电子发烧友论坛|
当我想要在eclipse的工程下创建另一个ide的工程时,执行make ewarm TOOLCAHIN=IAR出错,报错信息如下:
~/mtw/FreeRTOS_Blinky> make ewarm TOOLCHAIN=IAR Tools Directory: C:/Users/Administrator/ModusToolbox/tools_3.2 Searching installed tools in progress... /bin/bash: line 1: C:/Users/Administrator/mtw/FreeRTOS_Blinky/build/mtbquery-info.mk: cannot overwrite existing file C:/Users/Administrator/ModusToolbox/tools_3.2/make/core_version3/query-v3.mk:71: *** Searching installed tools failed with error code: 1. Stop. 同样的执行make help等命令也是一样的问题。 附加信息: 1 环境变量已设置 ~/mtw/FreeRTOS_Blinky> echo $CY_TOOLS_PATHS C:/Users/Administrator/ModusToolbox/tools_3.2 2 make 和bash信息 ~/mtw/FreeRTOS_Blinky> make --version GNU Make 4.4.1 Built for x86_64-pc-cygwin Copyright (C) 1988-2023 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <https://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. ~/mtw/FreeRTOS_Blinky> ~/mtw/FreeRTOS_Blinky> bash --version GNU bash, version 5.2.21(1)-release (x86_64-pc-cygwin) Copyright (C) 2022 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software; you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. |
根据您提供的错误信息,这个问题可能是由于在执行make命令时,文件mtbquery-info.mk已经存在,导致无法覆盖。为了解决这个问题,请按照以下步骤操作:
1. 首先,打开终端并导航到您的工程目录。例如: ``` cd ~/mtw/FreeRTOS_Blinky ``` 2. 检查mtbquery-info.mk文件是否存在。如果存在,请删除它。您可以使用以下命令: ``` rm build/mtbquery-info.mk ``` 3. 确保您的环境变量设置正确。检查您的PATH变量是否包含ModusToolbox工具的路径。您可以使用以下命令查看当前的PATH变量: ``` echo $PATH ``` 4. 如果PATH变量没有包含ModusToolbox工具的路径,请将其添加到PATH中。例如,如果您的工具安装在`C:/Users/Administrator/ModusToolbox/tools_3.2`,您可以使用以下命令: ``` export PATH=$PATH:/C:/Users/Administrator/ModusToolbox/tools_3.2/bin ``` 5. 现在,再次尝试执行make命令: ``` make ewarm TOOLCHAIN=IAR ``` 6. 如果问题仍然存在,请检查您的makefile和环境设置,确保它们与IAR工具链兼容。 通过以上步骤,您应该能够解决执行make ewarm TOOLCHAIN=IAR时出现的错误。如果问题仍然存在,请提供更多详细信息,以便我们能够更好地帮助您。 |
请教个XMC1404调试串口接收时为什么一直无法接收数据的问题
362 浏览 0 评论
TLE9879_BLDC电机启动需要用手拨一下才能转动,怎么解决?
6268 浏览 2 评论
4106 浏览 9 评论
请问TLE5012B_E1000 启动后为什么位置不能正确获取
3632 浏览 9 评论
1231 浏览 8 评论
457浏览 2评论
270浏览 2评论
376浏览 2评论
6272浏览 2评论
如果是打开已有的dave工程,怎么查看这个工程选择的mcu型号?
456浏览 2评论
GMT+8, 2024-12-23 14:05 , Processed in 0.672740 second(s), Total 81, Slave 64 queries .
