都是标准的C代码,其他平台你直接移植就是了。
PCM3168A是一款四通道模拟输入和输出的音频编解码器,支持I2S和SPI接口。以下是一份基于SPI接口的PCM3168A初始化及应用的使用例程。这个例程假设你已经配置好了SPI接口。
1. 初始化SPI接口: 首先,你需要初始化SPI接口。这通常涉及到设置SPI的时钟速率、CPOL、CPHA等参数。以下是一个示例代码: ```c #include #include static struct spi_device *pcm3168_spi; static int __init pcm3168_init(void) { struct spi_master *master; struct spi_board_info info; int ret; master = spi_busnum_to_master(0); if (!master) { printk(KERN_ERR "PCM3168: No SPI master foundn"); return -ENODEV; } memset(&info, 0, sizeof(info)); info.modalias = "pcm3168"; info.bus_num = 0; info.chip_select = 0; info.max_speed_hz = 1000000; // 1 MHz info.mode = SPI_MODE_0; pcm3168_spi = spi_new_device(master, &info); if (!pcm3168_spi) { printk(KERN_ERR "PCM3168: Failed to add devicen"); return -ENODEV; } ret = spi_setup(pcm3168_spi); if (ret < 0) { printk(KERN_ERR "PCM3168: Failed to setup SPI devicen"); return ret; } return 0; } static void __exit pcm3168_exit(void) { spi_unregister_device(pcm3168_spi); } module_init(pcm3168_init); module_exit(pcm3168_exit); MODULE_LICENSE("GPL"); MODULE_AUTHOR("Your Name"); MODULE_DESCRIPTION("PCM3168A SPI driver"); ``` 2. 初始化PCM3168A: 接下来,你需要初始化PCM3168A。这通常涉及到发送一些初始化命令,以配置音频格式、采样率等参数。以下是一个示例代码: ```c #include #include #define PCM3168_REG_FORMAT_CONTROL 0x00 #define PCM3168_REG_POWER_CONTROL 0x02 #define PCM3168_REG_FILTER_CONTROL 0x04 #define PCM3168_REG_CLOCK_CONTROL 0x06 #define PCM3168_REG_INTERFACE_CONTROL 0x08 #define PCM3168_REG_MISC_CONTROL 0x0A static int pcm3168_write_reg(struct spi_device *spi, u8 reg, u16 value) { u8 buf[3] = {reg, value & 0xFF, (value >> 8) & 0xFF}; return spi_write(spi, buf, sizeof(buf)); } static int pcm3168_init_device(struct spi_device *spi) { int ret; // Set audio format to 24-bit I2S ret = pcm3168_write_reg(spi, PCM3168_REG_FORMAT_CONTROL, 0x0000); if (ret < 0) { return ret; } // Enable all channels ret = pcm3168_write_reg(spi, PCM3168_REG_POWER_CONTROL, 0x0F0F); if (ret < 0) { return ret; } // Configure filter settings ret = pcm3168_write_reg(spi, PCM3168_REG_FILTER_CONTROL, 0x0000); if (ret < 0) { return ret; } // Configure clock settings ret = pcm3168_write_reg(spi, PCM3168_REG_CLOCK_CONTROL, 0x0000); if (ret < 0) { return ret; } // Configure interface settings ret = pcm3168_write_reg(spi, PCM3168_REG_INTERFACE_CONTROL, 0x0000); if (ret < 0) { return ret; } // Configure miscellaneous settings ret = pcm3168_write_reg(spi, PCM3168_REG_MISC_CONTROL, 0x0000); if (ret < 0) { return ret; } return 0; } ``` 3. 配置PCM3168A时隙: PCM3168A的时隙配置取决于你的音频格式和采样率。通常,你需要根据这些参数计算时隙大小。以下是一个示例代码: ```c static int pcm3168_config_tsi(struct spi_device *spi, int sample_rate, int bits_per_sample) { int ret; u16 format_control; // Calculate format control value based on sample rate and bits per sample format_control = (sample_rate == 48000) ? |
586 浏览 1 评论
427 浏览 1 评论
620 浏览 2 评论
910 浏览 3 评论
709 浏览 1 评论
193浏览 29评论
1155浏览 23评论
323浏览 20评论
286浏览 14评论
135浏览 13评论
GMT+8, 2025-2-3 09:16 , Processed in 0.698739 second(s), Total 48, Slave 43 queries .
