扫一扫,分享给好友
找了很久却不知道错哪,求大侠相助!!
#include #include #define uchar unsigned char #define uint unsigned int ***it s_clka=P2^4; ***it r_clka=P2^3; ***it mosio=P2^2; ***it sck=P3^6; ***it io=P3^4; ***it rst=P3^5; uchar code dula[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf}; uchar code wela[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01}; uchar time_data[7]={10,6,4,17,58,8,38}; uchar write_add[7]={0x8c,0x8a,0x88,0x86,0x84,0x82,0x80}; uchar read_add[7]={0x8d,0x8b,0x89,0x87,0x85,0x83,0x81}; uchar disp[8]; unsigned char flag; unsigned int count; void smg(uchar dat1,uchar dat2); void send(uchar dat); void out(); void write_ds1302_byte(uchar dat); void write_ds1302(uchar add,uchar dat); uchar read_ds1302(uchar add); void set_rtc(); void read_rtc(); void time_pros(); void display(); void main() { set_rtc(); while(1) { read_rtc(); time_pros(); display(); } } void set_rtc() { uchar i,j; for(i=0;i<7;i++) { j=time_data[i]/10; time_data[i]=time_data[i]%10; time_data[i]=time_data[i]+j*16; } write_ds1302(0x8e,0x00); //去处写保护 for(i=0;i<7;i++) { write_ds1302(write_add[i],time_data[i]); } write_ds1302(0x8e,0x80); } void read_rtc() { uchar i; for(i=0;i<7;i++) { time_data[i]=read_ds1302(read_add[i]); } } void time_pros() { disp[0]=time_data[6]%16; disp[1]=time_data[6]/16; disp[2]=10; disp[3]=time_data[5]%16; disp[4]=time_data[5]/16; disp[5]=10; disp[6]=time_data[4]%16; disp[7]=time_data[4]/16; } void write_ds1302_byte(uchar dat) { uchar i; for(i=0;i<8;i++) { sck=0; io=dat&0x01; dat=dat>>1; sck=1; } } void write_ds1302(uchar add,uchar dat) { rst=0; _nop_(); sck=0; _nop_(); rst=1; _nop_(); write_ds1302_byte(add); write_ds1302_byte(dat); rst=0; _nop_(); io=1; sck=1; } uchar read_ds1302(uchar add) { uchar i,value; rst=0; _nop_();_nop_(); sck=0; _nop_();_nop_(); rst=1; _nop_();_nop_(); write_ds1302_byte(add); for(i=0;i<8;i++) { if(io) value=value|0x80; sck=0; value=value>>1; _nop_(); _nop_(); _nop_(); sck=1; } rst=0; _nop_();_nop_(); sck=0; rst=0; _nop_(); _nop_(); _nop_(); _nop_(); sck=1; _nop_(); _nop_(); io=1; _nop_();_nop_(); return value; } void display() { uchar i; for(i=0;i<8;i++) { smg(wela[i],dula[disp[i]]); } } void smg(uchar dat1,uchar dat2) { send(dat1); send(dat2); out(); } void send(uchar dat) { uchar i; for(i=0;i<8;i++) { if((dat< mosio=1; else mosio=0; s_clka=0; s_clka=1; } } void out() { r_clka=0; r_clka=1; } |
5个回答
非常感谢!! |
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之电阻屏触摸
899 浏览 0 评论
1438 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之I2C-RTC
622 浏览 0 评论
ATK-DLRK3588开发板deepseek-r1-1.5b/7b部署指南
3183 浏览 0 评论
《DNESP32S3使用指南-IDF版_V1.6》第五十章 WiFi热点实验
997 浏览 0 评论
12394 浏览 31 评论
GMT+8, 2025-2-24 19:58 , Processed in 0.524626 second(s), Total 82, Slave 65 queries .
