[This introduction is not part of IEEE Std 1226.3-1998, IEEE Standard for Software Interface for Resource Management
for A Broad-Based Environment for Test (ABBET).] In the course of developing IEEE Std 1226-1993, A Broad-Based Environment for Test (ABBET), it was determined that multiple standards would be required to define the various ABBET functions and interfaces. These standards consist of the Overview and Architecture Standard, numbered 1226, and a set of related component standards, numbered 1226.1 through 1226.x. This component standard, numbered 1226.3, documents the software interfaces defined by ABBET to test equipment configuration information. At the February, 1991, ABBET meeting, it was decided to document the automatic test equipment (ATE) system and instrument control in a single component standard. Deliberations subsequent to that meeting, however, revealed that combining the groups of interfaces into a single component standard would force implementations of the instrumentation interfaces to conform to a subset of that standard. Therefore, it was concluded that the interface groups should be documented in separate component standards, and that these standards would naturally divide at the interface between Test Equipment Description Language (TEDL) and Resource Description Language (RDL). At the Scottsdale, Arizona, meeting in May, 1991, this decision was changed, as it was decided to create three component standards for the ATE system layer: one for the resource management interfaces (referencing TEDL and RDL), one for the instrument interfaces (referencing SCPI, CIIL, etc.), and one for the instrument control bus interfaces (referencing IEEE 488, VXI, Ethernet, etc.). This standard is intended to document the interfaces to services to ATE descriptive information that would allow bridging the gap between an ABBET ATLAS level test procedure and an ATE (referred to in this standard as “ATE interface services”). |
GMT+8, 2024-12-28 17:09 , Processed in 0.374395 second(s), Total 36, Slave 27 queries .
