我发送数据量为640个十六进制数据是正常的,上位机有收到书籍。但是我想发送3600个数据就一直灭有反应,不知道为啥什么,求助。我使用的是A9,A10的usart接口。以下是部分代码
#include "STM32f10x.h" // Device header #include #include void Serial_Init(void) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, GPIO_InitStructure); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, GPIO_InitStructure); USART_InitTypeDef USART_InitStructure; USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_Init(USART1, USART_InitStructure); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); NVIC_InitTypeDef NVIC_InitStructure; NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_Init( NVIC_InitStructure); USART_Cmd(USART1, ENABLE); } void Serial_SendByte(uint8_t Byte) { USART_SendData(USART1, Byte); while (USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); } void Serial_SendArray(uint8_t *Array, uint16_t Length) { uint16_t i; for (i = 0; i < Length; i ++) { Serial_SendByte(Array[i]); } } 然后我定义了一个数组arra[3600],用 Serial_SendArray函数发送后没有反应 |
根据您提供的信息,您在使用STM32F103C8T6的USART接口发送大量十六进制数据时遇到了问题。当发送640个数据时,一切正常,但是当尝试发送3600个数据时,上位机没有收到数据。以下是一些建议和可能的原因:
1. **缓冲区溢出**:当发送大量数据时,可能存在缓冲区溢出的问题。请检查您的代码中是否有适当的缓冲区管理,以确保数据不会丢失。 2. **中断处理**:请确保您正确地配置了USART的中断,并在中断服务程序中正确地处理数据。如果中断处理不当,可能会导致数据发送失败。 3. **波特率设置**:请检查您的波特率设置是否正确。如果波特率设置不正确,可能会导致数据传输速度过慢,从而导致数据丢失。 4. **硬件连接**:请检查您的硬件连接是否正确,包括USART接口的引脚连接和上位机的串口设置。如果硬件连接有问题,可能会导致数据传输失败。 5. **代码优化**:请检查您的代码是否有优化空间,例如减少循环次数、使用更高效的数据传输方法等。优化代码可以提高数据传输的效率。 6. **调试**:在发送大量数据时,尝试在代码中添加一些调试信息,例如打印发送数据的数量、检查USART的状态等。这可以帮助您找到问题的根源。 7. **串口助手**:如果您使用的是串口助手等工具进行数据接收,请确保该工具能够处理大量数据的接收。有些工具可能在接收大量数据时会出现性能问题。 8. **电源稳定性**:请确保您的开发板电源稳定,因为不稳定的电源可能会影响USART的性能。 综上所述,您需要检查代码、硬件连接、波特率设置等多个方面,以找到导致大量数据发送失败的原因。希望这些建议对您有所帮助。 |
2107 浏览 1 评论
1828 浏览 1 评论
1303 浏览 2 评论
853 浏览 2 评论
2191 浏览 2 评论
2092浏览 9评论
998浏览 4评论
385浏览 3评论
715浏览 3评论
703浏览 3评论
GMT+8, 2025-3-31 15:41 , Processed in 0.909635 second(s), Total 48, Slave 42 queries .
