扫一扫,分享给好友
时钟能正常走,就是有两个数字跟问号交替出现 下面是程序: #include #define uchar unsigned char #define uint unsigned int uchar code table[]=" 20 - - "; uchar code table1[]=" : : "; ***it lcdrs=P2^0; //1602信号 ***it lcdrw=P2^1; //写命令,置低电平 ***it lcden=P2^2; //1602使能端 ***it dsrst=P2^5; //ds1302复位 ***it dsio=P2^6; //1302IO口 ***it dssck=P2^7; //1302时钟 ***it fmq=P3^5; //蜂鸣器 ***it s0=P3^0; //增大键 ***it s1=P3^1; //减小键 ***it s2=P3^2; //功能键 ***it s3=P3^3; //闹钟查看键 bit run; uchar miao, fen, shi, week, day, month, year, tflag; void delayms(uint z) { uint x, y; for(x=z;x>0;x--) for(y=110;y>0;y--); } void di() {//蜂鸣器 fmq=0; delayms(100); fmq=1; } void write_com(uchar com) { lcdrs=0; P0=com; delayms(5); lcden=1; delayms(5); lcden=0; } void write_data(uchar dat) { lcdrs=1; P0=dat; delayms(5); lcden=1; delayms(5); lcden=0; } void write_sfm(uchar add,uchar date) {//1602刷新时间 uchar shi,ge; shi=date/16; ge=date%16; write_com(0x80+0x40+add); write_data(0x30+shi); write_data(0x30+ge); } void write_nyr(uchar add,uchar date) {//1602刷新年月日 uchar shi,ge; shi=date/16; ge=date%16; write_com(0x80+add); write_data(0x30+shi);//0x30对应ASCII码 write_data(0x30+ge); } void write_week(char we) {//星期 write_com(0x80+12); switch(we) { case 1: write_data('M');delayms(5); write_data('O');delayms(5); write_data('N');delayms(5); break; case 2: write_data('T');delayms(5); write_data('U');delayms(5); write_data('E');delayms(5); break; case 3: write_data('W');delayms(5); write_data('E');delayms(5); write_data('D');delayms(5); break; case 4: write_data('T');delayms(5); write_data('H');delayms(5); write_data('U');delayms(5); break; case 5: write_data('F');delayms(5); write_data('R');delayms(5); write_data('T');delayms(5); break; case 6: write_data('S');delayms(5); write_data('A');delayms(5); write_data('T');delayms(5); break; case 7: write_data('S');delayms(5); write_data('U');delayms(5); write_data('N');delayms(5); break; } } void init1() { uchar num; /*.........液晶初始程序................................*/ lcdrw=0; lcden=0; write_com(0x38); write_com(0x0c); write_com(0x06); write_com(0x01); write_com(0x80); for(num=0;num<16;num++) write_data(table[num]); write_com(0x80+0x40); for(num=0;num<16;num++) write_data(table1[num]); /*......................................................*/ } void delayus(uint t) { t--; } /*................1302读写程序..........................*/ void write_byte(uchar dat) { uchar i; dssck=0;//初始时钟线为0 for(i=0;i<8;i++)//开始传送八位字节的数据 { dssck=0; dsio=dat&0x01;//取最低位传送给IO delayus(2); dssck=1;//时钟线拉高,数据传走 delayus(2); dssck=0; dat>>=1;//右移一位 } } void write_ds(uchar add, uchar dat) { dsrst=0;//CE线为0 dssck=0;//时钟线为0 dsrst=1;//CE线为1,传输开始。。。位传输 write_byte(add);//传入命令字,写入时间,日历地址 write_byte(dat);//写入要修改的时间日历 dssck=1;//时钟线拉高 dsrst=0;//读取结束 } uchar read_byte() { uchar i, dat; delayus(2); for(i=0;i<8;i++) { dssck=0; dat>>=1;//左移一位 if(dsio) dat|=0x80;//按位或,最高位成为1 delayus(2); dssck=1; delayus(2); dssck=0; } return dat;//返回读取的值 } uchar read_ds(uchar add) { uchar dat; dsrst=0; dssck=0; dsrst=1; write_byte(add);//写入命令字,地址 dat=read_byte();//读取数据 delayus(2); dssck=1; delayus(2); dsrst=0; return dat; } /*......................................................*/ /*void init2()//1302 初始化 { write_ds(0x8e,0x00);//写保护关 write_ds(0x80,0x11); write_ds(0x82,0x11); write_ds(0x84,0x11); write_ds(0x86,0x11);//日11 write_ds(0x88,0x11);//月11 write_ds(0x8a,0x05);//星期5 write_ds(0x8c,0x11);//年11 write_ds(0x90,0x01);//充电????? write_ds(0xc0,0xf0); write_ds(0x8e,0x80);//写保护开 }*/ void main()
{ TMOD=0X02; //设置定时器0为工作方式2 TH0=0X06; //装初值 TL0=0X06; EA=1; //开总中断 ET0=1; //开定时器0中断 TR0=1; //启动定时器0 init1(); //1602初始程序 // init2(); //1302初始程序 /* year=read_ds(0x8d); write_nyr(3,year); month=read_ds(0x89); write_nyr(6,month); day=read_ds(0x87); write_nyr(9,day); shi=read_ds(0x85); write_sfm(4,shi); fen=read_ds(0x83); write_sfm(7,fen); miao=read_ds(0x81); write_sfm(10,miao); week=read_ds(0x8b); write_week(week); */ while(1) { delayms(20); miao=read_ds(0x81); fen=read_ds(0x83); shi=read_ds(0x85); year=read_ds(0x8d); month=read_ds(0x89); day=read_ds(0x87); week=read_ds(0x8b); write_sfm(10,miao); write_sfm(7,fen); write_sfm(4,shi); write_nyr(3,year); write_nyr(6,month); write_nyr(9,day); write_week(week); }
《DNESP32S3使用指南-IDF版_V1.6》第三十五章 摄像头实验
787 浏览 0 评论
《DNESP32S3使用指南-IDF版_V1.6》第三十章 DHT11数字温湿度传感器
755 浏览 0 评论
850 浏览 0 评论
【敏矽微ME32G070开发板免费体验】之原厂2812测试例程解析
1534 浏览 0 评论
1239 浏览 2 评论
12060 浏览 31 评论
GMT+8, 2024-12-29 14:03 , Processed in 0.373136 second(s), Total 35, Slave 29 queries .
