我是www.eepeople.com 猎头顾问Nicole Li。www.eepeople.com 是面向电子/电气工程行业人员的人脉社交网站。现在飞利浦电子(中国)有限公司急招一名Lighting-Senior Reliability Engineer,具体信息如下: 职位名称 Lighting-Senior Reliability Engineer 公司 飞利浦电子(中国)有限公司 职能部门 研发中心/R&D 职位所在城市 Shanghai 职位所需经验 3 years 职位描述 PRINCIPAL ACCOUNTABILITIES ·As a member in produce design team, reliability engineer is to make sure that reliability is designed into the product and qualified. - Responsible for the reliability requirements definition, management and realization. - Translate the needs from customer and marketing into the reliability requirement and design guideline, and setup the qualification plan to evaluate the product design with reliability tools - Report the reliability test result and failure, conduct risk assessment for the failure and impact of product lifetime and reliability - Collect and analysis data from field return and lifetest to improve the reliability in product design - Building up and maintaining a complete set of Failure Analysis, using both internally as well as externally available resource. - Implement the design for reliability in projects development. ·Maintain a network of Philips Lighting competence center contact persons in the field of LED Lighting, i.e. the reliability council in Europe and the USA. ·Support quality team to handle complaint and solve problems found in mass production. ·Build up own experience about LED lamp reliability to make a reliability design rule for components and system. ·Keeps abreast of technical developments in own field through study of the literature and technical contacts. ·Define good and reasonable reliability tests for each new product & keep updated about new reliability method 职位所需技能 COMPETENCIES/JOB REQUIREMENTS ·Master Degree in the area of physics, electronics and material ·3 years of experience in design for quality and reliability, e.g. derating, HALT and international reliability standards, e.g. MIL/IEC standards Experience with lighting and LEDs is a preferred. ·Be familiar with reliability analysis tools, e.g. Reliasoft Weibull++ and ALTA ·Good at statistical analysis and reliability modeling ·Be familiar with electronic components and SMT process and qualification ·Be familiar with optical, electrical, and thermo-mechanical design requirement and realization ·Good command of the English language in both speaking and writing is a must. ·Good communication skill and team player ·Be good at problem solving and independent thinking ·Fast learn and willing to share 除上述职位外, www.eepeople.com 还有更多类似威廉希尔官方网站
职位。 有意者请将中英文简历发至这邮箱: nicoleli_nl01@163.com, 也可在www.eepeople.com上找到我并在线联系。 |
6 个讨论
GMT+8, 2024-12-26 09:21 , Processed in 0.445392 second(s), Total 46, Slave 38 queries .
