model of photovoltaic cell , a MPPT strategy is proposed in this paper which aims at getting maximum output current and doesn’t need to get the output characteristic of photovoltaic cell. The experiment results of a current source PV grid-connected inverter and a PV charger verify the availability and correctness of the proposed method. 关键词:光伏系统,最大功率点跟踪,蓄电池充电 Keywords: photovoltaic system, Maximum power point tracking, Battery charging |
2141 浏览 2 评论
24v开关电源指示灯有规律的一暗一暗,输出电压在20到22v之间跳变怎么查找?
1660 浏览 4 评论
电源接线检测仪LED1、2电路的二极管是反接的,灯为什么会亮?
8552 浏览 2 评论
5024 浏览 1 评论
各位大神,求电路图,用MC34063设计出一个升降压DC-DC,输出900mA左右
5749 浏览 0 评论
GMT+8, 2024-9-21 05:43 , Processed in 0.582039 second(s), Total 78, Slave 58 queries .
