ESP32-LyraT V4.3烧进去dueros固件,机器一直重启,日志如下:
Rebooting... ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:6036 load:0x40078000,len:8812 load:0x40080400,len:6488 entry 0x40080734 [0;32mI (29) boot: ESP-IDF v3.2-103-g4aa1058e8-dirty 2nd stage bootloader[0m [0;32mI (29) boot: compile time 19:58:17[0m [0;32mI (29) boot: Enabling RNG early entropy source...[0m [0;32mI (35) boot: SPI Speed : 40MHz[0m [0;32mI (39) boot: SPI Mode : DIO[0m [0;32mI (43) boot: SPI Flash Size : 4MB[0m [0;32mI (47) boot: Partition Table:[0m [0;32mI (51) boot: ## Label Usage Type ST Offset Length[0m [0;32mI (58) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m [0;32mI (66) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m [0;32mI (73) boot: 2 factory factory app 00 00 00010000 00300000[0m [0;32mI (81) boot: End of partition table[0m [0;32mI (85) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x6decc (450252) map[0m [0;32mI (250) esp_image: segment 1: paddr=0x0007def4 vaddr=0x3ffb0000 size=0x0211c ( 8476) load[0m [0;32mI (253) esp_image: segment 2: paddr=0x00080018 vaddr=0x400d0018 size=0x128950 (1214800) map[0m [0;32mI (678) esp_image: segment 3: paddr=0x001a8970 vaddr=0x3ffb211c size=0x01a6c ( 6764) load[0m [0;32mI (681) esp_image: segment 4: paddr=0x001aa3e4 vaddr=0x40080000 size=0x00400 ( 1024) load[0m [0;32mI (685) esp_image: segment 5: paddr=0x001aa7ec vaddr=0x40080400 size=0x1771c ( 96028) load[0m [0;32mI (745) boot: Loaded app from partition at offset 0x10000[0m [0;32mI (745) boot: Disabling RNG early entropy source...[0m [0;31mE (746) spiram: Expected 4096KiB chip but found 8192KiB chip. Bailing out..[0m [0;31mE (753) cpu_start: Failed to init external RAM![0m abort() was called at PC 0x4008162 这个是不支持dueros,内存太小了吗? |
根据您提供的信息,您的ESP32-LyraT V4.3设备在烧录了dueros固件后一直重启。我们可以从以下几个方面来分析可能的原因:
1. **固件问题**:首先,需要确认您烧录的dueros固件是否适用于ESP32-LyraT V4.3设备。如果固件与硬件不兼容,可能会导致设备无法正常启动或频繁重启。 2. **烧录过程问题**:在烧录过程中,如果数据传输不完整或出现错误,可能会导致设备无法正常启动。请检查烧录过程中是否有任何异常,并尝试重新烧录固件。 3. **硬件问题**:设备硬件可能存在问题,如电源不稳定、焊接不良等。这可能导致设备在启动过程中出现问题,从而导致重启。检查硬件连接和焊接,确保一切正常。 4. **电源问题**:如果设备的电源不稳定或电压不符合要求,可能会导致设备无法正常启动。请检查电源供应是否稳定,并确保电压符合设备要求。 5. **软件配置问题**:在烧录固件时,可能需要进行一些软件配置,如设置正确的波特率、选择正确的烧录模式等。请检查您的配置是否正确。 6. **日志分析**:从您提供的日志来看,设备在启动过程中出现了重置(rst:0xc (SW_CPU_RESET))。这可能是由于软件或硬件问题导致的。您可以根据日志中的信息进一步分析问题所在。 综上所述,要解决设备一直重启的问题,您需要从固件、烧录过程、硬件、电源和软件配置等方面进行排查。希望这些信息对您有所帮助。 |
208个成员聚集在这个小组
加入小组508 浏览 1 评论
2080 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
421浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
214浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
240浏览 2评论
用AT+CIPSNTPCFG=1,8,\"cn.ntp.org.cn\",\"ntp.sjtu.edu.cn\"更新不了时间怎么处理?
641浏览 2评论
304浏览 2评论
GMT+8, 2025-3-28 11:49 , Processed in 0.804491 second(s), Total 45, Slave 39 queries .
