Config UART */
uart_config_t uart_config = { .baud_rate = config->baud_rate, .data_bits = config->data_bits, .parity = config->parity, .stop_bits = config->stop_bits, .flow_ctrl = UART_HW_FLOWCTRL_CTS_RTS , .rx_flow_ctrl_thresh = 122 //UART_FIFO_LEN -8 }; MODEM_CHECK(uart_param_config(esp_dte->uart_port, &uart_config) == ESP_OK, "config modem uart parameter failed", err_uart_config); if (config->flow_control == MODEM_FLOW_CONTROL_HW) { printf("[MODEM UART FLOW_CONTROL]:uart_set_pin,rts pin:%d,cts pin:%dn",config->uart_pins_rts,config->uart_pins_cts); res = uart_set_pin(esp_dte->uart_port, config->uart_pins_txd, config->uart_pins_rxd, config->uart_pins_rts, config->uart_pins_cts); } else { res = uart_set_pin(esp_dte->uart_port, config->uart_pins_txd, config->uart_pins_rxd, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE); } MODEM_CHECK(res == ESP_OK, "config modem uart gpio failed", err_uart_config); ----------------------------------------------------------------------------------------------------- 使用以上代码初始化了 4G 模块的串口,4G模块也已启用 RTS /CTS 硬件流控,并验证了4G模块的RTS/CTS是有效的;ppp拨号也成功建立了连接: [HOS MODEM] esp_modem_dte_send_cmd,port:1,cmd:ATD*99***1# [HOS MODEM] AT read: [HOS MODEM] AT read:CONNECT pppos netif created! addr=0x3f80bb3c Modem PPP Started Modem Connect to PPP Server ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ IP : 10.50.115.93 Netmask : 255.255.255.255 Gateway : 10.64.64.64 Name Server1: 183.230.126.225 Name Server2: 183.230.126.224 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [HOS IP ROUTE] add item :0,ip: 180.153.49.147, netmask:255.255.255.255, gw:10.64.64.64 [HOS IP ROUTE] add item :1,ip: 180.153.49.128, netmask:255.255.255.255, gw:10.64.64.64 应用程序运行在 Core1 上,CPU负荷比较高,大约在 95% 以上 用示波器看 RTS 引脚,可以看到 RTS 有变化, 但仍然频繁出现 : W (374153) esp-modem: HW FIFO Overflow W (374173) esp-modem: HW FIFO Overflow W (374953) esp-modem: HW FIFO Overflow W (374983) esp-modem: HW FIFO Overflow W (377023) esp-modem: HW FIFO Overflow W (377043) esp-modem: HW FIFO Overflow W (380103) esp-modem: HW FIFO Overflow W (386633) esp-modem: HW FIFO Overflow W (394133) esp-modem: HW FIFO Overflow W (400463) esp-modem: HW FIFO Overflow dhcps: send_nak>>udp_sendto result 0 W (426463) esp-modem: HW FIFO Overflow dhcps: send_nak>>udp_sendto result 0 dhcps: send_nak>>udp_sendto result 0 请问这个是说明原因呢? |
我也遇到这个问题了。主要问题在于中断处理不够快,FIFO的数据无法快速转换到Ring Buffer里。
可以通过设置menuconfig菜单,(Top) → Component config → Driver configurations → UART configuration 。 选中Place UART ISR function into IRAM。 然后记得根据你更新包的大小适度调到Ring Buffer的值,建议用4096. |
255个成员聚集在这个小组
加入小组636 浏览 1 评论
3135 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
580浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
326浏览 3评论
1294浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
1574浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
339浏览 2评论
GMT+8, 2025-7-6 06:05 , Processed in 0.991651 second(s), Total 76, Slave 60 queries .
