先上程序
#include "STM32f10x.h" #include #include "touwenjian.h" extern uint8_t ch; extern uint8_t flog; int main(void) { USART1_Init(); nvic_Init(); while(flog==1) { USART_SendData(USART1, ch); while( USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET ); flog=0; } } 下面是中断程序 void USART1_IRQHandler(void) { if(USART_GetiTStatus(USART1,USART_IT_RXNE)!=RESET) { ch=USART_ReceiveData(USART1); while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET){} flog=1; } } 配置程序 void nvic_Init(void) { NVIC_InitTypeDef NVIC_InitStructure; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x02; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x03; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init( NVIC_InitStructure); } void USART1_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA , GPIO_InitStructure); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_Init(GPIOA , GPIO_InitStructure); USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1, USART_InitStructure); USART_ITConfig(USART1,USART_IT_RXNE,ENABLE); USART_Cmd(USART1, ENABLE); } 问题是我硬件仿真的时候他进入了 void BusFault_Handler(void) { /* Go to infinite loop when Bus Fault exception occurs */ while (1) { } }这个总线错误中断 |
单步仿真一下,看看走到哪儿进入的这个中断。
请按照以下步骤操作:
1. 确保时钟配置正确:在初始化USART1之前,请确保已正确配置了时钟。这包括设置APB2时钟、设置USART1时钟源等。 2. 检查GPIO配置:确保您已正确配置了USART1的TX和RX引脚。这包括设置引脚模式(例如:推挽输出、浮空输入等)、设置引脚速度等。 3. 检查USART1初始化参数:确保您在调用`USART1_Init()`函数时,传递了正确的参数。这包括波特率、字长、停止位、奇偶校验位等。 4. 检查中断配置:确保您已正确配置了NVIC(嵌套向量中断控制器)以处理USART1中断。这包括设置优先级、使能中断等。 5. 检查中断服务例程:确保您的中断服务例程(ISR)正确处理了USART1中断。这包括读取接收到的数据、发送数据等。 6. 检查总线错误中断:在STM32F10x系列微控制器中,总线错误中断通常与内存访问错误有关。请检查您的程序中是否有不合法的内存访问,例如访问未初始化的指针、数组越界等。 7. 使用调试工具:如果问题仍然存在,建议您使用调试工具(例如:ST-LINK、J-Link等)逐步调试您的程序,以找到导致总线错误中断的确切位置。 8. 更新固件库:确保您使用的STM32F10x固件库是最新版本,以避免可能的已知问题。 |
1928 浏览 1 评论
1700 浏览 1 评论
1181 浏览 2 评论
781 浏览 2 评论
1747 浏览 2 评论
1986浏览 9评论
822浏览 4评论
269浏览 3评论
634浏览 3评论
638浏览 3评论
GMT+8, 2025-2-1 08:06 , Processed in 0.687929 second(s), Total 47, Slave 42 queries .
