当我使用HTTP POST/GET请求时,每次请求耗时一般在100-300ms左右
更改为HTTPS,并加入服务器证书校验后,每次请求耗时需要3s以上 我尝试过下面这几种配置方式,但是耗时变化不大 1、 esp_tls_cfg_t cfg = { .use_global_ca_store = true, }; 2、 esp_tls_cfg_t cfg = { .cacert_buf = (const unsigned char *) server_root_cert_pem_start, .cacert_bytes = server_root_cert_pem_end - server_root_cert_pem_start, }; 3、 esp_tls_cfg_t cfg = { .crt_bundle_attach = esp_crt_bundle_attach, }; 然后我跟踪源码运行发现,每次请求耗时主要在esp_mbedtls_handshake内 Then I tracked the source code and ran and found that each request took less than esp_mbedtls_handshake E (9881) esp-tls-mbedtls: -------start = 9270ms esp_mbedtls_handshake I (10691) esp-x509-crt-bundle: Certificate validated E (15741) esp-tls-mbedtls: -------end =15130ms esp_mbedtls_handshake 这是否是正常的HTTPS请求耗时?还是我的配置出现问题?是否有优化请求耗时的方法呢? 下方是完整的启动、请求日志: entry 0x40080694 I (27) boot: ESP-IDF v4.4.2-378-g9269a536ac-dirty 2nd stage bootloader I (27) boot: compile time 22:13:45 I (28) boot: chip revision: 3 I (32) boot_comm: chip revision: 3, min. bootloader chip revision: 0 I (39) boot.esp32: SPI Speed : 40MHz I (44) boot.esp32: SPI Mode : DIO I (48) boot.esp32: SPI Flash Size : 2MB I (53) boot: Enabling RNG early entropy source... I (58) boot: Partition Table: I (62) boot: ## Label Usage Type ST Offset Length I (69) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (77) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (84) boot: 2 factory factory app 00 00 00010000 00100000 I (92) boot: End of partition table I (96) boot_comm: chip revision: 3, min. application chip revision: 0 I (103) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=28eb8h (167608) map I (172) esp_image: segment 1: paddr=00038ee0 vaddr=3ffb0000 size=03800h ( 14336) load I (178) esp_image: segment 2: paddr=0003c6e8 vaddr=40080000 size=03930h ( 14640) load I (184) esp_image: segment 3: paddr=00040020 vaddr=400d0020 size=88158h (557400) map I (388) esp_image: segment 4: paddr=000c8180 vaddr=40083930 size=10f64h ( 69476) load I (417) esp_image: segment 5: paddr=000d90ec vaddr=50000000 size=00010h ( 16) load I (427) boot: Loaded app from partition at offset 0x10000 I (427) boot: Disabling RNG early entropy source... I (439) cpu_start: Pro cpu up. I (439) cpu_start: Starting app cpu, entry point is 0x400811a4 0x400811a4: call_start_cpu1 at /home/leo/work/esp/esp-idf/components/esp_system/port/cpu_start.c:148 I (0) cpu_start: App cpu up. I (456) cpu_start: Pro cpu start user code I (456) cpu_start: cpu freq: 160000000 I (456) cpu_start: Application information: I (460) cpu_start: Project name: https_request I (466) cpu_start: App version: 1 I (470) cpu_start: Compile time: Jan 10 2023 22:13:40 I (476) cpu_start: ELF file SHA256: 3ad1424200dff368... I (482) cpu_start: ESP-IDF: v4.4.2-378-g9269a536ac-dirty I (489) heap_init: Initializing. RAM available for dynamic allocation: I (496) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (502) heap_init: At 3FFB7790 len 00028870 (162 KiB): DRAM I (508) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (515) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (521) heap_init: At 40094894 len 0000B76C (45 KiB): IRAM I (529) spi_flash: detected chip: generic I (532) spi_flash: flash io: dio W (536) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header. I (550) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (671) wifi:wifi driver task: 3ffc01f8, prio:23, stack:6656, core=0 I (671) system_api: Base MAC address is not set I (671) system_api: read default base MAC address from EFUSE I (691) wifi:wifi firmware version: f1d33cc I (691) wifi:wifi certification version: v7.0 I (691) wifi:config NVS flash: enabled I (691) wifi:config nano formating: disabled I (701) wifi:Init data frame dynamic rx buffer num: 32 I (701) wifi:Init management frame dynamic rx buffer num: 32 I (711) wifi:Init management short buffer num: 32 I (711) wifi:Init dynamic tx buffer num: 32 I (721) wifi:Init static rx buffer size: 1600 I (721) wifi:Init static rx buffer num: 10 I (731) wifi:Init dynamic rx buffer num: 32 I (731) wifi_init: rx ba win: 6 I (731) wifi_init: tcpip mbox: 32 I (741) wifi_init: udp mbox: 6 I (741) wifi_init: tcp mbox: 6 I (741) wifi_init: tcp tx win: 5744 I (751) wifi_init: tcp rx win: 5744 I (751) wifi_init: tcp mss: 1440 I (761) wifi_init: WiFi IRAM OP enabled I (761) wifi_init: WiFi RX IRAM OP enabled I (771) example_connect: Connecting to midea_ceshi_002... I (771) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07 W (781) phy_init: failed to load RF calibration data (0xffffffff), falling back to full calibration I (1051) wifi:mode : sta (b8:d6:1a:33:d0:e4) I (1051) wifi:enable tsf I (1061) example_connect: Waiting for IP(s) I (3471) wifi<8,0>, old:<1,0>, ap:<255,255>, sta:<8,0>, prof:1 I (4211) wifi:state: init -> auth (b0) I (4221) wifi:state: auth -> assoc (0) I (4221) wifi:state: assoc -> run (10) W (4231) wifi:idx:0 (ifx:0, 34:97:f6:b6:22:a0), tid:0, ssn:0, winSize:64 I (4251) wifi:connected with midea_ceshi_002, aid = 7, channel 8, BW20, bssid = 34:97:f6:b6:22:a0 I (4251) wifi:security: WPA2-PSK, phy: bgn, rssi: -42 I (4251) wifi:pm start, type: 1 I (4331) wifi:AP's beacon interval = 102400 us, DTIM period = 3 I (5661) example_connect: Got IPv6 event: Interface "example_connect: sta" address: fe80:0000:0000:0000:bad6:1aff:fe33:d0e4, type: ESP_IP6_ADDR_IS_LINK_LOCAL I (9161) esp_netif_handlers: example_connect: sta ip: 192.168.3.137, mask: 255.255.255.0, gw: 192.168.3.1 I (9161) example_connect: Got IPv4 event: Interface "example_connect: sta" address: 192.168.3.137 I (9171) example_connect: Connected to example_connect: sta I (9171) example_connect: - IPv4 address: 192.168.3.137 I (9181) example_connect: - IPv6 address: fe80:0000:0000:0000:bad6:1aff:fe33:d0e4, type: ESP_IP6_ADDR_IS_LINK_LOCAL I (9191) example: Start https_request example I (9201) example: https_request using crt bundle E (9881) esp-tls-mbedtls: -------start = 9270ms esp_mbedtls_handshake I (10691) esp-x509-crt-bundle: Certificate validated E (15741) esp-tls-mbedtls: -------end =15130ms esp_mbedtls_handshake I (15741) example: Connection established... I (15751) example: 106 bytes written I (15751) example: Reading HTTP response... HTTP/1.1 200 OK Content-Length: 2091 Access-Control-Allow-Origin: * Connection: close Content-Type: application/json Date: Wed, 11 Jan 2023 06:15:16 GMT Strict-Transport-Security: max-age=631138519; includeSubdomains; preload ... I (42881) example: https_request using global ca_store E (44281) esp-tls-mbedtls: -------start = 43670ms esp_mbedtls_handshake E (47381) esp-tls-mbedtls: -------end =46770ms esp_mbedtls_handshake I (47391) example: Connection established... I (47401) example: 106 bytes written I (47401) example: Reading HTTP response... HTTP/1.1 200 OK Content-Length: 2091 Access-Control-Allow-Origin: * Connection: close Content-Type: application/json Date: Wed, 11 Jan 2023 06:15:48 GMT Strict-Transport-Security: max-age=631138519; includeSubdomains; preload Top 以下内容为评论 ESP_YJM Posts: 300 Joined: Fri Feb 26, 2021 10:30 am Re: ESP32-S3 HTTPS esp_mbedtls_handshake握手平均耗时3s以上 Postby ESP_YJM » Wed Jan 11, 2023 11:12 am 能否提供下你的 sdkconfig 以及打开 mbedtls debug 查看下 mbedtls 握手所使用的套件。 Top kangzy4 Posts: 6 Joined: Wed Jan 11, 2023 7:18 am Re: ESP32-S3 HTTPS esp_mbedtls_handshake握手平均耗时3s以上 Postby kangzy4 » Sun Jan 15, 2023 12:46 am 好的,这里提供下配置和日志信息如下: 下方是sdkconfig与TLS相关的配置 # # ESP-TLS # CONFIG_ESP_TLS_USING_MBEDTLS=y CONFIG_ESP_TLS_USE_DS_PERIPHERAL=y # CONFIG_ESP_TLS_CLIENT_SESSION_TICKETS is not set # CONFIG_ESP_TLS_SERVER is not set # CONFIG_ESP_TLS_PSK_VERIFICATION is not set CONFIG_ESP_TLS_INSECURE=y CONFIG_ESP_TLS_SKIP_SERVER_CERT_VERIFY=y # end of ESP-TLS # # mbedTLS # CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y # CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC is not set # CONFIG_MBEDTLS_DEFAULT_MEM_ALLOC is not set # CONFIG_MBEDTLS_CUSTOM_MEM_ALLOC is not set CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN=y CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16384 CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096 # CONFIG_MBEDTLS_DYNAMIC_BUFFER is not set CONFIG_MBEDTLS_DEBUG=y # CONFIG_MBEDTLS_DEBUG_LEVEL_WARN is not set # CONFIG_MBEDTLS_DEBUG_LEVEL_INFO is not set # CONFIG_MBEDTLS_DEBUG_LEVEL_DEBUG is not set CONFIG_MBEDTLS_DEBUG_LEVEL_VERBOSE=y CONFIG_MBEDTLS_DEBUG_LEVEL=4 # # mbedTLS v2.28.x related # # CONFIG_MBEDTLS_SSL_VARIABLE_BUFFER_LENGTH is not set # CONFIG_MBEDTLS_X509_TRUSTED_CERT_CALLBACK is not set # CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION is not set CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE=y # end of mbedTLS v2.28.x related # # Certificate Bundle # CONFIG_MBEDTLS_CERTIFICATE_BUNDLE=y CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_FULL=y # CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_CMN is not set # CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_NONE is not set # CONFIG_MBEDTLS_CUSTOM_CERTIFICATE_BUNDLE is not set CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_MAX_CERTS=200 # end of Certificate Bundle # CONFIG_MBEDTLS_ECP_RESTARTABLE is not set # CONFIG_MBEDTLS_CMAC_C is not set CONFIG_MBEDTLS_HARDWARE_AES=y CONFIG_MBEDTLS_AES_USE_INTERRUPT=y CONFIG_MBEDTLS_HARDWARE_MPI=y CONFIG_MBEDTLS_HARDWARE_SHA=y CONFIG_MBEDTLS_ROM_MD5=y # CONFIG_MBEDTLS_ATCA_HW_ECDSA_SIGN is not set # CONFIG_MBEDTLS_ATCA_HW_ECDSA_VERIFY is not set CONFIG_MBEDTLS_HAVE_TIME=y # CONFIG_MBEDTLS_HAVE_TIME_DATE is not set CONFIG_MBEDTLS_ECDSA_DETERMINISTIC=y CONFIG_MBEDTLS_SHA512_C=y CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT=y # CONFIG_MBEDTLS_TLS_SERVER_ONLY is not set # CONFIG_MBEDTLS_TLS_CLIENT_ONLY is not set # CONFIG_MBEDTLS_TLS_DISABLED is not set CONFIG_MBEDTLS_TLS_SERVER=y CONFIG_MBEDTLS_TLS_CLIENT=y CONFIG_MBEDTLS_TLS_ENABLED=y # # TLS Key Exchange Methods # # CONFIG_MBEDTLS_PSK_MODES is not set CONFIG_MBEDTLS_KEY_EXCHANGE_RSA=y CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA=y CONFIG_MBEDTLS_KEY_EXCHANGE_ELLIPTIC_CURVE=y CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA=y CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA=y CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA=y CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA=y # end of TLS Key Exchange Methods CONFIG_MBEDTLS_SSL_RENEGOTIATION=y # CONFIG_MBEDTLS_SSL_PROTO_SSL3 is not set CONFIG_MBEDTLS_SSL_PROTO_TLS1=y CONFIG_MBEDTLS_SSL_PROTO_TLS1_1=y CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y # CONFIG_MBEDTLS_SSL_PROTO_GMTSSL1_1 is not set # CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set CONFIG_MBEDTLS_SSL_ALPN=y CONFIG_MBEDTLS_CLIENT_SSL_SESSION_TICKETS=y CONFIG_MBEDTLS_X509_CHECK_KEY_USAGE=y CONFIG_MBEDTLS_X509_CHECK_EXTENDED_KEY_USAGE=y CONFIG_MBEDTLS_SERVER_SSL_SESSION_TICKETS=y # # Symmetric Ciphers # CONFIG_MBEDTLS_AES_C=y # CONFIG_MBEDTLS_CAMELLIA_C is not set # CONFIG_MBEDTLS_DES_C is not set CONFIG_MBEDTLS_RC4_DISABLED=y # CONFIG_MBEDTLS_RC4_ENABLED_NO_DEFAULT is not set # CONFIG_MBEDTLS_RC4_ENABLED is not set # CONFIG_MBEDTLS_BLOWFISH_C is not set # CONFIG_MBEDTLS_XTEA_C is not set CONFIG_MBEDTLS_CCM_C=y CONFIG_MBEDTLS_GCM_C=y # CONFIG_MBEDTLS_NIST_KW_C is not set # end of Symmetric Ciphers # CONFIG_MBEDTLS_RIPEMD160_C is not set # # Certificates # CONFIG_MBEDTLS_PEM_PARSE_C=y CONFIG_MBEDTLS_PEM_WRITE_C=y CONFIG_MBEDTLS_X509_CRL_PARSE_C=y CONFIG_MBEDTLS_X509_CSR_PARSE_C=y # end of Certificates CONFIG_MBEDTLS_ECP_C=y CONFIG_MBEDTLS_ECDH_C=y CONFIG_MBEDTLS_ECDSA_C=y # CONFIG_MBEDTLS_ECJPAKE_C is not set CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED=y CONFIG_MBEDTLS_ECP_NIST_OPTIM=y # CONFIG_MBEDTLS_POLY1305_C is not set # CONFIG_MBEDTLS_CHACHA20_C is not set # CONFIG_MBEDTLS_HKDF_C is not set # CONFIG_MBEDTLS_THREADING_C is not set # CONFIG_MBEDTLS_LARGE_KEY_SOFTWARE_MPI is not set # CONFIG_MBEDTLS_SECURITY_RISKS is not set # end of mbedTLS 下面是开启Mbedtls后的日志 I (31829) ms_camera: picture: 1280 x 720 22111byte I (31834) ms_http_client: picture size = 22111 I (31846) ms_http_client: http_get_task 2 I (31851) ms_http_client: http_loader_len = 22553 I (31855) ms_http_client: HTTP POST:30606 E (31860) TRANSPORT_BASE: -------send time test=30611ms ssl_connect E (31907) esp-tls: -------send time test3=30658ms tcp_connect E (31907) esp-tls-mbedtls: -------send time2=30658ms esp_mbedtls_handshake I (31910) mbedtls: ssl_tls.c:5905 => handshake I (31922) mbedtls: ssl_cli.c:4483 client state: 0 I (31927) mbedtls: ssl_msg.c:2102 => flush output I (31933) mbedtls: ssl_msg.c:2114 <= flush output I (31945) mbedtls: ssl_cli.c:4483 client state: 1 I (31950) mbedtls: ssl_msg.c:2102 => flush output I (31956) mbedtls: ssl_msg.c:2114 <= flush output I (31961) mbedtls: ssl_cli.c:999 => write client hello I (31970) mbedtls: ssl_msg.c:2542 => write handshake message I (31974) mbedtls: ssl_msg.c:2701 => write record I (31981) mbedtls: ssl_msg.c:2102 => flush output I (31985) mbedtls: ssl_msg.c:2122 message length: 244, out_left: 244 I (31994) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 244 (-0xffffff0c) I (32000) mbedtls: ssl_msg.c:2155 <= flush output I (32006) mbedtls: ssl_msg.c:2870 <= write record I (32011) mbedtls: ssl_msg.c:2678 <= write handshake message I (32018) mbedtls: ssl_cli.c:1467 <= write client hello I (32030) mbedtls: ssl_cli.c:4483 client state: 2 I (32036) mbedtls: ssl_msg.c:2102 => flush output I (32041) mbedtls: ssl_msg.c:2114 <= flush output I (32047) mbedtls: ssl_cli.c:2082 => parse server hello I (32053) mbedtls: ssl_msg.c:3941 => read record I (32058) mbedtls: ssl_msg.c:1886 => fetch input I (32064) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5 I (32070) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5 I (32076) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) I (32085) mbedtls: ssl_msg.c:2089 <= fetch input I (32090) mbedtls: ssl_msg.c:1886 => fetch input I (32096) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 70 I (32102) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 70 I (32108) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 65 (-0xffffffbf) I (32117) mbedtls: ssl_msg.c:2089 <= fetch input I (32123) mbedtls: ssl_msg.c:4015 <= read record I (32128) mbedtls: ssl_cli.c:2385 server hello, total extension length: 21 I (32136) mbedtls: ssl_cli.c:2627 <= parse server hello I (32148) mbedtls: ssl_cli.c:4483 client state: 3 I (32153) mbedtls: ssl_msg.c:2102 => flush output I (32159) mbedtls: ssl_msg.c:2114 <= flush output I (32164) mbedtls: ssl_tls.c:2878 => parse certificate I (32170) mbedtls: ssl_msg.c:3941 => read record I (32176) mbedtls: ssl_msg.c:1886 => fetch input I (32181) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5 I (32188) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5 I (32194) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) I (32202) mbedtls: ssl_msg.c:2089 <= fetch input I (32208) mbedtls: ssl_msg.c:1886 => fetch input I (32213) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 2738 I (32221) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 2738 I (32226) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 2733 (-0xfffff553) I (32235) mbedtls: ssl_msg.c:2089 <= fetch input I (32259) mbedtls: ssl_msg.c:4015 <= read record I (32266) mbedtls: ssl_tls.c:2989 <= parse certificate I (32268) mbedtls: ssl_cli.c:4483 client state: 4 I (32273) mbedtls: ssl_msg.c:2102 => flush output I (32279) mbedtls: ssl_msg.c:2114 <= flush output I (32284) mbedtls: ssl_cli.c:3094 => parse server key exchange I (32291) mbedtls: ssl_msg.c:3941 => read record I (32297) mbedtls: ssl_msg.c:1886 => fetch input I (32302) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5 I (32309) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5 I (32315) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) I (32323) mbedtls: ssl_msg.c:2089 <= fetch input I (32329) mbedtls: ssl_msg.c:1886 => fetch input I (32334) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 305 I (32341) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 305 I (32347) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 300 (-0xfffffed4) I (32355) mbedtls: ssl_msg.c:2089 <= fetch input I (32363) mbedtls: ssl_msg.c:4015 <= read record I (32369) mbedtls: ssl_cli.c:2699 ECDH curve: x25519 I (32372) mbedtls: ssl_cli.c:3018 Server used SignatureAlgorithm 1 I (32379) mbedtls: ssl_cli.c:3020 Server used HashAlgorithm 4 I (32407) mbedtls: ssl_cli.c:3487 <= parse server key exchange I (32410) mbedtls: ssl_cli.c:4483 client state: 5 I (32415) mbedtls: ssl_msg.c:2102 => flush output I (32421) mbedtls: ssl_msg.c:2114 <= flush output I (32427) mbedtls: ssl_cli.c:3522 => parse certificate request I (32433) mbedtls: ssl_msg.c:3941 => read record I (32439) mbedtls: ssl_msg.c:1886 => fetch input I (32444) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5 I (32451) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5 I (32457) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) I (32465) mbedtls: ssl_msg.c:2089 <= fetch input I (32471) mbedtls: ssl_msg.c:1886 => fetch input I (32476) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 9 I (32482) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 9 I (32488) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 4 (-0xfffffffc) I (32497) mbedtls: ssl_msg.c:2089 <= fetch input I (32502) mbedtls: ssl_msg.c:4015 <= read record I (32508) mbedtls: ssl_cli.c:3678 <= parse certificate request I (32521) mbedtls: ssl_cli.c:4483 client state: 6 I (32526) mbedtls: ssl_msg.c:2102 => flush output I (32532) mbedtls: ssl_msg.c:2114 <= flush output I (32537) mbedtls: ssl_cli.c:3689 => parse server hello done I (32544) mbedtls: ssl_msg.c:3941 => read record I (32549) mbedtls: ssl_msg.c:4011 reuse previously read message I (32556) mbedtls: ssl_msg.c:4015 <= read record I (32562) mbedtls: ssl_cli.c:3719 <= parse server hello done I (32575) mbedtls: ssl_cli.c:4483 client state: 7 I (32580) mbedtls: ssl_msg.c:2102 => flush output I (32586) mbedtls: ssl_msg.c:2114 <= flush output I (32591) mbedtls: ssl_tls.c:2229 => write certificate I (32597) mbedtls: ssl_tls.c:2243 <= skip write certificate I (32610) mbedtls: ssl_cli.c:4483 client state: 8 I (32616) mbedtls: ssl_msg.c:2102 => flush output I (32621) mbedtls: ssl_msg.c:2114 <= flush output I (32627) mbedtls: ssl_cli.c:3734 => write client key exchange I (33112) mbedtls: ssl_msg.c:2542 => write handshake message I (33113) mbedtls: ssl_msg.c:2701 => write record I (33114) mbedtls: ssl_msg.c:2102 => flush output I (33119) mbedtls: ssl_msg.c:2122 message length: 42, out_left: 42 I (33127) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 42 (-0xffffffd6) I (33134) mbedtls: ssl_msg.c:2155 <= flush output I (33139) mbedtls: ssl_msg.c:2870 <= write record I (33145) mbedtls: ssl_msg.c:2678 <= write handshake message I (33151) mbedtls: ssl_cli.c:4151 <= write client key exchange I (33165) mbedtls: ssl_cli.c:4483 client state: 9 I (33170) mbedtls: ssl_msg.c:2102 => flush output I (33175) mbedtls: ssl_msg.c:2114 <= flush output I (33181) mbedtls: ssl_cli.c:4196 => write certificate verify I (33188) mbedtls: ssl_tls.c:1728 => derive keys I (33193) mbedtls: ssl_tls.c:1930 => calc verify sha256 I (33200) mbedtls: ssl_tls.c:1938 <= calc verify I (33212) mbedtls: ssl_tls.c:1807 <= derive keys I (33213) mbedtls: ssl_cli.c:4221 <= skip write certificate verify I (33224) mbedtls: ssl_cli.c:4483 client state: 10 I (33229) mbedtls: ssl_msg.c:2102 => flush output I (33235) mbedtls: ssl_msg.c:2114 <= flush output I (33240) mbedtls: ssl_msg.c:5012 => write change cipher spec I (33247) mbedtls: ssl_msg.c:2542 => write handshake message I (33253) mbedtls: ssl_msg.c:2701 => write record I (33259) mbedtls: ssl_msg.c:2102 => flush output I (33265) mbedtls: ssl_msg.c:2122 message length: 6, out_left: 6 I (33272) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 6 (-0xfffffffa) I (33279) mbedtls: ssl_msg.c:2155 <= flush output I (33285) mbedtls: ssl_msg.c:2870 <= write record I (33290) mbedtls: ssl_msg.c:2678 <= write handshake message I (33297) mbedtls: ssl_msg.c:5026 <= write change cipher spec I (33310) mbedtls: ssl_cli.c:4483 client state: 11 I (33315) mbedtls: ssl_msg.c:2102 => flush output I (33321) mbedtls: ssl_msg.c:2114 <= flush output I (33327) mbedtls: ssl_tls.c:3533 => write finished I (33332) mbedtls: ssl_tls.c:3323 => calc finished tls sha256 I (33340) mbedtls: ssl_tls.c:3349 <= calc finished I (33345) mbedtls: ssl_msg.c:2542 => write handshake message I (33351) mbedtls: ssl_msg.c:2701 => write record I (33357) mbedtls: ssl_msg.c:632 => encrypt buf I (33363) mbedtls: ssl_msg.c:1120 <= encrypt buf I (33368) mbedtls: ssl_msg.c:2102 => flush output I (33373) mbedtls: ssl_msg.c:2122 message length: 45, out_left: 45 I (33381) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 45 (-0xffffffd3) I (33388) mbedtls: ssl_msg.c:2155 <= flush output I (33393) mbedtls: ssl_msg.c:2870 <= write record I (33399) mbedtls: ssl_msg.c:2678 <= write handshake message I (33405) mbedtls: ssl_tls.c:3642 <= write finished I (33418) mbedtls: ssl_cli.c:4483 client state: 12 I (33423) mbedtls: ssl_msg.c:2102 => flush output I (33429) mbedtls: ssl_msg.c:2114 <= flush output I (33435) mbedtls: ssl_cli.c:4365 => parse new session ticket I (33441) mbedtls: ssl_msg.c:3941 => read record I (33446) mbedtls: ssl_msg.c:1886 => fetch input I (33452) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5 I (33479) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5 I (33480) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) I (33483) mbedtls: ssl_msg.c:2089 <= fetch input I (33489) mbedtls: ssl_msg.c:1886 => fetch input I (33494) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 191 I (33501) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 191 I (33507) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 186 (-0xffffff46) I (33516) mbedtls: ssl_msg.c:2089 <= fetch input I (33523) mbedtls: ssl_msg.c:4015 <= read record I (33527) mbedtls: ssl_cli.c:4467 <= parse new session ticket I (33540) mbedtls: ssl_cli.c:4483 client state: 12 I (33545) mbedtls: ssl_msg.c:2102 => flush output I (33551) mbedtls: ssl_msg.c:2114 <= flush output I (33556) mbedtls: ssl_msg.c:5035 => parse change cipher spec I (33563) mbedtls: ssl_msg.c:3941 => read record I (33568) mbedtls: ssl_msg.c:1886 => fetch input I (33574) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5 I (33580) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5 I (33586) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) I (33595) mbedtls: ssl_msg.c:2089 <= fetch input I (33600) mbedtls: ssl_msg.c:1886 => fetch input I (33606) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 6 I (33612) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 6 I (33618) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 1 (-0xffffffff) I (33626) mbedtls: ssl_msg.c:2089 <= fetch input I (33632) mbedtls: ssl_msg.c:4015 <= read record I (33637) mbedtls: ssl_msg.c:5099 <= parse change cipher spec I (33651) mbedtls: ssl_cli.c:4483 client state: 13 I (33656) mbedtls: ssl_msg.c:2102 => flush output I (33662) mbedtls: ssl_msg.c:2114 <= flush output I (33667) mbedtls: ssl_tls.c:3659 => parse finished I (33673) mbedtls: ssl_tls.c:3323 => calc finished tls sha256 I (33681) mbedtls: ssl_tls.c:3349 <= calc finished I (33685) mbedtls: ssl_msg.c:3941 => read record I (33691) mbedtls: ssl_msg.c:1886 => fetch input I (33696) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5 I (33703) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5 I (33709) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) I (33717) mbedtls: ssl_msg.c:2089 <= fetch input I (33723) mbedtls: ssl_msg.c:1886 => fetch input I (33728) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 45 I (33734) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 45 I (33740) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 40 (-0xffffffd8) I (33749) mbedtls: ssl_msg.c:2089 <= fetch input I (33755) mbedtls: ssl_msg.c:1144 => decrypt buf I (33761) mbedtls: ssl_msg.c:1741 <= decrypt buf I (33766) mbedtls: ssl_msg.c:4015 <= read record I (33771) mbedtls: ssl_tls.c:3730 <= parse finished I (33783) mbedtls: ssl_cli.c:4483 client state: 14 I (33789) mbedtls: ssl_msg.c:2102 => flush output I (33794) mbedtls: ssl_msg.c:2114 <= flush output I (33800) mbedtls: ssl_cli.c:4594 handshake: done I (33812) mbedtls: ssl_cli.c:4483 client state: 15 I (33817) mbedtls: ssl_msg.c:2102 => flush output I (33823) mbedtls: ssl_msg.c:2114 <= flush output I (33841) mbedtls: ssl_tls.c:5920 <= handshake E (33846) esp-tls-mbedtls: -------send time3=32597ms esp_mbedtls_handshake I (33855) mbedtls: ssl_msg.c:5820 => write I (33859) mbedtls: ssl_msg.c:2701 => write record I (33864) mbedtls: ssl_msg.c:632 => encrypt buf I (33873) mbedtls: ssl_msg.c:1120 <= encrypt buf I (33877) mbedtls: ssl_msg.c:2102 => flush output I (33881) mbedtls: ssl_msg.c:2122 message length: 238, out_left: 238 I (33889) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 238 (-0xffffff12) I (33896) mbedtls: ssl_msg.c:2155 <= flush output I (33901) mbedtls: ssl_msg.c:2870 <= write record I (33907) mbedtls: ssl_msg.c:5848 <= write I (33913) mbedtls: ssl_msg.c:5820 => write I (33917) mbedtls: ssl_msg.c:2701 => write record I (33922) mbedtls: ssl_msg.c:632 => encrypt buf I (33970) mbedtls: ssl_msg.c:1120 <= encrypt buf I (33998) mbedtls: ssl_msg.c:2102 => flush output I (33998) mbedtls: ssl_msg.c:2122 message length: 4125, out_left: 4125 I (34002) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 4125 (-0xffffefe3) I (34008) mbedtls: ssl_msg.c:2155 <= flush output I (34013) mbedtls: ssl_msg.c:2870 <= write record I (34019) mbedtls: ssl_msg.c:5848 <= write I (34024) mbedtls: ssl_msg.c:5820 => write I (34029) mbedtls: ssl_msg.c:2701 => write record I (34034) mbedtls: ssl_msg.c:632 => encrypt buf I (34083) mbedtls: ssl_msg.c:1120 <= encrypt buf I (34112) mbedtls: ssl_msg.c:2102 => flush output I (34112) mbedtls: ssl_msg.c:2122 message length: 4125, out_left: 4125 I (34116) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 4125 (-0xffffefe3) I (34122) mbedtls: ssl_msg.c:2155 <= flush output I (34127) mbedtls: ssl_msg.c:2870 <= write record I (34133) mbedtls: ssl_msg.c:5848 <= write I (34138) mbedtls: ssl_msg.c:5820 => write I (34143) mbedtls: ssl_msg.c:2701 => write record I (34148) mbedtls: ssl_msg.c:632 => encrypt buf I (34197) mbedtls: ssl_msg.c:1120 <= encrypt buf I (34225) mbedtls: ssl_msg.c:2102 => flush output I (34226) mbedtls: ssl_msg.c:2122 message length: 4125, out_left: 4125 I (34229) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 4125 (-0xffffefe3) I (34235) mbedtls: ssl_msg.c:2155 <= flush output I (34241) mbedtls: ssl_msg.c:2870 <= write record I (34246) mbedtls: ssl_msg.c:5848 <= write I (34251) mbedtls: ssl_msg.c:5820 => write I (34256) mbedtls: ssl_msg.c:2701 => write record I (34262) mbedtls: ssl_msg.c:632 => encrypt buf I (34310) mbedtls: ssl_msg.c:1120 <= encrypt buf I (34338) mbedtls: ssl_msg.c:2102 => flush output I (34339) mbedtls: ssl_msg.c:2122 message length: 4125, out_left: 4125 I (34342) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 4125 (-0xffffefe3) I (34348) mbedtls: ssl_msg.c:2155 <= flush output I (34354) mbedtls: ssl_msg.c:2870 <= write record I (34359) mbedtls: ssl_msg.c:5848 <= write I (34364) mbedtls: ssl_msg.c:5820 => write I (34369) mbedtls: ssl_msg.c:2701 => write record I (34375) mbedtls: ssl_msg.c:632 => encrypt buf I (34424) mbedtls: ssl_msg.c:1120 <= encrypt buf I (34452) mbedtls: ssl_msg.c:2102 => flush output I (34452) mbedtls: ssl_msg.c:2122 message length: 4125, out_left: 4125 I (34456) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 4125 (-0xffffefe3) I (34462) mbedtls: ssl_msg.c:2155 <= flush output I (34467) mbedtls: ssl_msg.c:2870 <= write record I (34473) mbedtls: ssl_msg.c:5848 <= write I (34478) mbedtls: ssl_msg.c:5820 => write I (34483) mbedtls: ssl_msg.c:2701 => write record I (34488) mbedtls: ssl_msg.c:632 => encrypt buf I (34517) mbedtls: ssl_msg.c:1120 <= encrypt buf I (34532) mbedtls: ssl_msg.c:2102 => flush output I (34533) mbedtls: ssl_msg.c:2122 message length: 2102, out_left: 2102 I (34536) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 2102 (-0xfffff7ca) I (34542) mbedtls: ssl_msg.c:2155 <= flush output I (34548) mbedtls: ssl_msg.c:2870 <= write record I (34553) mbedtls: ssl_msg.c:5848 <= write I (34625) mbedtls: ssl_msg.c:5399 => read I (34626) mbedtls: ssl_msg.c:3941 => read record I (34627) mbedtls: ssl_msg.c:1886 => fetch input I (34631) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5 I (34637) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5 I (34643) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) I (34652) mbedtls: ssl_msg.c:2089 <= fetch input I (34657) mbedtls: ssl_msg.c:1886 => fetch input I (34662) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 994 I (34670) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 994 I (34675) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 989 (-0xfffffc23) I (34684) mbedtls: ssl_msg.c:2089 <= fetch input I (34696) mbedtls: ssl_msg.c:1144 => decrypt buf I (34700) mbedtls: ssl_msg.c:1741 <= decrypt buf I (34707) mbedtls: ssl_msg.c:4015 <= read record I (34708) mbedtls: ssl_msg.c:5693 <= read I (34711) mbedtls: ssl_msg.c:5399 => read I (34715) mbedtls: ssl_msg.c:5693 <= read I (34721) HTTP_CLIENT: Body received in fetch header state, 0x3fcb4de2, 177 I (34729) mbedtls: ssl_msg.c:5399 => read I (34733) mbedtls: ssl_msg.c:3941 => read record I (34738) mbedtls: ssl_msg.c:1886 => fetch input I (34744) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5 I (34750) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5 I (34756) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) I (34764) mbedtls: ssl_msg.c:2089 <= fetch input I (34770) mbedtls: ssl_msg.c:1886 => fetch input I (34775) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 34 I (34782) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 34 I (34788) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 29 (-0xffffffe3) I (34796) mbedtls: ssl_msg.c:2089 <= fetch input I (34802) mbedtls: ssl_msg.c:1144 => decrypt buf I (34808) mbedtls: ssl_msg.c:1741 <= decrypt buf I (34813) mbedtls: ssl_msg.c:4015 <= read record I (34818) mbedtls: ssl_msg.c:5693 <= read I (34823) ms_http_client: end_time 2:33574 I (34828) ms_http_client: average_time 2:2111:2999 I (34833) ms_http_client: HTTP POST Status = 200, content_length = -1 |
在ESP32-S3上使用HTTPS时,握手耗时较长可能是由于多种原因导致的。以下是一些建议和优化方法,以帮助您减少握手时间:
1. **网络环境**:确保您的设备连接到稳定的网络环境。网络延迟和不稳定可能会影响HTTPS握手时间。 2. **服务器性能**:检查服务器的性能和响应时间。如果服务器响应较慢,可能会导致握手时间较长。 3. **证书大小**:证书的大小可能会影响握手时间。尝试使用较小的证书,或者使用更高效的证书格式,如DER格式。 4. **使用预共享密钥**:如果可能,使用预共享密钥(PSK)进行TLS握手。PSK可以减少握手过程中的计算和通信开销。 5. **优化mbedtls配置**:尝试调整mbedtls的配置选项,以提高性能。例如,您可以使用以下配置: ```c mbedtls_ssl_conf_min_version(&conf, MBEDTLS_SSL_MAJOR_VERSION_3, MBEDTLS_SSL_MINOR_VERSION_3); mbedtls_ssl_conf_max_version(&conf, MBEDTLS_SSL_MAJOR_VERSION_3, MBEDTLS_SSL_MINOR_VERSION_3); mbedtls_ssl_conf_ciphersuites(&conf, mbedtls_ssl_list_ciphersuites()); ``` 6. **减少重传次数**:调整ESP32-S3的网络配置,减少因网络问题导致的重传次数。例如,您可以调整TCP重传次数和超时时间。 7. **使用硬件加速**:如果您的ESP32-S3支持硬件加速,尝试启用硬件加速以提高性能。 8. **优化代码**:检查您的代码,确保没有不必要的延迟或阻塞操作。优化代码逻辑,减少等待时间和资源占用。 9. **更新固件和库**:确保您的ESP32-S3固件和相关库是最新版本。新版本可能包含性能改进和bug修复。 10. **调试和分析**:使用调试工具和日志记录,分析HTTPS握手过程中的耗时和性能瓶颈。这可以帮助您找到问题所在并进行针对性的优化。 综上所述,通过优化网络环境、服务器性能、证书配置、mbedtls配置、代码逻辑等方面,您可以有效地减少ESP32-S3在HTTPS握手过程中的耗时。同时,确保使用最新版本的固件和库,以及利用硬件加速等特性,进一步提高性能。 |
171个成员聚集在这个小组
加入小组341 浏览 0 评论
1186 浏览 1 评论
587浏览 6评论
484浏览 5评论
468浏览 5评论
467浏览 4评论
443浏览 4评论
GMT+8, 2024-12-28 07:31 , Processed in 0.795168 second(s), Total 47, Slave 41 queries .
