最近基于STM32H743处理器进行以太网移植,mpu按照art-pi配置是可以,以太网初始化正常,且可以ping通,此时AXI SRAM设置为 write-through 和 no write allocate,如下:
MPU_InitStruct.Enable = MPU_REGION_ENABLE; MPU_InitStruct.BaseAddress = 0x24000000; MPU_InitStruct.Size = MPU_REGION_SIZE_512KB; MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS; MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE; MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE; MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE; MPU_InitStruct.Number = MPU_REGION_NUMBER0; MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0; MPU_InitStruct.SubRegionDisable = 0X00; MPU_InitStruct.DisableExec = MPU_INSTRUCtiON_ACCESS_ENABLE; 尝试使用其它cache策略,出现一些奇怪的现象,表现为栈溢出或者直接进入hardfault,如下两种配置都存在问题,第一种如下, write-back 和 write allocate MPU_InitStruct.Enable = MPU_REGION_ENABLE; MPU_InitStruct.BaseAddress = 0x24000000; MPU_InitStruct.Size = MPU_REGION_SIZE_512KB; MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS; MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE; MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE; MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE; MPU_InitStruct.Number = MPU_REGION_NUMBER0; MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL1; MPU_InitStruct.SubRegionDisable = 0X00; MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE; 第二种如下, write-back 和 no write allocate MPU_InitStruct.Enable = MPU_REGION_ENABLE; MPU_InitStruct.BaseAddress = 0x24000000; MPU_InitStruct.Size = MPU_REGION_SIZE_512KB; MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS; MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE; MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE; MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE; MPU_InitStruct.Number = MPU_REGION_NUMBER0; MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0; MPU_InitStruct.SubRegionDisable = 0X00; MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE; 有大神了解相关内容的吗?给简单介绍一些为什么会出现这种状况,似乎只要设置成MPU_ACCESS_BUFFERABLE就有问题。 |
159个成员聚集在这个小组
加入小组【Vision Board创客营连载体验】基于RA8D1-Vision Board的自动路径规划小车
962 浏览 0 评论
【Vision Board创客营连载体验】基于Vision Board的垃圾分类
1399 浏览 0 评论
【Vision Board创客营连载体验】使用 Vision Board 做一个 UVC Camera
1064 浏览 0 评论
【Vision Board创客营连载体验】TinyMaix进行手写数字识别
1295 浏览 0 评论
【Vision Board创客营连载体验】RA8D1-Vision Board使用7寸屏设置为RGB666大端模式模式成功显示摄像头图案
1376 浏览 0 评论
GMT+8, 2025-3-4 12:40 , Processed in 0.683701 second(s), Total 44, Slave 37 queries .
