使用的是esp32官方的Wi-Fi例程
一直连接不上Wi-Fi 日志: ESP-ROM:esp8684-api2-20220127 Build:Jan 27 2022 rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT) SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd5c80,len:0x16c4 load:0x403acb70,len:0x974 load:0x403aeb70,len:0x2988 entry 0x403acb70 I (21) boot: ESP-IDF v5.1.2-dirty 2nd stage bootloader I (21) boot: compile time May 30 2024 15:41:17 I (21) boot: chip revision: v1.0 I (24) boot.esp32c2: MMU Page Size : 64K I (29) boot.esp32c2: SPI Speed : 60MHz I (34) boot.esp32c2: SPI Mode : DIO I (39) boot.esp32c2: SPI Flash Size : 4MB I (43) boot: Enabling RNG early entropy source... I (49) boot: Partition Table: I (52) boot: ## Label Usage Type ST Offset Length I (60) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (67) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (75) boot: 2 factory factory app 00 00 00010000 00100000 I (82) boot: End of partition table I (86) esp_image: segment 0: paddr=00010020 vaddr=3c080020 size=1dfb8h (122808) map I (122) esp_image: segment 1: paddr=0002dfe0 vaddr=3fcace30 size=02038h ( 8248) load I (125) esp_image: segment 2: paddr=00030020 vaddr=42000020 size=73b94h (474004) map I (234) esp_image: segment 3: paddr=000a3bbc vaddr=3fcaee68 size=00a98h ( 2712) load I (235) esp_image: segment 4: paddr=000a465c vaddr=40380000 size=0ce30h ( 52784) load I (257) boot: Loaded app from partition at offset 0x10000 I (257) boot: Disabling RNG early entropy source... I (269) cpu_start: Unicore app I (269) cpu_start: Pro cpu up. I (278) cpu_start: Pro cpu start user code I (278) cpu_start: cpu freq: 120000000 Hz I (278) cpu_start: Application information: I (281) cpu_start: Project name: blink I (285) cpu_start: App version: 1 I (290) cpu_start: Compile time: May 30 2024 15:41:11 I (296) cpu_start: ELF file SHA256: 7c86b3cb80bcc7af... I (302) cpu_start: ESP-IDF: v5.1.2-dirty I (307) cpu_start: Min chip rev: v1.0 I (312) cpu_start: Max chip rev: v1.99 I (317) cpu_start: Chip rev: v1.0 I (322) heap_init: Initializing. RAM available for dynamic allocation: I (329) heap_init: At 3FCB36F0 len 00029480 (165 KiB): D/IRAM I (335) heap_init: At 3FCDCB70 len 0000294C (10 KiB): STACK/DRAM I (343) spi_flash: detected chip: gd I (346) spi_flash: flash io: dio I (350) sleep: Configure to isolate all GPIO pins in sleep state I (357) sleep: Enable automatic switching of GPIO sleep configuration I (364) coexist: coex firmware version: b6d5e8c I (369) coexist: coexist rom version de8c800 I (374) app_start: Starting scheduler on CPU0 I (379) main_task: Started on CPU0 I (379) main_task: Calling app_main() I (389) wifi station: ESP_WIFI_MODE_STA I (399) pp: pp rom version: de8c800 I (399) net80211: net80211 rom version: de8c800 I (409) wifi:wifi driver task: 3fcb994c, prio:23, stack:6144, core=0 I (409) wifi:wifi firmware version: 91b9630 I (409) wifi:wifi certification version: v7.0 I (409) wifi:config NVS flash: enabled I (419) wifi:config nano formating: enabled I (419) wifi:Init data frame dynamic rx buffer num: 32 I (419) wifi:Init static rx mgmt buffer num: 5 I (429) wifi:Init management short buffer num: 32 I (429) wifi:Init dynamic tx buffer num: 32 I (439) wifi:Init static tx FG buffer num: 2 I (439) wifi:Init static rx buffer size: 1600 I (439) wifi:Init static rx buffer num: 10 I (449) wifi:Init dynamic rx buffer num: 32 I (449) wifi_init: rx ba win: 6 I (459) wifi_init: tcpip mbox: 32 I (459) wifi_init: udp mbox: 6 I (459) wifi_init: tcp mbox: 6 I (469) wifi_init: tcp tx win: 5744 I (469) wifi_init: tcp rx win: 5744 I (479) wifi_init: tcp mss: 1440 I (479) wifi_init: WiFi IRAM OP enabled I (479) wifi_init: WiFi RX IRAM OP enabled I (489) phy_init: phy_version 270,39d177a,Oct 13 2023,16:18:10 I (529) wifi:mode : sta (08:3a:8d:65:51:00) I (529) wifi:enable tsf I (529) wifi station: wifi_init_sta 完成 I (2939) wifi station: 重试连接到 AP I (2939) wifi station: 连接到 AP 失败 I (5349) wifi station: 重试连接到 AP I (5349) wifi station: 连接到 AP 失败 I (7759) wifi station: 重试连接到 AP I (7759) wifi station: 连接到 AP 失败 I (10159) wifi station: 重试连接到 AP I (10159) wifi station: 连接到 AP 失败 I (12569) wifi station: 重试连接到 AP I (12569) wifi station: 连接到 AP 失败 I (14979) wifi station: 连接到 AP 失败 I (14979) wifi station: 无法连接到 SSID:1908A, 密码:GXFC2021 I (14979) main_task: Returned from app_main() |
根据您提供的信息,您的ESP32设备正在使用官方的Wi-Fi例程,但无法连接到Wi-Fi。以下是一些建议来解决这个问题:
1. 检查Wi-Fi配置:确保您在代码中设置了正确的Wi-Fi SSID和密码。请检查以下代码片段是否正确填写了您的Wi-Fi网络信息: ```c const char *ssid = "您的Wi-Fi名称"; const char *password = "您的Wi-Fi密码"; ``` 2. 检查Wi-Fi模块:确保您的ESP32设备上的Wi-Fi模块正常工作。您可以尝试使用其他Wi-Fi网络或使用其他设备连接到相同的Wi-Fi网络,以排除网络问题。 3. 检查电源:确保ESP32设备的电源供应稳定,因为不稳定的电源可能会影响Wi-Fi连接。 4. 更新ESP-IDF:您提到的ESP-IDF版本是v5.1.2-dirty,这可能表示您的ESP-IDF版本有问题。建议您更新到最新的稳定版本。您可以按照以下步骤进行更新: a. 打开命令行工具。 b. 输入 `cd ~/esp/esp-idf`(假设您的ESP-IDF安装在默认位置)。 c. 输入 `git pull` 以获取最新版本。 d. 输入 `./install.sh` 以安装最新版本。 5. 检查代码:确保您的代码没有错误或遗漏。您可以从ESP32官方示例中获取Wi-Fi连接示例代码,以确保您的代码正确无误。 6. 检查日志:您提供的日志信息似乎不完整。请提供更多日志信息,以便我们更好地了解问题所在。 7. 重置设备:尝试重置您的ESP32设备,然后重新上传代码并尝试连接Wi-Fi。 8. 检查硬件:如果以上方法都无法解决问题,可能是您的ESP32设备硬件存在问题。您可以尝试更换另一块ESP32设备进行测试。 希望这些建议能帮助您解决问题。如果问题仍然存在,请提供更多详细信息,以便我们为您提供更具体的帮助。 |
208个成员聚集在这个小组
加入小组508 浏览 1 评论
2080 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
421浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
214浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
240浏览 2评论
用AT+CIPSNTPCFG=1,8,\"cn.ntp.org.cn\",\"ntp.sjtu.edu.cn\"更新不了时间怎么处理?
639浏览 2评论
304浏览 2评论
GMT+8, 2025-3-28 09:08 , Processed in 0.721549 second(s), Total 45, Slave 39 queries .
