我们有个案子使用的是TLV320AIC3104,原理图如下:
使用的是MIC1RP/MIC1RM通道,以下是开始录音时所有寄存器的值: [ 8580.149952] reg:0,ret:0x0 [ 8580.155532] reg:1,ret:0x0 [ 8580.160671] reg:2,ret:0x0 [ 8580.165799] reg:3,ret:0x91 [ 8580.171010] reg:4,ret:0x1c [ 8580.176221] reg:5,ret:0x36 [ 8580.181432] reg:6,ret:0xb0 [ 8580.186805] reg:7,ret:0x8a [ 8580.192016] reg:8,ret:0x0 [ 8580.197140] reg:9,ret:0x0 [ 8580.203640] reg:10,ret:0x0 [ 8580.210241] reg:11,ret:0x1 [ 8580.216294] reg:12,ret:0x0 [ 8580.221505] reg:13,ret:0x0 [ 8580.226716] reg:14,ret:0x0 [ 8580.231926] reg:15,ret:0x6e [ 8580.237224] reg:16,ret:0x6e [ 8580.242524] reg:17,ret:0xff [ 8580.247821] reg:18,ret:0xff [ 8580.253118] reg:19,ret:0x78 [ 8580.258414] reg:20,ret:0x78 [ 8580.263710] reg:21,ret:0x78 [ 8580.269170] reg:22,ret:0x4 [ 8580.274380] reg:23,ret:0x78 [ 8580.279678] reg:24,ret:0x78 [ 8580.286352] reg:25,ret:0x40 [ 8580.293025] reg:26,ret:0x0 [ 8580.299091] reg:27,ret:0xfe [ 8580.304388] reg:28,ret:0x0 [ 8580.309598] reg:29,ret:0x0 [ 8580.314809] reg:30,ret:0xfe [ 8580.320106] reg:31,ret:0x0 [ 8580.325316] reg:32,ret:0x18 [ 8580.330613] reg:33,ret:0x18 [ 8580.335910] reg:34,ret:0x0 [ 8580.341121] reg:35,ret:0x0 [ 8580.346331] reg:36,ret:0x0 [ 8580.351542] reg:37,ret:0x0 [ 8580.356915] reg:38,ret:0x0 [ 8580.362125] reg:39,ret:0x0 [ 8580.367336] reg:40,ret:0x0 [ 8580.373923] reg:41,ret:0x0 [ 8580.380509] reg:42,ret:0x0 [ 8580.386574] reg:43,ret:0xaf [ 8580.391871] reg:44,ret:0xaf [ 8580.397168] reg:45,ret:0x0 [ 8580.402379] reg:46,ret:0x2f [ 8580.407676] reg:47,ret:0xaf [ 8580.412973] reg:48,ret:0x0 [ 8580.418187] reg:49,ret:0x0 [ 8580.424944] reg:50,ret:0x0 [ 8580.431530] reg:51,ret:0xc [ 8580.437596] reg:52,ret:0x0 [ 8580.442807] reg:53,ret:0x2f [ 8580.448104] reg:54,ret:0xaf [ 8580.453400] reg:55,ret:0x0 [ 8580.458611] reg:56,ret:0x0 [ 8580.463821] reg:57,ret:0x0 [ 8580.469031] reg:58,ret:0xc [ 8580.474241] reg:59,ret:0x0 [ 8580.479451] reg:60,ret:0x0 [ 8580.484662] reg:61,ret:0x0 [ 8580.489872] reg:62,ret:0x0 [ 8580.495082] reg:63,ret:0x2f [ 8580.500378] reg:64,ret:0xaf [ 8580.505676] reg:65,ret:0xc [ 8580.510886] reg:66,ret:0x0 [ 8580.516097] reg:67,ret:0x0 [ 8580.521308] reg:68,ret:0x0 [ 8580.526681] reg:69,ret:0x0 [ 8580.531891] reg:70,ret:0x2f [ 8580.537188] reg:71,ret:0xaf [ 8580.543861] reg:72,ret:0xc [ 8580.550448] reg:73,ret:0x0 [ 8580.556520] reg:74,ret:0x0 [ 8580.561730] reg:75,ret:0x0 [ 8580.566941] reg:76,ret:0x0 [ 8580.572151] reg:77,ret:0x0 [ 8580.577361] reg:78,ret:0x0 [ 8580.582570] reg:79,ret:0x0 [ 8580.587781] reg:80,ret:0x0 [ 8580.592991] reg:81,ret:0x2f [ 8580.598287] reg:82,ret:0x80 [ 8580.603584] reg:83,ret:0x0 [ 8580.608794] reg:84,ret:0x0 [ 8580.614168] reg:85,ret:0x0 [ 8580.619378] reg:86,ret:0x8 [ 8580.624589] reg:87,ret:0x0 [ 8580.631175] reg:88,ret:0x0 [ 8580.637762] reg:89,ret:0x0 [ 8580.643828] reg:90,ret:0x0 [ 8580.649039] reg:91,ret:0x2f [ 8580.654336] reg:92,ret:0x80 [ 8580.659632] reg:93,ret:0x8 [ 8580.664843] reg:94,ret:0x0 [ 8580.670053] reg:95,ret:0x0 [ 8580.675268] reg:96,ret:0x0 [ 8580.680479] reg:97,ret:0x0 [ 8580.685689] reg:98,ret:0x0 [ 8580.690900] reg:99,ret:0x0 [ 8580.696273] reg:100,ret:0x0 [ 8580.701569] reg:101,ret:0x0 [ 8580.706866] reg:102,ret:0x2 [ 8580.713540] reg:103,ret:0x0 [ 8580.720213] reg:104,ret:0x0 [ 8580.726366] reg:105,ret:0x0 [ 8580.731663] reg:106,ret:0x0 [ 8580.736960] reg:107,ret:0x0 [ 8580.742257] reg:108,ret:0x0 [ 8580.747552] reg:109,ret:0x0 |
TLV320AIC3104录音噪声过大可能有以下几个原因:
1. 电源干扰:电源不稳定或者电源滤波不良可能导致噪声。请检查电源电路,确保电源稳定且滤波良好。 2. 地线问题:地线连接不良或者地线环路可能导致噪声。请检查地线连接,确保地线连接良好且没有环路。 3. 模拟输入信号干扰:模拟输入信号受到干扰可能导致噪声。请检查模拟输入信号路径,确保信号路径干净且没有干扰。 4. 麦克风问题:麦克风本身可能存在问题,导致噪声。请尝试更换麦克风,看是否能解决问题。 5. 寄存器设置问题:寄存器设置不当可能导致噪声。根据您提供的寄存器值,以下是一些建议: a. 寄存器3(AIC3104_PAGE0):0x91,表示当前页为0,这是正确的。 b. 寄存器4(AIC3104_RESET):0x1c,表示复位寄存器。请确保复位操作正确执行。 c. 寄存器5(AIC3104_CLOCK):0x36,表示时钟设置。请检查时钟设置是否正确。 d. 寄存器6(AIC3104_INTERFACE):0xb0,表示接口设置。请检查接口设置是否正确。 e. 寄存器7(AIC3104_POWER_MANAGEMENT):0x8a,表示电源管理设置。请检查电源管理设置是否正确。 f. 寄存器11(AIC3104_MIC):0x1,表示麦克风增益设置。请检查麦克风增益设置是否合适。 6. 数字滤波器设置问题:数字滤波器设置不当可能导致噪声。请检查数字滤波器设置,确保设置正确。 综上所述,要解决TLV320AIC3104录音噪声过大的问题,需要从电源、地线、模拟输入信号、麦克风、寄存器设置和数字滤波器等方面进行排查和调整。希望这些建议对您有所帮助。 |
832 浏览 1 评论
1071 浏览 0 评论
620 浏览 1 评论
469 浏览 1 评论
663 浏览 2 评论
265浏览 29评论
1228浏览 23评论
360浏览 20评论
337浏览 14评论
204浏览 13评论
GMT+8, 2025-3-7 00:20 , Processed in 0.812975 second(s), Total 76, Slave 60 queries .
