扫一扫,分享给好友
LCD1602突然只能显示数字,不能显示字母,显示字母突然出错。跪求大神解释原因:#include "C8051F120.h"
#include"stdio.h" #define uchar unsigned char #define uint unsigned int ***it LCD_RS = P2^0; //复位端 ***it LCD_RW = P2^1; //写数据端 ***it LCD_EP = P2^2; //使能端 void delay_1ms(uint z) //延时z*1ms { uint x,y; for(x=z; x>0; x--) for(y=1696; y>0; y--); } /****************侧忙函数,读状态************************/ void lcd_bz()// 测试LCD忙碌状态 { LCD_RS = 0; LCD_RW = 1; LCD_EP = 1; //EP代表的是DB7,输入使能信号,当其变为1代表不忙 delay_1ms(2); while((P1 & 0x80)); LCD_EP = 0; } /****************写命令函数************************/ lcd_wcmd(uchar cmd) { lcd_bz(); //当不忙时 LCD_RS = 0; LCD_RW = 0; LCD_EP = 0; delay_1ms(1); P1 = cmd; //将8位指令通过P0口传给1602 delay_1ms(1); LCD_EP = 1; delay_1ms(1); LCD_EP = 0; } /****************写数据函数************************/ char putchar(uchar dat) //没有将返回值送回,故存在一个警告 { lcd_bz(); //当不忙时 LCD_RS = 1; LCD_RW = 0; LCD_EP = 0; delay_1ms(1); P1 = dat; //将8位指令通过P0口传给1602 delay_1ms(1); LCD_EP = 1; delay_1ms(1); LCD_EP = 0; return(0) ; } /****************写地址函数************************/ void gotoxy (uchar y ,uint x )//置光标于y行,X列 { switch(y) { case 0 : x=x+0x80;break; case 1 : x=x+0x40+0x80; break; //1602,第二行的位置 default : break; } lcd_wcmd(x); } /****************初始化LCD1602函数************************/ lcd_init() { lcd_wcmd(0x38); //16*2显示,5*7点阵,8位数据 delay_1ms(1); lcd_wcmd(0x0c); //显示开,关光标 delay_1ms(1); lcd_wcmd(0x06); //移动光标 delay_1ms(1); lcd_wcmd(0x01); //清除LCD的显示内容 delay_1ms(80); } void Port_IO_Init() { SFRPAGE = CONFIG_PAGE; XBR2 = 0x40; } void Reset_Sources_Init() { WDTCN = 0xDE; WDTCN = 0xAD; } void Oscillator_Init() { int i = 0; SFRPAGE = CONFIG_PAGE; OSCXCN = 0x67; for (i = 0; i < 3000; i++); // Wait 1ms for initialization while ((OSCXCN & 0x80) == 0); CLKSEL = 0x01; OSCICN &= ~0x80; } void Init_Device(void) { Port_IO_Init(); Oscillator_Init(); Reset_Sources_Init(); lcd_init(); } void main() { float c=1.23569; Init_Device(); delay_1ms(2); gotoxy(0 ,1 ); //第一个字符决定行,第二个字符决定位置 delay_1ms(10) ; printf("abcddef"); //printf 跟 putchar 函数配合使用,输出字符,为最简单的字符输出 gotoxy(1,2 ); //第一个字符决定行,第二个字符决定位置 printf("wen=%6.4f",c) ;//输出的结果为wen=1.2357 while(1); } |
4个回答
程序应该没有问题,我以前都液晶都是这么写的,不知道为什么突然出现这种状况
没人帮忙啊,只能独立解决了
这边是 1602的问题,换一个就好了。
202 浏览 0 评论
556 浏览 2 评论
ESP32开发中,使用ADF环境,系统报错I2C Bus WriteReg Error和I2C Bus ReadReg Error
495 浏览 1 评论
在ZYNQ上跑超炫酷GUI!手把手教你移植LVGL到ZYNQ平台!
709 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之FLEXCAN
888 浏览 0 评论
12463 浏览 31 评论
GMT+8, 2025-3-7 08:04 , Processed in 0.430866 second(s), Total 46, Slave 40 queries .
