1. 使用 esp-idf 5.1 稳定版
2. 使用 ble_hid_device_demo 示例,未做任何修改。 问题: 第一次苹果13是能正确连接上设备的,并且断开之后也能正常自动重连。慢速的开关苹果手机蓝牙也使能自动重连的。快速的开关几次手机蓝牙之后,发现不会自动重连,手动重连也不行。必须要重新绑定之后才能进行连接。 Code: Select all I (22) boot: ESP-IDF v5.1 2nd stage bootloaderI (23) boot: compile time Oct 19 2023 17:18:34I (23) boot: Multicore bootloaderI (26) boot: chip revision: v0.1I (29) boot.esp32s3: Boot SPI Speed : 80MHzI (34) boot.esp32s3: SPI Mode : DIOI (39) boot.esp32s3: SPI Flash Size : 2MBI (44) boot: Enabling RNG early entropy source...I (49) boot: Partition Table:I (53) boot: ## Label Usage Type ST Offset LengthI (60) boot: 0 nvs WiFi data 01 02 00009000 00006000I (67) boot: 1 phy_init RF data 01 01 0000f000 00001000I (75) boot: 2 factory factory app 00 00 00010000 00100000I (82) boot: End of partition tableI (86) esp_image: segment 0: paddr=00010020 vaddr=3c080020 size=20c00h (134144) mapI (119) esp_image: segment 1: paddr=00030c28 vaddr=3fc96d00 size=03f58h ( 16216) loadI (123) esp_image: segment 2: paddr=00034b88 vaddr=40374000 size=0b490h ( 46224) loadI (135) esp_image: segment 3: paddr=00040020 vaddr=42000020 size=785a0h (492960) mapI (224) esp_image: segment 4: paddr=000b85c8 vaddr=4037f490 size=07774h ( 30580) loadI (239) boot: Loaded app from partition at offset 0x10000I (239) boot: Disabling RNG early entropy source...I (250) cpu_start: Multicore appI (251) cpu_start: Pro cpu up.I (251) cpu_start: Starting app cpu, entry point is 0x4037541c0x4037541c: call_start_cpu1 at /home/navi/esp/esp-idf/components/esp_system/port/cpu_start.c:154I (0) cpu_start: App cpu up.I (269) cpu_start: Pro cpu start user codeI (269) cpu_start: cpu freq: 160000000 HzI (269) cpu_start: Application information:I (272) cpu_start: Project name: hidd_demosI (277) cpu_start: App version: 1I (282) cpu_start: Compile time: Oct 19 2023 17:18:28I (288) cpu_start: ELF file SHA256: 69e3ecd8510776e7...I (294) cpu_start: ESP-IDF: v5.1I (298) cpu_start: Min chip rev: v0.0I (303) cpu_start: Max chip rev: v0.99 I (308) cpu_start: Chip rev: v0.1I (313) heap_init: Initializing. RAM available for dynamic allocation:I (320) heap_init: At 3FC9ED20 len 0004A9F0 (298 KiB): DRAMI (326) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DRAMI (333) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAMI (339) heap_init: At 600FE010 len 00001FF0 (7 KiB): RTCRAMI (346) spi_flash: detected chip: gdI (349) spi_flash: flash io: dioW (353) spi_flash: Detected size(8192k) larger than the size in the binary image header(2048k). Using the size in the binary image header.I (367) sleep: Configure to isolate all GPIO pins in sleep stateI (373) sleep: Enable automatic switching of GPIO sleep configurationI (380) coexist: coex firmware version: ebddf30I (386) coexist: coexist rom version e7ae62fI (391) app_start: Starting scheduler on CPU0I (396) app_start: Starting scheduler on CPU1I (396) main_task: Started on CPU0I (406) main_task: Calling app_main()I (416) BLE_INIT: BT controller compile version [85b425c]I (416) phy_init: phy_version 601,fe52df4,May 10 2023,17:26:54I (466) BLE_INIT: Bluetooth MAC: f4:12:fa:83:1d:e2W (486) BT_BTM: BTM_BleWriteAdvData, Partial data write into ADVI (496) HID_LE_PRF: esp_hidd_prf_cb_hdl(), start added the hid service to the stack database. incl_handle = 40I (496) HID_LE_PRF: hid svc handle = 2dI (506) main_task: Returned from app_main()I (59516) HID_LE_PRF: HID connection establish, conn_id = 0I (59516) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (61626) HID_DEMO: remote BD_ADDR: 542e4b0c8dbaI (61626) HID_DEMO: address type = 1I (61626) HID_DEMO: pair status = successI (63506) HID_DEMO: Send the volumeI (71506) HID_DEMO: Send the volumeW (71526) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (71526) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (74436) HID_LE_PRF: HID connection establish, conn_id = 0I (74436) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (74746) HID_DEMO: remote BD_ADDR: 542e4b0c8dbaI (74746) HID_DEMO: address type = 1I (74746) HID_DEMO: pair status = successI (79506) HID_DEMO: Send the volumeW (79836) BT_GATT: gatt_ind_ack_timeout send ack nowI (87506) HID_DEMO: Send the volumeI (95506) HID_DEMO: Send the volumeW (97836) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (97836) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (100936) HID_LE_PRF: HID connection establish, conn_id = 0I (100936) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (101236) HID_DEMO: remote BD_ADDR: 542e4b0c8dbaI (101236) HID_DEMO: address type = 1I (101236) HID_DEMO: pair status = successI (103506) HID_DEMO: Send the volumeW (106286) BT_GATT: gatt_ind_ack_timeout send ack nowI (111506) HID_DEMO: Send the volumeW (117036) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (117036) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (122996) HID_LE_PRF: HID connection establish, conn_id = 0I (123006) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (123406) HID_DEMO: remote BD_ADDR: 542e4b0c8dbaI (123406) HID_DEMO: address type = 1I (123406) HID_DEMO: pair status = successI (123506) HID_DEMO: Send the volumeW (128446) BT_GATT: gatt_ind_ack_timeout send ack nowI (131506) HID_DEMO: Send the volumeW (133296) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (133296) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (136866) HID_LE_PRF: HID connection establish, conn_id = 0I (136866) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (137226) HID_DEMO: remote BD_ADDR: 542e4b0c8dbaI (137226) HID_DEMO: address type = 1I (137226) HID_DEMO: pair status = successI (139506) HID_DEMO: Send the volumeW (142266) BT_GATT: gatt_ind_ack_timeout send ack nowI (147506) HID_DEMO: Send the volumeI (155506) HID_DEMO: Send the volumeI (163506) HID_DEMO: Send the volumeW (166966) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (166966) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTW (171286) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x3eI (172436) HID_LE_PRF: HID connection establish, conn_id = 0I (172436) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (172736) HID_DEMO: remote BD_ADDR: 542e4b0c8dbaI (172736) HID_DEMO: address type = 1I (172736) HID_DEMO: pair status = successI (173506) HID_DEMO: Send the volumeW (173936) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (173936) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (177066) HID_LE_PRF: HID connection establish, conn_id = 0I (177066) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (177366) HID_DEMO: remote BD_ADDR: 542e4b0c8dbaI (177366) HID_DEMO: address type = 1I (177366) HID_DEMO: pair status = successW (180016) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (180016) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (183126) HID_LE_PRF: HID connection establish, conn_id = 0I (183126) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (183436) HID_DEMO: remote BD_ADDR: 542e4b0c8dbaI (183436) HID_DEMO: address type = 1I (183436) HID_DEMO: pair status = successI (183506) HID_DEMO: Send the volumeW (188126) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (188126) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (191056) HID_LE_PRF: HID connection establish, conn_id = 0I (191056) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (191366) HID_DEMO: remote BD_ADDR: 542e4b0c8dbaI (191366) HID_DEMO: address type = 1I (191366) HID_DEMO: pair status = successI (191506) HID_DEMO: Send the volumeW (196406) BT_GATT: gatt_ind_ack_timeout send ack nowI (199506) HID_DEMO: Send the volumeW (203056) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (203056) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (219256) HID_LE_PRF: HID connection establish, conn_id = 0I (219256) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (221926) HID_DEMO: remote BD_ADDR: 542e4b0c8dbaI (221926) HID_DEMO: address type = 1I (221926) HID_DEMO: pair status = successI (223506) HID_DEMO: Send the volumeW (228756) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (228756) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (250916) HID_LE_PRF: HID connection establish, conn_id = 0I (250916) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (251556) HID_DEMO: remote BD_ADDR: 542e4b0c8dbaI (251566) HID_DEMO: address type = 1I (251566) HID_DEMO: pair status = successI (253506) HID_DEMO: Send the volumeW (256016) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (256016) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (259146) HID_LE_PRF: HID connection establish, conn_id = 0I (259146) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (259596) HID_DEMO: remote BD_ADDR: 542e4b0c8dbaI (259596) HID_DEMO: address type = 1I (259596) HID_DEMO: pair status = successI (261506) HID_DEMO: Send the volumeW (264646) BT_GATT: gatt_ind_ack_timeout send ack nowI (269506) HID_DEMO: Send the volumeI (277506) HID_DEMO: Send the volumeI (285506) HID_DEMO: Send the volumeI (293506) HID_DEMO: Send the volumeI (301506) HID_DEMO: Send the volumeI (309506) HID_DEMO: Send the volumeI (317506) HID_DEMO: Send the volumeI (325506) HID_DEMO: Send the volumeI (333506) HID_DEMO: Send the volumeI (338096) HID_DEMO: ESP_HIDD_EVENT_BLE_LED_REPORT_WRITE_EVTI (338096) HID_DEMO: 00 I (341506) HID_DEMO: Send the volumeI (342196) HID_DEMO: ESP_HIDD_EVENT_BLE_LED_REPORT_WRITE_EVTI (342196) HID_DEMO: 00 I (349506) HID_DEMO: Send the volumeI (357506) HID_DEMO: Send the volumeI (359096) HID_DEMO: ESP_HIDD_EVENT_BLE_LED_REPORT_WRITE_EVTI (359096) HID_DEMO: 00 I (365506) HID_DEMO: Send the volumeI (373506) HID_DEMO: Send the volumeI (375896) HID_DEMO: ESP_HIDD_EVENT_BLE_LED_REPORT_WRITE_EVTI (375896) HID_DEMO: 00 I (381506) HID_DEMO: Send the volumeI (389506) HID_DEMO: Send the volumeI (397506) HID_DEMO: Send the volumeI (405506) HID_DEMO: Send the volumeI (413506) HID_DEMO: Send the volumeI (421506) HID_DEMO: Send the volumeI (429506) HID_DEMO: Send the volumeI (437506) HID_DEMO: Send the volumeI (445506) HID_DEMO: Send the volumeI (453506) HID_DEMO: Send the volumeI (461506) HID_DEMO: Send the volumeI (469506) HID_DEMO: Send the volumeI (477506) HID_DEMO: Send the volumeI (485506) HID_DEMO: Send the volumeI (493506) HID_DEMO: Send the volumeI (501506) HID_DEMO: Send the volumeI (505486) HID_DEMO: ESP_HIDD_EVENT_BLE_LED_REPORT_WRITE_EVTI (505486) HID_DEMO: 00 I (509506) HID_DEMO: Send the volumeI (517506) HID_DEMO: Send the volumeI (525506) HID_DEMO: Send the volumeI (533506) HID_DEMO: Send the volumeI (541506) HID_DEMO: Send the volumeI (549506) HID_DEMO: Send the volumeI (557506) HID_DEMO: Send the volumeI (565506) HID_DEMO: Send the volumeI (573506) HID_DEMO: Send the volumeI (581506) HID_DEMO: Send the volumeI (589506) HID_DEMO: Send the volumeI (597506) HID_DEMO: Send the volumeI (605506) HID_DEMO: Send the volumeI (613506) HID_DEMO: Send the volumeI (621506) HID_DEMO: Send the volumeI (629506) HID_DEMO: Send the volumeI (637506) HID_DEMO: Send the volumeI (645506) HID_DEMO: Send the volumeI (653506) HID_DEMO: Send the volumeI (661506) HID_DEMO: Send the volumeI (669506) HID_DEMO: Send the volumeI (677506) HID_DEMO: Send the volumeI (685506) HID_DEMO: Send the volumeI (693506) HID_DEMO: Send the volumeI (701506) HID_DEMO: Send the volumeI (709506) HID_DEMO: Send the volumeI (711326) HID_DEMO: ESP_HIDD_EVENT_BLE_LED_REPORT_WRITE_EVTI (711336) HID_DEMO: 00 I (717506) HID_DEMO: Send the volumeI (725506) HID_DEMO: Send the volumeW (728376) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (728386) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (901156) HID_LE_PRF: HID connection establish, conn_id = 0I (901156) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (902806) BT_GATT: gatts_write_attr_perm_check - GATT_INSUF_AUTHENTICATIONI (903806) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (903806) HID_DEMO: address type = 1I (903806) HID_DEMO: pair status = successI (905506) HID_DEMO: Send the volumeI (913506) HID_DEMO: Send the volumeW (913826) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (913826) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (917866) HID_LE_PRF: HID connection establish, conn_id = 0I (917866) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (917866) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (917876) HID_DEMO: address type = 1I (917876) HID_DEMO: pair status = successI (921506) HID_DEMO: Send the volumeW (925006) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (925006) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (927136) HID_LE_PRF: HID connection establish, conn_id = 0I (927136) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (927136) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (927146) HID_DEMO: address type = 1I (927146) HID_DEMO: pair status = successI (929506) HID_DEMO: Send the volumeW (929626) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (929626) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (932026) HID_LE_PRF: HID connection establish, conn_id = 0I (932026) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (932026) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (932026) HID_DEMO: address type = 1I (932036) HID_DEMO: pair status = successW (933466) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (933466) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTW (935566) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (935566) BT_HCI: CC evt: op=0x2022, status=0x2I (935566) HID_LE_PRF: HID connection establish, conn_id = 0I (935566) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (935576) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (935586) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (938776) HID_LE_PRF: HID connection establish, conn_id = 0I (938776) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (938776) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (938776) HID_DEMO: address type = 1I (938786) HID_DEMO: pair status = successI (939506) HID_DEMO: Send the volumeW (943096) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (943096) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (945226) HID_LE_PRF: HID connection establish, conn_id = 0I (945226) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (945226) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (945226) HID_DEMO: address type = 1I (945236) HID_DEMO: pair status = successW (946726) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (946726) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (948436) HID_LE_PRF: HID connection establish, conn_id = 0I (948436) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (948676) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (948676) HID_DEMO: address type = 1I (948676) HID_DEMO: pair status = successW (949186) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (949186) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (950866) HID_LE_PRF: HID connection establish, conn_id = 0I (950866) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (951106) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (951106) HID_DEMO: address type = 1I (951106) HID_DEMO: pair status = successI (951506) HID_DEMO: Send the volumeW (952696) BT_L2CAP: le con upd: err_stat=0x13W (952696) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (952696) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (953836) HID_LE_PRF: HID connection establish, conn_id = 0I (953836) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (954136) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (954136) HID_DEMO: address type = 1I (954136) HID_DEMO: pair status = successW (955666) BT_L2CAP: le con upd: err_stat=0x13W (955666) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (955666) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (957466) HID_LE_PRF: HID connection establish, conn_id = 0I (957466) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (957706) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (957706) HID_DEMO: address type = 1I (957706) HID_DEMO: pair status = successW (958936) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (958936) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (960646) HID_LE_PRF: HID connection establish, conn_id = 0I (960646) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (960886) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (960886) HID_DEMO: address type = 1I (960886) HID_DEMO: pair status = successI (961506) HID_DEMO: Send the volumeW (962326) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (962326) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (964126) HID_LE_PRF: HID connection establish, conn_id = 0I (964126) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (964126) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (964126) HID_DEMO: address type = 1I (964136) HID_DEMO: pair status = successW (965806) BT_L2CAP: le con upd: err_stat=0x13W (965806) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (965806) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (966886) HID_LE_PRF: HID connection establish, conn_id = 0I (966886) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (967126) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (967126) HID_DEMO: address type = 1I (967126) HID_DEMO: pair status = successW (967636) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (967636) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (969226) HID_LE_PRF: HID connection establish, conn_id = 0I (969226) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (969226) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (969226) HID_DEMO: address type = 1I (969236) HID_DEMO: pair status = successW (969286) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (969286) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (970696) HID_LE_PRF: HID connection establish, conn_id = 0I (970696) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (970906) BT_BTM: Device not foundW (970906) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (970906) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (970956) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (970956) HID_DEMO: address type = 1I (970956) HID_DEMO: pair status = failE (970956) HID_DEMO: fail reason = 0x66I (971506) HID_DEMO: Send the volumeI (972406) HID_LE_PRF: HID connection establish, conn_id = 0I (972406) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (972586) BT_BTM: Device not foundW (972586) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (972586) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (972596) HID_DEMO: remote BD_ADDR: 76b2f9e913d8I (972596) HID_DEMO: address type = 1I (972596) HID_DEMO: pair status = failE (972606) HID_DEMO: fail reason = 0x66W (972886) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (972886) BT_HCI: CC evt: op=0x2022, status=0x2I (972886) HID_LE_PRF: HID connection establish, conn_id = 0I (972886) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (972896) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (972896) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (973846) HID_LE_PRF: HID connection establish, conn_id = 0I (973846) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (973996) BT_BTM: Device not foundW (973996) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (973996) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (974006) HID_DEMO: remote BD_ADDR: 54965ef97e35I (974006) HID_DEMO: address type = 1I (974006) HID_DEMO: pair status = failE (974016) HID_DEMO: fail reason = 0x66W (974296) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (974296) BT_HCI: CC evt: op=0x2022, status=0x2I (974296) HID_LE_PRF: HID connection establish, conn_id = 0I (974296) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (974306) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (974306) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (975856) HID_LE_PRF: HID connection establish, conn_id = 0I (975856) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (976036) BT_BTM: Device not foundW (976036) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (976036) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (976046) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (976046) HID_DEMO: address type = 1I (976046) HID_DEMO: pair status = failE (976056) HID_DEMO: fail reason = 0x66I (976246) HID_LE_PRF: HID connection establish, conn_id = 0I (976246) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (976426) BT_BTM: Device not foundW (976426) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (976426) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (976436) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (976436) HID_DEMO: address type = 1I (976436) HID_DEMO: pair status = failE (976446) HID_DEMO: fail reason = 0x66W (976696) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (976696) BT_HCI: CC evt: op=0x2022, status=0x2I (976696) HID_LE_PRF: HID connection establish, conn_id = 0I (976696) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (976706) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (976706) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (977086) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (977086) BT_HCI: CC evt: op=0x2022, status=0x2I (977086) HID_LE_PRF: HID connection establish, conn_id = 0I (977086) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (977096) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (977096) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (977296) HID_LE_PRF: HID connection establish, conn_id = 0I (977296) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (977476) BT_BTM: Device not foundW (977476) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (977476) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (977486) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (977486) HID_DEMO: address type = 1I (977486) HID_DEMO: pair status = failE (977496) HID_DEMO: fail reason = 0x66W (978136) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (978136) BT_HCI: CC evt: op=0x2022, status=0x2I (978136) HID_LE_PRF: HID connection establish, conn_id = 0I (978136) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (978146) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (978146) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (979216) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (979216) BT_HCI: CC evt: op=0x2022, status=0x2I (979216) HID_LE_PRF: HID connection establish, conn_id = 0I (979216) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (979226) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (979226) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (979426) HID_LE_PRF: HID connection establish, conn_id = 0I (979426) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (979576) BT_BTM: Device not foundW (979576) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (979576) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (979586) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (979586) HID_DEMO: address type = 1I (979586) HID_DEMO: pair status = failE (979596) HID_DEMO: fail reason = 0x66I (980176) HID_LE_PRF: HID connection establish, conn_id = 0I (980176) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (980356) BT_BTM: Device not foundW (980356) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (980356) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (980366) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (980366) HID_DEMO: address type = 1I (980366) HID_DEMO: pair status = failE (980376) HID_DEMO: fail reason = 0x66I (980536) HID_LE_PRF: HID connection establish, conn_id = 0I (980536) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (980716) BT_BTM: Device not foundW (980716) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (980716) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (980726) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (980726) HID_DEMO: address type = 1I (980726) HID_DEMO: pair status = failE (980736) HID_DEMO: fail reason = 0x66W (981166) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (981166) BT_HCI: CC evt: op=0x2022, status=0x2I (981166) HID_LE_PRF: HID connection establish, conn_id = 0I (981166) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (981176) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (981176) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (981376) HID_LE_PRF: HID connection establish, conn_id = 0I (981376) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (981556) BT_BTM: Device not foundW (981556) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (981556) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (981566) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (981566) HID_DEMO: address type = 1I (981566) HID_DEMO: pair status = failE (981576) HID_DEMO: fail reason = 0x66I (983506) HID_DEMO: Send the volumeW (983716) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (983716) BT_HCI: CC evt: op=0x2022, status=0x2I (983716) HID_LE_PRF: HID connection establish, conn_id = 0I (983716) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (983726) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (983726) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (984016) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (984016) BT_HCI: CC evt: op=0x2022, status=0x2I (984016) HID_LE_PRF: HID connection establish, conn_id = 0I (984016) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (984026) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (984026) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (984616) HID_LE_PRF: HID connection establish, conn_id = 0I (984616) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (984796) BT_BTM: Device not foundW (984796) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (984796) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (984806) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (984806) HID_DEMO: address type = 1I (984806) HID_DEMO: pair status = failE (984816) HID_DEMO: fail reason = 0x66W (985096) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (985096) BT_HCI: CC evt: op=0x2022, status=0x2I (985096) HID_LE_PRF: HID connection establish, conn_id = 0I (985096) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (985106) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (985106) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (985486) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (985486) BT_HCI: CC evt: op=0x2022, status=0x2I (985486) HID_LE_PRF: HID connection establish, conn_id = 0I (985486) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (985496) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (985496) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (985786) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (985786) BT_HCI: CC evt: op=0x2022, status=0x2I (985786) HID_LE_PRF: HID connection establish, conn_id = 0I (985786) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (985796) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (985796) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (986086) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (986086) BT_HCI: CC evt: op=0x2022, status=0x2I (986086) HID_LE_PRF: HID connection establish, conn_id = 0I (986086) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (986096) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (986096) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (986566) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (986566) BT_HCI: CC evt: op=0x2022, status=0x2I (986566) HID_LE_PRF: HID connection establish, conn_id = 0I (986566) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (986576) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (986576) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (986776) HID_LE_PRF: HID connection establish, conn_id = 0I (986776) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (986986) BT_BTM: Device not foundW (986986) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (986986) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (986996) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (986996) HID_DEMO: address type = 1I (986996) HID_DEMO: pair status = failE (987006) HID_DEMO: fail reason = 0x66W (987256) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (987256) BT_HCI: CC evt: op=0x2022, status=0x2I (987256) HID_LE_PRF: HID connection establish, conn_id = 0I (987256) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (987266) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (987266) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (987646) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (987646) BT_HCI: CC evt: op=0x2022, status=0x2I (987646) HID_LE_PRF: HID connection establish, conn_id = 0I (987646) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (987656) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (987656) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (987946) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (987946) BT_HCI: CC evt: op=0x2022, status=0x2I (987946) HID_LE_PRF: HID connection establish, conn_id = 0I (987946) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (987956) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (987956) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (988186) HID_LE_PRF: HID connection establish, conn_id = 0I (988186) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (988396) BT_BTM: Device not foundW (988396) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (988396) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (988406) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (988406) HID_DEMO: address type = 1I (988406) HID_DEMO: pair status = failE (988416) HID_DEMO: fail reason = 0x66I (988906) HID_LE_PRF: HID connection establish, conn_id = 0I (988906) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (989086) BT_BTM: Device not foundW (989086) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (989086) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (989096) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (989096) HID_DEMO: address type = 1I (989096) HID_DEMO: pair status = failE (989106) HID_DEMO: fail reason = 0x66W (989386) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (989386) BT_HCI: CC evt: op=0x2022, status=0x2I (989386) HID_LE_PRF: HID connection establish, conn_id = 0I (989386) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (989396) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (989396) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (989596) HID_LE_PRF: HID connection establish, conn_id = 0I (989596) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (989776) BT_BTM: Device not foundW (989776) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (989776) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (989786) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (989786) HID_DEMO: address type = 1I (989786) HID_DEMO: pair status = failE (989796) HID_DEMO: fail reason = 0x66W (990076) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (990076) BT_HCI: CC evt: op=0x2022, status=0x2I (990076) HID_LE_PRF: HID connection establish, conn_id = 0I (990076) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (990086) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (990086) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (990316) HID_LE_PRF: HID connection establish, conn_id = 0I (990316) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (990526) BT_BTM: Device not foundW (990526) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (990526) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (990536) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (990536) HID_DEMO: address type = 1I (990536) HID_DEMO: pair status = failE (990546) HID_DEMO: fail reason = 0x66I (991216) HID_LE_PRF: HID connection establish, conn_id = 0I (991216) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (991396) BT_BTM: Device not foundW (991396) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (991396) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (991406) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (991406) HID_DEMO: address type = 1I (991406) HID_DEMO: pair status = failE (991416) HID_DEMO: fail reason = 0x66I (991506) HID_DEMO: Send the volumeI (993136) HID_LE_PRF: HID connection establish, conn_id = 0I (993136) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (993316) BT_BTM: Device not foundW (993316) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (993316) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (993326) HID_DEMO: remote BD_ADDR: 7aedae8c7576I (993326) HID_DEMO: address type = 1I (993326) HID_DEMO: pair status = failE (993326) HID_DEMO: fail reason = 0x66W (993376) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (999506) HID_DEMO: Send the volumeI (1007506) HID_DEMO: Send the volumeI (1015506) HID_DEMO: Send the volumeI (1021866) HID_LE_PRF: HID connection establish, conn_id = 0I (1021876) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (1022046) BT_BTM: Device not foundW (1022056) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (1022056) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (1022056) HID_DEMO: remote BD_ADDR: 7da5d335b282I (1022066) HID_DEMO: address type = 1I (1022066) HID_DEMO: pair status = failE (1022066) HID_DEMO: fail reason = 0x66W (1022376) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1022386) BT_HCI: CC evt: op=0x2022, status=0x2I (1022386) HID_LE_PRF: HID connection establish, conn_id = 0I (1022386) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1022396) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1022396) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (1022586) HID_LE_PRF: HID connection establish, conn_id = 0I (1022586) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (1022766) BT_BTM: Device not foundW (1022776) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (1022776) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (1022776) HID_DEMO: remote BD_ADDR: 7da5d335b282I (1022786) HID_DEMO: address type = 1I (1022786) HID_DEMO: pair status = failE (1022786) HID_DEMO: fail reason = 0x66I (1023506) HID_DEMO: Send the volumeW (1023816) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1023826) BT_HCI: CC evt: op=0x2022, status=0x2I (1023826) HID_LE_PRF: HID connection establish, conn_id = 0I (1023826) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1023836) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1023836) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (1024146) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1024156) BT_HCI: CC evt: op=0x2022, status=0x2I (1024156) HID_LE_PRF: HID connection establish, conn_id = 0I (1024156) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1024166) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1024166) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (1024536) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1024546) BT_HCI: CC evt: op=0x2022, status=0x2I (1024546) HID_LE_PRF: HID connection establish, conn_id = 0I (1024546) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1024556) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1024556) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (1024896) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1024906) BT_HCI: CC evt: op=0x2022, status=0x2I (1024906) HID_LE_PRF: HID connection establish, conn_id = 0I (1024906) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1024916) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1024916) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (1025076) HID_LE_PRF: HID connection establish, conn_id = 0I (1025076) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (1025256) BT_BTM: Device not foundW (1025266) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (1025266) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (1025266) HID_DEMO: remote BD_ADDR: 7da5d335b282I (1025276) HID_DEMO: address type = 1I (1025276) HID_DEMO: pair status = failE (1025276) HID_DEMO: fail reason = 0x66W (1025916) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1025926) BT_HCI: CC evt: op=0x2022, status=0x2I (1025926) HID_LE_PRF: HID connection establish, conn_id = 0I (1025926) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1025936) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1025936) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (1026336) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1026346) BT_HCI: CC evt: op=0x2022, status=0x2I (1026346) HID_LE_PRF: HID connection establish, conn_id = 0I (1026346) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1026356) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1026356) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (1026756) HID_LE_PRF: HID connection establish, conn_id = 0I (1026756) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (1026966) BT_BTM: Device not foundW (1026976) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (1026976) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (1026976) HID_DEMO: remote BD_ADDR: 7da5d335b282I (1026986) HID_DEMO: address type = 1I (1026986) HID_DEMO: pair status = failE (1026986) HID_DEMO: fail reason = 0x66W (1027236) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1027246) BT_HCI: CC evt: op=0x2022, status=0x2I (1027246) HID_LE_PRF: HID connection establish, conn_id = 0I (1027246) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1027256) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1027256) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (1027446) HID_LE_PRF: HID connection establish, conn_id = 0I (1027446) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (1027626) BT_BTM: Device not foundW (1027636) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (1027636) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (1027636) HID_DEMO: remote BD_ADDR: 7da5d335b282I (1027646) HID_DEMO: address type = 1I (1027646) HID_DEMO: pair status = failE (1027646) HID_DEMO: fail reason = 0x66W (1027926) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1027936) BT_HCI: CC evt: op=0x2022, status=0x2I (1027936) HID_LE_PRF: HID connection establish, conn_id = 0I (1027936) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1027946) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1027946) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorI (1028856) HID_LE_PRF: HID connection establish, conn_id = 0I (1028856) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTE (1029036) BT_BTM: Device not foundW (1029046) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13I (1029046) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTI (1029046) HID_DEMO: remote BD_ADDR: 7da5d335b282I (1029056) HID_DEMO: address type = 1I (1029056) HID_DEMO: pair status = failE (1029056) HID_DEMO: fail reason = 0x66W (1029636) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1029646) BT_HCI: CC evt: op=0x2022, status=0x2I (1029646) HID_LE_PRF: HID connection establish, conn_id = 0I (1029646) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1029656) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1029656) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (1029796) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1029796) BT_HCI: CC evt: op=0x2022, status=0x2I (1029796) HID_LE_PRF: HID connection establish, conn_id = 0I (1029796) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1029806) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1029806) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (1042566) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1042576) BT_HCI: CC evt: op=0x2022, status=0x2I (1042576) HID_LE_PRF: HID connection establish, conn_id = 0I (1042576) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1042586) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1042586) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (1043016) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1043026) BT_HCI: CC evt: op=0x2022, status=0x2I (1043026) HID_LE_PRF: HID connection establish, conn_id = 0I (1043026) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1043036) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1043036) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state errorW (1043496) BT_HCI: hcif disc complete: hdl 0x1, rsn 0x13E (1043506) BT_HCI: CC evt: op=0x2022, status=0x2I (1043506) HID_LE_PRF: HID connection establish, conn_id = 0I (1043506) HID_DEMO: ESP_HIDD_EVENT_BLE_CONNECTI (1043516) HID_DEMO: ESP_HIDD_EVENT_BLE_DISCONNECTE (1043516) BT_APPL: bta_dm_set_encryption, not find peer_bdaddr or peer_bdaddr connection state error |
根据您提供的信息,您使用的是ESP32-S3开发板,基于ESP-IDF 5.1稳定版,并使用了ble_hid_device_demo示例。您遇到的问题是在快速开关苹果手机蓝牙几次后,设备无法自动重连,手动重连也无法成功,需要重新绑定才能连接。
这个问题可能有以下几个原因: 1. **蓝牙配对信息存储问题**:ESP32-S3可能在存储配对信息时遇到了问题,导致在快速开关蓝牙时无法正确恢复之前的配对状态。 2. **ESP32-S3的BLE堆栈稳定性**:虽然ESP-IDF 5.1是稳定版,但可能在BLE HID设备与苹果手机的交互中存在一些未被发现的bug,导致在快速开关蓝牙时出现连接问题。 3. **苹果手机的蓝牙管理策略**:苹果手机可能在快速开关蓝牙时采取了一些安全或节能措施,导致与ESP32-S3的连接出现问题。 4. **示例代码的局限性**:虽然您没有对示例代码进行修改,但示例代码可能没有考虑到所有可能的连接场景,导致在特定情况下无法正常工作。 为了解决这个问题,您可以尝试以下方法: 1. **更新ESP-IDF**:检查是否有更新版本的ESP-IDF,可能已经修复了这个问题。 2. **修改示例代码**:尝试对示例代码进行一些修改,例如增加错误处理逻辑,以便在连接失败时能够更好地诊断问题。 3. **检查日志**:使用ESP-IDF的日志系统,记录ESP32-S3在连接过程中的详细信息,以便分析问题所在。 4. **联系威廉希尔官方网站 支持**:如果问题仍然无法解决,您可以联系ESP-IDF的威廉希尔官方网站 支持或社区寻求帮助。 5. **测试其他设备**:尝试使用其他型号的苹果手机或其他品牌的智能手机,看看问题是否仍然存在,这有助于确定问题是否与特定的设备或系统有关。 6. **调整蓝牙开关速度**:虽然这不是根本解决方案,但可以作为一种临时措施,避免快速开关蓝牙,以减少问题的发生。 希望这些建议能帮助您解决问题。如果问题仍然存在,请提供更多的信息,例如ESP32-S3的日志输出,以便进一步分析。 |
191个成员聚集在这个小组
加入小组470 浏览 1 评论
1640 浏览 2 评论
641浏览 6评论
536浏览 5评论
515浏览 5评论
517浏览 4评论
507浏览 4评论
GMT+8, 2025-2-23 01:30 , Processed in 0.920708 second(s), Total 77, Slave 61 queries .
