gpio_config_t io_conf = {};
io_conf.intr_type = GPIO_INTR_DISABLE; io_conf.mode = GPIO_MODE_OUTPUT; io_conf.pin_bit_mask = GPIO_OUTPUT_PIN_SEL; io_conf.pull_down_en = 0; io_conf.pull_up_en = 0; gpio_config(&io_conf); gpio_set_level(GPIO_LOW_NUM1, 0); gpio_set_level(GPIO_LOW_NUM2, 0); gpio_set_level(GPIO_LOW_NUM3, 0); gpio_set_level(GPIO_LOW_NUM4, 0); gpio_set_level(GPIO_LOW_NUM5, 0); gpio_set_level(GPIO_LOW_NUM6, 0); gpio_set_level(GPIO_LOW_NUM7, 0); gpio_set_level(GPIO_LOW_NUM8, 0); gpio_set_level(TEST_LCD_DISP_EN_GPIO, 1); lv_disp_t *disp = NULL; lv_init(); esp_lcd_panel_handle_t panel_handle = NULL; esp_lcd_rgb_panel_config_t panel_config = { .data_width = 16, .disp_gpio_num = -1, .pclk_gpio_num = TEST_LCD_PCLK_GPIO, .vsync_gpio_num = TEST_LCD_VSYNC_GPIO, .hsync_gpio_num = TEST_LCD_HSYNC_GPIO, .de_gpio_num = TEST_LCD_DE_GPIO, .data_gpio_nums = { TEST_LCD_DATA0_GPIO, TEST_LCD_DATA1_GPIO, TEST_LCD_DATA2_GPIO, TEST_LCD_DATA3_GPIO, TEST_LCD_DATA4_GPIO, TEST_LCD_DATA5_GPIO, TEST_LCD_DATA6_GPIO, TEST_LCD_DATA7_GPIO, TEST_LCD_DATA8_GPIO, TEST_LCD_DATA9_GPIO, TEST_LCD_DATA10_GPIO, TEST_LCD_DATA11_GPIO, TEST_LCD_DATA12_GPIO, TEST_LCD_DATA13_GPIO, TEST_LCD_DATA14_GPIO, TEST_LCD_DATA15_GPIO, }, .timings = { .pclk_hz = 15000000, .h_res = TEST_LCD_H_RES, .v_res = TEST_LCD_V_RES, .hsync_back_porch = 50, .hsync_front_porch = 2, .hsync_pulse_width = 1, .vsync_back_porch = 30, .vsync_front_porch = 1, .vsync_pulse_width = 1, .flags.pclk_active_neg = 1, .flags.hsync_idle_low = 1, .flags.vsync_idle_low = 1, .flags.pclk_idle_low = 1, }, .flags.fb_in_psram = 1, .on_frame_trans_done = notify_lvgl_ready_to_flush, .user_ctx = &disp, }; TEST_ESP_OK(esp_lcd_new_rgb_panel(&panel_config, &panel_handle)); TEST_ESP_OK(esp_lcd_panel_reset(panel_handle)); TEST_ESP_OK(esp_lcd_panel_init(panel_handle)); test_lvgl_task_loop(panel_handle, TEST_LCD_H_RES, TEST_LCD_V_RES, &disp);求帮忙解惑 |
在解决ESP32-S3驱动RGB屏幕出现颜色问题时,我们需要按照以下步骤进行排查和解决:
1. 检查硬件连接:首先确保RGB屏幕的数据线、电源线和控制线都已正确连接到ESP32-S3。检查是否有接触不良或线路损坏的情况。 2. 检查GPIO配置:根据您提供的代码片段,您已经配置了GPIO为输出模式。请确保您为RGB屏幕的每个颜色通道(红、绿、蓝)分配了正确的GPIO引脚。例如: ```c io_conf.pin_bit_mask = (1ULL< |
180个成员聚集在这个小组
加入小组453 浏览 1 评论
1450 浏览 1 评论
618浏览 6评论
515浏览 5评论
494浏览 5评论
496浏览 4评论
486浏览 4评论
GMT+8, 2025-2-2 22:23 , Processed in 0.548470 second(s), Total 43, Slave 38 queries .
