把数据存储于内部EEPROM中,数码管动态显示。
问题是每当数据写入内部EEPROM中时,数码管就闪烁一下! 请问大家有遇到过同样的问题吗!?大家是如何解决的呢!? 以上,谢谢。 贴上部分代码: //--------------------------------------------------------------------------------- #include #include //--------------------------------------------------------------------------------- #define ENABLE_IAP 0x83 //<12MHz uchar Byte_Read(uchar,uchar); void Byte_Program(uchar,uchar,uchar); void Sector_Erase(uchar,uchar); void IAP_Disable(); void Trigger_IAP(); //-----------Byte_Read---------------------------- uchar Byte_Read(uchar addr1_h,uchar addr1_l) { uchar date; IAP_CONTR = ENABLE_IAP ; //open IAP set Flash operation time IAP_CMD = 0x01; //Select Read AP Mode IAP_ADDRH = addr1_h; IAP_ADDRL = addr1_l; Trigger_IAP(); date =IAP_DATA; IAP_Disable(); //关闭IAP功能,清与IAP有关的SFR return date; } //------Byte_Program------------- void Byte_Program(uchar addr2_h,uchar addr2_l,uchar date1) { IAP_CONTR = ENABLE_IAP ; //open IAP set Flash operation time IAP_CMD = 0x02; // Select Read AP Mode IAP_ADDRH = addr2_h; IAP_ADDRL = addr2_l; IAP_DATA = date1; Trigger_IAP(); IAP_Disable(); //关闭IAP功能,清与IAP有关的SFR } //--------------Sector_Erase-------------- void Sector_Erase(uchar addr3_h,uchar addr3_l) { IAP_CONTR = ENABLE_IAP ; //open IAP set Flash operation time IAP_CMD = 0x03; // Select Read AP Mode IAP_ADDRH = addr3_h; IAP_ADDRL = addr3_l; Trigger_IAP(); IAP_Disable(); //关闭IAP功能,清与IAP有关的SFR } //--------IAP_Disable----------- void IAP_Disable() { IAP_CONTR = 0; IAP_CMD = 0; IAP_TRIG = 0; } //--------Trigger IAP processing------ void Trigger_IAP() { uchar i; IAP_TRIG = 0x5A; IAP_TRIG = 0xA5; for(i=0;i<10;i++); } //--------------------------------------------------------------------------------- //Nameelay(); //Function:Software delay function //Input: //Output: //--------------------------------------------------------------------------------- void Delay(uchar t) //延時程序,延時時間2ms*t { t_2ms=0; while(t_2ms //--------------------------------------------------------------------------------- //Name:Main //Function: //Input: //Output: //--------------------------------------------------------------------------------- void Main(void) { //------------------------------------------- TMOD = 0x11; //T1 setting TL0 = INTERVAL_T0_L ; //10ms//加載定時計數值 TH0 = INTERVAL_T0_H ; TL1 = INTERVAL_T1_L ; //2ms//加載定時計數值 TH1 = INTERVAL_T1_H ; TR0 = ON; TR1 = ON; ET0 = ENABLE; ET1 = ENABLE; EA = ENABLE; set_minute=Byte_Read(0x00,0x00);//讀EEPROM set_second=Byte_Read(0x00,0x01);//讀EEPROM second=set_second;minute=set_minute; start_flag=0; //===================================================== while(1) { Key_scan(); Output_ctl(); } } //--------------------------------------------------------------------------------- //Name:Timer1 //Function: //Input: //Output: //--------------------------------------------------------------------------------- void Timer1(void) interrupt 3 using 1 //2ms { TL1 = INTERVAL_T1_L ; //2ms TH1 = INTERVAL_T1_H ; t_2ms++;dis_ms++; display(); } //----------------------------------------------------------------------------------------------------------- //end |
3 个讨论
你正在撰写讨论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之电阻屏触摸
820 浏览 0 评论
1346 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之I2C-RTC
555 浏览 0 评论
ATK-DLRK3588开发板deepseek-r1-1.5b/7b部署指南
3012 浏览 0 评论
《DNESP32S3使用指南-IDF版_V1.6》第五十章 WiFi热点实验
922 浏览 0 评论
12394 浏览 31 评论
GMT+8, 2025-2-24 11:28 , Processed in 0.443452 second(s), Total 35, Slave 30 queries .
