开发板:ESP32-S2-DevKitM-1 v1.0
开发环境:win10+espressif-ide(c语言) 我直接打开ulp_adc例程能编译成功,但无法烧录,烧录失败并出现下述信息。(其他例程可以正常烧录) [1/388] Performing build step for 'ulp_main' FAILED: esp-idf/main/ulp_main-prefix/src/ulp_main-stamp/ulp_main-build esp-idf/main/ulp_main/ulp_main.bin esp-idf/main/ulp_main/ulp_main.ld esp-idf/main/ulp_main/ulp_main.h esp-idf/main/ulp_main/ulp_main.map esp-idf/main/ulp_main/ulp_main.sym esp-idf/main/ulp_main/esp32.ulp.ld esp-idf/main/ulp_main/ulp_main F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main-prefix/src/ulp_main-stamp/ulp_main-build F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main.bin F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main.ld F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main.h F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main.map F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main.sym F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/esp32.ulp.ld F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main cmd.exe /C "cd /D F:ESP_Workspaceulp_adcbuildesp-idfmainulp_main && F:ESP-IDFEspressiftoolscmake3.23.1bincmake.exe --build F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main --target build" [1/4] Linking ASM executable ulp_main FAILED: ulp_main cmd.exe /C "cd . && F:ESP-IDFEspressiftoolsesp32s2ulp-elf2.28.51-esp-20191205esp32s2ulp-elf-binutilsbinesp32s2ulp-elf-ld.exe -A elf32-esp32s2ulp -nostdlib CMakeFiles/ulp_main.dir/adc.ulp.S.obj -o ulp_main -T"F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_fsm.ld" -Map="F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main.map" && cd ." F:ESP-IDFEspressiftoolsesp32s2ulp-elf2.28.51-esp-20191205esp32s2ulp-elf-binutilsbinesp32s2ulp-elf-ld.exe: invalid length for memory region ram ninja: build stopped: subcommand failed. [2/388] Performing build step for 'bootloader' [1/1] cmd.exe /C "cd /D F:ESP_Workspaceulp_adcbuildbootloaderesp-idfesptool_py && python F:/ESP-IDF/Espressif/frameworks/esp-idf-v4.4.2/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x1000 F:/ESP_Workspace/ulp_adc/build/bootloader/bootloader.bin" Bootloader binary size 0x4950 bytes. 0x26b0 bytes (35%) free. [3/386] Generating x509_crt_bundle ninja: build stopped: subcommand failed. Executing action: flash Running ninja in directory f:esp_workspaceulp_adcbuild Executing "ninja flash"... ninja failed with exit code 1 例程未更改,但无法下载 能麻烦工作人员帮忙看看吗? |
根据您提供的信息,您在尝试烧录ESP32-S2的ulp_adc例程时遇到了问题。以下是一些建议来解决这个问题:
1. 确保您的ESP32-S2-DevKitM-1 v1.0开发板已正确连接到计算机,并已安装所需的驱动程序。 2. 检查您的开发环境设置,确保选择了正确的目标设备(ESP32-S2)和烧录端口。 3. 确保您的ESP-IDF版本与例程兼容。您可以在ESP-IDF的GitHub仓库中查看所需的版本:https://github.com/espressif/esp-idf 4. 尝试清理项目并重新编译。在ESP-IDE中,您可以通过选择“Project”>“Clean Project”来执行此操作。 5. 如果问题仍然存在,请尝试升级ESP-IDF到最新版本。您可以按照以下步骤操作: a. 打开命令提示符或终端。 b. 导航到ESP-IDF的安装目录。 c. 运行以下命令:`git pull`(这将从GitHub仓库获取最新版本)。 d. 运行以下命令:`./install.sh`(在Linux或Mac上)或`install.bat`(在Windows上)。 |
171个成员聚集在这个小组
加入小组343 浏览 0 评论
1192 浏览 1 评论
587浏览 6评论
484浏览 5评论
468浏览 5评论
467浏览 4评论
443浏览 4评论
GMT+8, 2024-12-28 16:07 , Processed in 1.148111 second(s), Total 47, Slave 41 queries .
