开发板:ESP32-S2-saola-1_V1.2
开发环境安装方式:esp-idf-tools-setup-offline-2.8.exe 安装后是 v4.2版本 开发环境 :eclipse 使用j-link调试时出现以下问题,未找到原因: Open On-Chip Debugger v0.10.0-esp32-20200709 (2020-07-09-08:54)Licensed under GNU GPL v2For bug reports, read http://openocd.org/doc/doxygen/bugs.htmladapter speed: 9600 kHzStarted by GNU MCU EclipseInfo : Listening on port 6666 for tcl connectionsInfo : Listening on port 4444 for telnet connectionsInfo : J-Link V9 compiled Dec 13 2019 11:14:50Info : Hardware version: 9.20Info : VTarget = 3.301 VInfo : clock speed 9600 kHzInfo : JTAG tap: esp32s2.cpu tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)Info : esp32s2: Target halted, PC=0x400314A4, debug_reason=00000001Info : Detected ESP32-S2 chipInfo : Listening on port 3333 for gdb connectionsInfo : accepting 'gdb' connection on tcp/3333Error: No symbols for FreeRTOSError: esp32s2: DSR (8000CC13) indicates DIR instruction generated an exception!Warn : esp32s2: Failed reading 5284 bytes at address 0x40030000Error: no working area available, can't alloc space for stub code!Error: Failed to load stub (-308)!Error: Algorithm run failed (-308)!Error: Failed to run flasher stub (-308)!Warn : Failed to get flash mappings (-308)!Error: esp32s2: DSR (8000CC13) indicates DIR instruction generated an exception!Warn : esp32s2: Failed reading 5284 bytes at address 0x40030000Error: no working area available, can't alloc space for stub code!Error: Failed to load stub (-308)!Error: Algorithm run failed (-308)!Error: Failed to run flasher stub (-308)!Error: esp32s2: DSR (8000CC13) indicates DIR instruction generated an exception!Warn : esp32s2: Failed reading 5284 bytes at address 0x40030000Error: no working area available, can't alloc space for stub code!Error: Failed to load stub (-308)!Error: Algorithm run failed (-308)!Error: Failed to run flasher stub (-308)!Error: Failed to probe flash, size 0 KBError: auto_probe failedError: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.Error: attempted 'gdb' connection rejected |
在使用 ESP32-S2-saola-1_V1.2 和 J-Link 进行调试时,您遇到了一些问题。为了解决这个问题,我们可以按照以下步骤进行排查:
1. 检查硬件连接:确保 ESP32-S2-saola-1_V1.2 开发板与 J-Link 调试器之间的连接正确。检查是否有松动或损坏的引脚。 2. 检查 J-Link 驱动程序:确保您的计算机已安装了适用于 J-Link 调试器的正确驱动程序。如果没有,请从 J-Link 官方网站下载并安装。 3. 检查 J-Link 固件:确保 J-Link 调试器的固件是最新的。如果不是,请从 J-Link 官方网站下载并更新固件。 4. 检查 OpenOCD 版本:您提到使用的是 Open On-Chip Debugger v0.10.0-esp32-20200709。请尝试更新到最新版本的 OpenOCD,以确保与 ESP32-S2-saola-1_V1.2 开发板的兼容性。 5. 检查 Eclipse 配置:确保 Eclipse 的配置正确,包括 J-Link 调试器的设置。您可以在 Eclipse 的 "Run Configurations" 中检查这些设置。 6. 检查 ESP-IDF 版本:您提到使用的是 ESP-IDF v4.2。请确保这个版本与您的开发板和 J-Link 调试器兼容。如果不兼容,请尝试升级或降级 ESP-IDF。 7. 检查串口连接:确保您的计算机与 ESP32-S2-saola-1_V1.2 开发板之间的串口连接正确。检查串口线是否损坏或连接不稳定。 8. 检查电源:确保 ESP32-S2-saola-1_V1.2 开发板的电源稳定,以避免调试过程中出现意外问题。 9. 重新启动调试过程:在完成以上检查后,重新启动 Eclipse 和 J-Link 调试器,然后再次尝试调试。 如果问题仍然存在,请提供更多关于错误的详细信息,例如错误消息或日志文件,以便我们能够更准确地诊断问题。 |
171个成员聚集在这个小组
加入小组430 浏览 1 评论
1290 浏览 1 评论
598浏览 6评论
494浏览 5评论
480浏览 5评论
476浏览 4评论
461浏览 4评论
GMT+8, 2025-1-11 09:47 , Processed in 0.737683 second(s), Total 45, Slave 40 queries .
