我按照说明操作,VSCODE 无法使用该库:
https ://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/system.html#_CPPv411esp_restartv Code: Select all [Starting] Analyzing sketch 'TESTTEST.ino'[Warning] Output path is not specified. Unable to reuse previously compiled files. Build will be slower. See README.Loading configuration... Initializing packages... Skipping contributed index file C:UsersAdministratorAppDataLocalArduino15master.zip, parsing error occured:com.fasterxml.jackson.core.JsonParseException: Unrecognized token 'PK': was expecting ('true', 'false' or 'null') at [Source: (FileInputStream); line: 1, column: 6]Skipping contributed index file C:UsersAdministratorAppDataLocalArduino15master.zip, parsing error occured:com.fasterxml.jackson.core.JsonParseException: Unrecognized token 'PK': was expecting ('true', 'false' or 'null') at [Source: (FileInputStream); line: 1, column: 6]Preparing development board... Verifying... TEST:6:25: fatal error: periph_ctrl.h: No such file or directorycompilation terminated.exit status 1[Warning] Failed to generate IntelliSense configuration.[Error] Analyzing sketch 'TESTTEST.ino': Exit with code=1 命令没作用Arduino: Rebuild IntelliSense Configuration 如何为 ESP32 实现软重启? |
要为ESP32实现软重启,您可以使用ESP-IDF提供的`esp_restart()`函数。首先,请确保您已经正确安装了ESP-IDF和配置了VSCode。以下是实现软重启的步骤:
1. 打开VSCode,然后打开您的ESP32项目。 2. 在您的代码中,包含以下头文件: ```cpp #include "esp_system.h" ``` 3. 在适当的位置(例如,在一个按钮按下事件或定时器触发事件中),调用`esp_restart()`函数: ```cpp esp_restart(); ``` 4. 保存您的代码并编译项目。如果遇到问题,请确保您的ESP-IDF环境已正确配置。 关于您提到的VSCode无法使用库的问题,您可以尝试以下步骤来解决: 1. 确保您已经正确安装了ESP-IDF。请按照官方文档(https://docs.espressif.com/projects/esp-idf/en/latest/esp32/get-started/index.html#installation-step-by-step)进行安装。 2. 在VSCode中,打开命令面板(`Ctrl+Shift+P`或`Cmd+Shift+P`),然后输入并选择“Preferences: Open Settings (JSON)”。在打开的设置文件中,确保以下配置正确: ```json { "cmake.configureOnOpen": true, "cmake.buildBeforeRun": true, "cmake.generator": "Ninja", "cmake.buildDirectory": "${workspaceFolder}/build", "cmake.installPrefix": "${workspaceFolder}/install" } ``` 3. 确保您的`CMakeLists.txt`文件已正确配置。以下是一个基本的示例: ```cmake cmake_minimum_required(VERSION 3.5) project(TESTTEST) set(COMPONENT_SRCS "main.c") set(COMPONENT_ADD_INCLUDEDIRS ".") include($ENV{IDF_PATH}/tools/cmake/project.cmake) project(${COMPONENT_NAME}) ``` 4. 如果问题仍然存在,请尝试清理项目并重新编译。在VSCode的终端中,运行以下命令: ``` idf.py fullclean idf.py build ``` 5. 如果以上步骤都无法解决问题,请检查您的ESP-IDF版本是否与VSCode插件兼容。您可以尝试更新ESP-IDF或VSCode插件到最新版本。 希望这些步骤能帮助您解决问题并实现ESP32的软重启。 |
179个成员聚集在这个小组
加入小组441 浏览 1 评论
1407 浏览 1 评论
608浏览 6评论
506浏览 5评论
487浏览 5评论
489浏览 4评论
472浏览 4评论
GMT+8, 2025-1-24 14:43 , Processed in 0.541667 second(s), Total 43, Slave 38 queries .
