/* --COPYRIGHT--,BSD_EX
* Copyright (c) 2012, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * ******************************************************************************* * * MSP430 CODE EXAMPLE DISCLAIMER * * MSP430 code examples are self-contained low-level programs that typically * demonstrate a single peripheral function or device feature in a highly * concise manner. For this the code may rely on the device's power-on default * register values and settings such as the clock configuration and care must * be taken when combining code from several examples to avoid potential side * effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware * for an API functional library-approach to peripheral configuration. * * --/COPYRIGHT--*/ //****************************************************************************** // MSP430G2xx3 Demo - Timer_A, Ultra-Low Pwr UART 9600 Echo, 32kHz ACLK // // Description: Use Timer_A CCR0 hardware output modes and SCCI data latch // to implement UART function @ 9600 baud. Software does not directly read and // write to RX and TX pins, instead proper use of output modes and SCCI data // latch are demonstrated. Use of these hardware features eliminates ISR // latency effects as hardware insures that output and input bit latching and // timing are perfectly synchronised with Timer_A regardless of other // software activity. In the Mainloop the UART function readies the UART to // receive one character and waits in LPM3 with all activity interrupt driven. // After a character has been received, the UART receive function forces exit // from LPM3 in the Mainloop which configures the port pins (P1 & P2) based // on the value of the received byte (i.e., if BIT0 is set, turn on P1.0). // ACLK = TACLK = LFXT1 = 32768Hz, MCLK = SMCLK = default DCO // //* An external watch crystal is required on XIN XOUT for ACLK *// // // MSP430G2xx3 // ----------------- // /|| XIN|- // | | | 32kHz // --|RST XOUT|- // | | // | CCI0B/TXD/P1.1|--------> // | | 9600 8N1 // | CCI0A/RXD/P1.2|<-------- // // D. Dang // Texas Instruments Inc. // December 2010 // Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10 //****************************************************************************** #include //------------------------------------------------------------------------------ // Hardware-related definitions //------------------------------------------------------------------------------ #define UART_TXD 0x02 // TXD on P1.1 (Timer0_A.OUT0) #define UART_RXD 0x04 // RXD on P1.2 (Timer0_A.CCI1A) //------------------------------------------------------------------------------ // Conditions for 9600 Baud SW UART, SMCLK = 1MHz //------------------------------------------------------------------------------ #define UART_TBIT_DIV_2 (1000000 / (9600 * 2)) #define UART_TBIT (1000000 / 9600) //------------------------------------------------------------------------------ // Global variables used for full-duplex UART communication //------------------------------------------------------------------------------ unsigned int txData; // UART internal variable for TX unsigned char rxBuffer; // Received UART character //------------------------------------------------------------------------------ // Function prototypes //------------------------------------------------------------------------------ void TimerA_UART_init(void); void TimerA_UART_tx(unsigned char byte); void TimerA_UART_print(char *string); //------------------------------------------------------------------------------ // main() //------------------------------------------------------------------------------ int main(void) { WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer if (CALBC1_1MHZ==0xFF) // If calibration constant erased { while(1); // do not load, trap CPU!! } DCOCTL = 0; // Select lowest DCOx and MODx settings BCSCTL1 = CALBC1_1MHZ; // Set DCOCLK to 1MHz DCOCTL = CALDCO_1MHZ; P1OUT = 0x00; // Initialize all GPIO P1SEL = UART_TXD + UART_RXD; // Timer function for TXD/RXD pins P1DIR = 0xFF & ~UART_RXD; // Set all pins but RXD to output P2OUT = 0x00; P2SEL = 0x00; P2DIR = 0xFF; __enable_interrupt(); TimerA_UART_init(); // Start Timer_A UART TimerA_UART_print("G2xx2 TimerA UARTrn"); TimerA_UART_print("READY.rn"); for (;;) { // Wait for incoming character __bis_SR_register(LPM0_bits); // Update board outputs according to received byte if (rxBuffer & 0x01) P1OUT |= 0x01; else P1OUT &= ~0x01; // P1.0 if (rxBuffer & 0x02) P1OUT |= 0x08; else P1OUT &= ~0x08; // P1.3 if (rxBuffer & 0x04) P1OUT |= 0x10; else P1OUT &= ~0x10; // P1.4 if (rxBuffer & 0x08) P1OUT |= 0x20; else P1OUT &= ~0x20; // P1.5 if (rxBuffer & 0x10) P1OUT |= 0x40; else P1OUT &= ~0x40; // P1.6 if (rxBuffer & 0x20) P1OUT |= 0x80; else P1OUT &= ~0x80; // P1.7 if (rxBuffer & 0x40) P2OUT |= 0x40; else P2OUT &= ~0x40; // P2.6 if (rxBuffer & 0x80) P2OUT |= 0x80; else P2OUT &= ~0x80; // P2.7 // Echo received character TimerA_UART_tx(rxBuffer); } } //------------------------------------------------------------------------------ // Function configures Timer_A for full-duplex UART operation //------------------------------------------------------------------------------ void TimerA_UART_init(void) { TACCTL0 = OUT; // Set TXD Idle as Mark = '1' TACCTL1 = SCS + CM1 + CAP + CCIE; // Sync, Neg Edge, Capture, Int TACTL = TASSEL_2 + MC_2; // SMCLK, start in continuous mode } //------------------------------------------------------------------------------ // Outputs one byte using the Timer_A UART //------------------------------------------------------------------------------ void TimerA_UART_tx(unsigned char byte) { while (TACCTL0 & CCIE); // Ensure last char got TX'd TACCR0 = TAR; // Current state of TA counter TACCR0 += UART_TBIT; // One bit time till first bit TACCTL0 = OUTMOD0 + CCIE; // Set TXD on EQU0, Int txData = byte; // Load global variable txData |= 0x100; // Add mark stop bit to TXData txData <<= 1; // Add space start bit } //------------------------------------------------------------------------------ // Prints a string over using the Timer_A UART //------------------------------------------------------------------------------ void TimerA_UART_print(char *string) { while (*string) { TimerA_UART_tx(*string++); } } //------------------------------------------------------------------------------ // Timer_A UART - Transmit Interrupt Handler //------------------------------------------------------------------------------ #pragma vector = TIMER0_A0_VECTOR __interrupt void Timer_A0_ISR(void) { static unsigned char txBitCnt = 10; TACCR0 += UART_TBIT; // Add Offset to CCRx if (txBitCnt == 0) { // All bits TXed? TACCTL0 &= ~CCIE; // All bits TXed, disable interrupt txBitCnt = 10; // Re-load bit counter } else { if (txData & 0x01) { TACCTL0 &= ~OUTMOD2; // TX Mark '1' } else { TACCTL0 |= OUTMOD2; // TX Space '0' } txData >>= 1; txBitCnt--; } } //------------------------------------------------------------------------------ // Timer_A UART - Receive Interrupt Handler //------------------------------------------------------------------------------ #pragma vector = TIMER0_A1_VECTOR __interrupt void Timer_A1_ISR(void) { static unsigned char rxBitCnt = 8; static unsigned char rxData = 0; switch (__even_in_range(TA0IV, TA0IV_TAIFG)) { // Use calculated branching case TA0IV_TACCR1: // TACCR1 CCIFG - UART RX TACCR1 += UART_TBIT; // Add Offset to CCRx if (TACCTL1 & CAP) { // Capture mode = start bit edge TACCTL1 &= ~CAP; // Switch capture to compare mode TACCR1 += UART_TBIT_DIV_2; // Point CCRx to middle of D0 } else { rxData >>= 1; if (TACCTL1 & SCCI) { // Get bit waiting in receive latch rxData |= 0x80; } rxBitCnt--; if (rxBitCnt == 0) { // All bits RXed? rxBuffer = rxData; // Store in global variable rxBitCnt = 8; // Re-load bit counter TACCTL1 |= CAP; // Switch compare to capture mode __bic_SR_register_on_exit(LPM0_bits); // Clear LPM0 bits from 0(SR) } } break; } } //------------------------------------------------------------------------------ |
3244个成员聚集在这个小组
加入小组5297 浏览 1 评论
6121 浏览 1 评论
MSP430FR5994 使用库函数 定时器触发AD问题请教
6399 浏览 2 评论
请问怎么把下面51单片机的代码改成msp430 g2 pocket的代码,还有改下时间变成30秒
2518 浏览 1 评论
4981 浏览 1 评论
5178浏览 3评论
6409浏览 2评论
6131浏览 1评论
5307浏览 1评论
3996浏览 0评论
GMT+8, 2025-7-13 14:46 , Processed in 1.313177 second(s), Total 42, Slave 35 queries .
