DSP—算法——精华资料
10
骗子,就知道骗积分
bbs.elecfans.combbs.elecfans.com
个人认为,对于这么没有任何针对的东西,下载的意义不大,讲的很泛泛
顶顶顶
#include
#include
#include
#include
#define uchar unsigned char
#define uint unsigned int
***it Key1 = P2^3;
***it Key2 = P2^2;
***it Key3 = P2^1;
***it Key4 = P2^0;
***it BELL = P3^6;
***it CONNECT = P3^7;
unsigned int Key1_flag = 0;
unsigned int Key2_flag = 0;
unsigned int Key3_flag = 0;
unsigned int Key4_flag = 0;
unsigned char b;
unsigned char code Num[21]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,
0x90,0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,
0x10,0x89};
unsigned char code Disdigit[4] = {0x7F,0xBF,0xDF,0xEF};
unsigned char Di***uf[4];
void delayms(uint t)
uint i;
while(t--)
/* 对于11.0592M时钟,约延时1ms */
for (i=0;i<125;i++)
void SendData(uchar Dat)
uchar i=0;
SBUF = Dat;
while (1)
if(TI)
TI=0;
break;
void ScanKey()
if(Key1 == 0)
delayms(100);
if(Key1 == 0)
Key1_flag = 1;
Key2_flag = 0;
Key3_flag = 0;
Key4_flag = 0;
Key1 = 1;
else;
if(Key2 == 0)
delayms(100);
if(Key2 == 0)
Key2_flag = 1;
Key1_flag = 0;
Key3_flag = 0;
Key4_flag = 0;
Key2 = 1;
else;
if(Key3 == 0)
delayms(50);
if(Key3 == 0)
Key3_flag = 1;
Key1_flag = 0;
Key2_flag = 0;
Key4_flag = 0;
Key3 = 1;
else;
if(Key4 == 0)
delayms(50);
if(Key4 == 0)
Key4_flag = 1;
Key1_flag = 0;
Key2_flag = 0;
Key3_flag = 0;
Key4 = 1;
else;
else;
void KeyProc()
if(Key1_flag)
TR1 = 1;
SendData(0x55);
Key1_flag = 0;
else if(Key2_flag)
TR1 = 1;
SendData(0x11);
Key2_flag = 0;
else if(Key3_flag)
P1=0xff;
BELL = 0;
CONNECT = 1;
Key3_flag = 0;
else if(Key4_flag)
CONNECT = 0;
BELL = 1;
Key4_flag = 0;
else;
void Initdisplay(void)
Di***uf[0] = 1;
Di***uf[1] = 2;
Di***uf[2] = 3;
Di***uf[3] = 4;
void Display() //显示
unsigned int i = 0;
unsigned int temp,count;
temp = Disdigit[count];
P2 =temp;
temp = Di***uf[count];
temp = Num[temp];
P0 =temp;
count++;
if (count==4)
count=0;
void time0() interrupt 1 using 2
Display();
TH0 = (65535 - 2000)/256;
TL0 = (65535 - 2000)%256;
void main()
Initdisplay();
TMOD = 0x21;
TR0 = 1;
ET0 = 1;
TH1 = 0xFD; //11.0592M
TL1 = 0xFD;
PCON&=0x80;
TR1 = 1;
ET1 = 1;
SCON = 0x40; //串口方式
REN = 1;
PT1 = 0;
PT0 = 1;
EA = 1;
while(1)
ScanKey();
KeyProc();
if(RI)
Di***uf[0] = 0;
Di***uf[1] = 20;
Di***uf[2] = SBUF>>4;
Di***uf[3] = SBUF&0x0f;
RI = 0;
else;
