1、 层压板:laminate 2、 基材:base material 3、 增强板材:stiffener material 4、 铜箔面:copper-clad surface 5、 去铜箔面:foil removal surface 6、 层压板面:unclad laminate surface 7、 基膜面:base film surface 8、 胶粘剂面:adhesive faec 9、 原始光洁面:plate finish 10、 粗面:matt finish 11、 纵向:length wise direction 12、 模向:cross wise direction 13、 剪切板:cut to size panel 14、 覆金属箔基材:metal-clad bade material 15、 覆铜箔层压板:copper-clad laminate (ccl) 16、 单面覆铜箔层压板:single-sided copper-clad laminate 17、 双面覆铜箔层压板:double-sided copper-clad laminate 18、 复合层压板:composite laminate 19、 薄层压板:thin laminate 20、 金属芯覆铜箔层压板:metal core copper-clad laminate 21、 金属基覆铜层压板:metal base copper-clad laminate 22、 挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film 23、 基体材料:basis material 24、 预浸材料:prepreg 25、 粘结片:bonding sheet 26、 预浸粘结片:preimpregnated bonding sheer 27、 环氧玻璃基板:epoxy glass substrate 28、 加成法用层压板:laminate for additive process 29、 预制内层覆箔板:mass lamination panel 30、 内层芯板:core material 31、 催化板材:catalyzed board ,coated catalyzed laminate 32、 涂胶催化层压板:adhesive-coated catalyzed laminate 33、 涂胶无催层压板:adhesive-coated uncatalyzed laminate 34、 粘结层:bonding layer 35、 涂胶粘剂绝缘薄膜:adhesive coated dielectric film 36、 无支撑胶粘剂膜:unsupported adhesive film 37、 覆盖层:cover layer (cover lay) 38、 环氧玻璃布玻璃纤维复合覆铜箔板: epoxide non woven/woven glass reinforced copper-clad laminates 39、 聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad laminates 40、 聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad laminates 41、 双马来酰亚胺三嗪环氧玻璃布覆铜箔板: bismaleimide/triazine/epoxide woven glass fabric copper-clad lamimates 42、 环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric copper-clad laminates 43、 聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad laminates 44、 超薄型层压板:ultra thin laminate 45、 陶瓷基覆铜箔板:ceramics base copper-clad laminates 46、 紫外线阻挡型覆铜箔板:uv blocking copper-clad laminates 47、 酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad laminates(phenolic/paper ccl) 48、 环氧纸质覆铜箔板:epoxide cellulose paper copper-clad laminates (epoxy/paper ccl) 49、 环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad laminates 50、 环氧玻璃布纸复合覆铜箔板: epoxide cellulose paper core, glass cloth surfaces copper-clad laminates 51、 粘结膜:film adhesive http://www.hqPCB.com |
你正在撰写讨论
9123 浏览 0 评论
7126 浏览 0 评论
7816 浏览 0 评论
5336 浏览 2 评论
7990 浏览 2 评论
GMT+8, 2025-2-24 19:32 , Processed in 0.733393 second(s), Total 42, Slave 34 queries .
