扫一扫,分享给好友
在测试程序中调用的是linux2.6中自带的transfer函数:
static void transfer(int fd) { int ret; uint8_t tx[] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x40, 0x00, 0x00, 0x00, 0x00, 0x95, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xDE, 0xAD, 0xBE, 0xEF, 0xBA, 0xAD, 0xF0, 0x0D, }; uint8_t rx[ARRAY_SIZE(tx)] = {0, }; struct spi_ioc_transfer tr = { .tx_buf = (unsigned long)tx, .rx_buf = (unsigned long)rx, .len = ARRAY_SIZE(tx), .delay_usecs = delay, .speed_hz = speed, .bits_per_word = bits, }; ret = ioctl(fd, SPI_IOC_MESSAGE(1), &tr); if (ret == 1) pabort("can't send spi message"); for (ret = 0; ret < ARRAY_SIZE(tx); ret++) { if (!(ret % 6)) puts(""); printf("%.2X ", rx[ret]); } puts(""); } 在这里我调用这个函数循环的传一个地址,然后再传一个数据。 当我短接mosi和miso时,数据返回正常,但是一旦接上外设,返回的数据都是0xff。 当我想外设先传控制数据初始化外设,然后再循环传一个数据时,结果一样都是0xff 求高手解答!! |
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之wifi
1527 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之USB_OTG
819 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之ADC
1012 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之CSI
1933 浏览 0 评论
迅为RK3568开发板篇Openharmony配置HDF控制UART-实操-HDF驱动配置UART-修改HCS配置
1804 浏览 0 评论
GMT+8, 2025-3-5 00:51 , Processed in 0.425012 second(s), Total 38, Slave 33 queries .
