在使用rtthread settings配置完i2c后,与pca9535pw的第一通讯报错,不知道为什么?代码如下:
main: /* 初始化PCA9535PW */ if (pca9535pw_init(I2C_BUS_NAME) != RT_EOK) { return 0; } rt_thread_delay(1000); while(pca9535pw_write_reg(PCA9535PW_CONFIG_PORT_0, 0x00) != RT_EOK) { rt_kprintf("Failed to configure Port 0\n"); } while(pca9535pw_write_reg(PCA9535PW_CONFIG_PORT_1, 0x00) != RT_EOK) { rt_kprintf("Failed to configure Port 1\n"); } while (1) { /* 打开特定引脚 */ if (pca9535pw_write_reg(PCA9535PW_OUTPUT_PORT_0, 0x01) != RT_EOK) { rt_kprintf("Failed to write to Output Port 0\n"); } if (pca9535pw_write_reg(PCA9535PW_OUTPUT_PORT_1, 0x06) != RT_EOK) { rt_kprintf("Failed to write to Output Port 1\n"); } rt_thread_mdelay(500); /* 读取输入引脚状态 */ if (pca9535pw_read_reg(PCA9535PW_INPUT_PORT_0, &value) == RT_EOK) { rt_kprintf("Input Port 0: 0x%02X\n", value); } else { rt_kprintf("Failed to read from Input Port 0\n"); } if (pca9535pw_read_reg(PCA9535PW_INPUT_PORT_1, &value) == RT_EOK) { rt_kprintf("Input Port 1: 0x%02X\n", value); } else { rt_kprintf("Failed to read from Input Port 1\n"); } rt_thread_mdelay(1000); } pca9535pw.c: #include "pca9535pw.h" #define PCA9535PW_ADDRESS 0x20 // PCA9535PW的I2C地址 static struct rt_i2c_bus_device *i2c_bus = RT_NULL; /* 初始化I2C总线 */ rt_err_t pca9535pw_init(const char *i2c_bus_name) { i2c_bus = (struct rt_i2c_bus_device *)rt_device_find(i2c_bus_name); if (i2c_bus == RT_NULL) { rt_kprintf("I2C bus %s not found!\n", i2c_bus_name); return -RT_ERROR; } rt_kprintf("I2C bus %s found!\n", i2c_bus_name); return RT_EOK; } /* 写寄存器函数 */ rt_err_t pca9535pw_write_reg(rt_uint8_t reg, rt_uint8_t value) { struct rt_i2c_msg msgs[2]; rt_uint8_t buffer[2]; buffer[0] = reg; buffer[1] = value; msgs[0].addr = PCA9535PW_ADDRESS; msgs[0].flags = RT_I2C_WR; msgs[0].buf = buffer; msgs[0].len = 2; if (rt_i2c_transfer(i2c_bus, msgs, 1) == 1) { return RT_EOK; } else { return -RT_ERROR; } } /* 读寄存器函数 */ rt_err_t pca9535pw_read_reg(rt_uint8_t reg, rt_uint8_t *value) { struct rt_i2c_msg msgs[2]; msgs[0].addr = PCA9535PW_ADDRESS; msgs[0].flags = RT_I2C_WR; msgs[0].buf = ® msgs[0].len = 1; msgs[1].addr = PCA9535PW_ADDRESS; msgs[1].flags = RT_I2C_RD; msgs[1].buf = value; msgs[1].len = 1; if (rt_i2c_transfer(i2c_bus, msgs, 2) == 2) { return RT_EOK; } else { return -RT_ERROR; } } |
首先,我们需要分析代码和可能的问题。以下是代码的关键部分:
1. 初始化PCA9535PW:`if (pca9535pw_init(I2C_BUS_NAME) != RT_EOK) { return 0; }` 2. 延时1秒:`rt_thread_delay(1000);` 3. 尝试写入PCA9535PW寄存器:`while(pca9535pw_write_reg(PCA9535PW_CONFIG_PORT_0, 0x00) != RT_EOK)` 根据这些信息,我们可以逐步检查可能的问题: 1. **I2C配置问题**:确保I2C总线配置正确,包括I2C设备的地址、时钟速率等。检查`I2C_BUS_NAME`是否正确设置。 2. **PCA9535PW初始化问题**:检查`pca9535pw_init`函数是否正确实现了初始化逻辑,包括设置I2C设备地址等。 3. **延时问题**:虽然延时1秒通常足够让设备稳定,但可以尝试减少延时时间,看看是否会影响通信结果。 4. **写入寄存器问题**:检查`pca9535pw_write_reg`函数是否正确实现了写入逻辑。确保寄存器地址和数据正确。 5. **错误处理**:在`while`循环中,如果写入失败,应该添加错误处理逻辑,例如打印错误信息或重试。 6. **硬件连接问题**:检查硬件连接是否正确,包括I2C数据线、电源线等。 7. **PCA9535PW设备问题**:确保PCA9535PW设备本身没有问题,可以尝试使用其他设备或在其他环境中测试。 |
159个成员聚集在这个小组
加入小组【Vision Board创客营连载体验】基于RA8D1-Vision Board的自动路径规划小车
938 浏览 0 评论
【Vision Board创客营连载体验】基于Vision Board的垃圾分类
1356 浏览 0 评论
【Vision Board创客营连载体验】使用 Vision Board 做一个 UVC Camera
1018 浏览 0 评论
【Vision Board创客营连载体验】TinyMaix进行手写数字识别
1263 浏览 0 评论
【Vision Board创客营连载体验】RA8D1-Vision Board使用7寸屏设置为RGB666大端模式模式成功显示摄像头图案
1285 浏览 0 评论
GMT+8, 2025-2-4 09:48 , Processed in 0.601209 second(s), Total 79, Slave 62 queries .
