CO_Data ObjDict_Data = CANOPEN_NODE_DATA_INItiALIZER(ObjDict);
IAR编译提示Error[Pe253]: expected a "," 错误指向CO_Data Error[Pe253]: expected a "," 错误指向CO_Data Error[Pe253]: expected a "," 错误指向CANOPEN_NODE_DATA_INITIALIZER(ObjDict) 自己比对发现并没有什么问题,但一直编译不过,希望可以指出来什么问题!什么感谢! 其中CO_Data 为如下结构体: struct struct_CO_Data { //* Object dictionary UNS8 *bDeviceNodeId; //节点地址 const indextable *objdict; s_PDO_status *PDO_status; //PDO传输类型 INTEGER16 *RxPDO_EventTimers; void (*RxPDO_EventTimers_Handler)(CO_Data*, UNS32); const quick_index *firstIndex;//起始索引 const quick_index *lastIndex;//终止索引 const UNS16 *ObjdictSize; const UNS8 *iam_a_slave; valueRangeTest_t valueRangeTest; // SDO s_transfer transfers[SDO_MAX_SIMULTANEOUS_TRANSFERTS]; // State machine e_nodeState nodeState; s_state_communication CurrentCommunicationState; initialisation_t initialisation; preOperational_t preOperational; operational_t operational; stopped_t stopped; void (*NMT_Slave_Node_Reset_Callback)(CO_Data*); void (*NMT_Slave_Communications_Reset_Callback)(CO_Data*); // NMT-heartbeat UNS8 *ConsumerHeartbeatCount; UNS32 *ConsumerHeartbeatEntries; INTEGER16 *ConsumerHeartBeatTimers; UNS16 *ProducerHeartBeatTime; INTEGER16 ProducerHeartBeatTimer; heartbeatError_t heartbeatError; e_nodeState NMTable[NMT_MAX_NODE_ID]; // /* NMT-nodeguarding */ INTEGER16 GuardTimeTimer; INTEGER16 LifeTimeTimer; nodeguardError_t nodeguardError; UNS16 *GuardTime; UNS8 *LifeTimeFactor; UNS8 nodeGuardStatus[NMT_MAX_NODE_ID]; // SYNC INTEGER16 syncTimer; UNS32 *COB_ID_Sync;//只可写入0x80(同步器不工作)与0x40000080(激活同步发生器) UNS32 *Sync_Cycle_Period;//同步周期 post_sync_t post_sync; post_TPDO_t post_TPDO; post_SlaveBootup_t post_SlaveBootup; post_SlaveStateChange_t post_SlaveStateChange; //General UNS8 toggle; CAN_PORT canHandle; //选择CAN1或者CAN2 scanIndexOD_t scanIndexOD; // storeODSubIndex_t storeODSubIndex; // DCF concise const indextable* dcf_odentry; UNS8* dcf_cursor; UNS32 dcf_entries_count; UNS8 dcf_status; UNS32 dcf_size; UNS8* dcf_data; // EMCY e_errorState error_state; UNS8 error_history_size; UNS8* error_number; UNS32* error_first_element; UNS8* error_register; UNS32* error_cobid; s_errors error_data[EMCY_MAX_ERRORS]; post_emcy_t post_emcy; }; CANOPEN_NODE_DATA_INITIALIZER(ObjDict);为如下宏定义 #define CANOPEN_NODE_DATA_INITIALIZER(NODE_PREFIX){ /* Object dictionary*/ NODE_PREFIX ## _bDeviceNodeId, /* bDeviceNodeId */ NODE_PREFIX ## _objdict, /* objdict */ NODE_PREFIX ## _PDO_status, /* PDO_status */ NULL, /* RxPDO_EventTimers */ _RxPDO_EventTimers_Handler, /* RxPDO_EventTimers_Handler */ NODE_PREFIX ## _firstIndex, /* firstIndex */ NODE_PREFIX ## _lastIndex, /* lastIndex */ NODE_PREFIX ## _ObjdictSize, /* ObjdictSize */ NODE_PREFIX ## _iam_a_slave, /* iam_a_slave */ NODE_PREFIX ## _valueRangeTest, /* valueRangeTest */ /* SDO, structure s_transfer */ { REPEAT_SDO_MAX_SIMULTANEOUS_TRANSFERS_TIMES(s_transfer_Initializer) }, /* State machine*/ Unknown_state, /* nodeState */ /* structure s_state_communication */ { 0, /* csBoot_Up */ 0, /* csSDO */ 0, /* csEmergency */ 0, /* csSYNC */ 0, /* csHeartbeat */ 0, /* csPDO */ 0 /* csLSS */ }, _initialisation, /* initialisation */ _preOperational, /* preOperational */ _operational, /* operational */ _stopped, /* stopped */ NULL, /* NMT node reset callback */ NULL, /* NMT communications reset callback */ /* NMT-heartbeat */ NODE_PREFIX ## _highestSubIndex_obj1016, /* ConsumerHeartbeatCount */ NODE_PREFIX ## _obj1016, /* ConsumerHeartbeatEntries */ NODE_PREFIX ## _heartBeatTimers, /* ConsumerHeartBeatTimers */ NODE_PREFIX ## _obj1017, /* ProducerHeartBeatTime */ TIMER_NONE, /* ProducerHeartBeatTimer */ _heartbeatError, /* heartbeatError */ {REPEAT_NMT_MAX_NODE_ID_TIMES(NMTable_Initializer)}, /* is well initialized at "Unknown_state". Is it ok ? (FD)*/ /* NMT-nodeguarding */ TIMER_NONE, /* GuardTimeTimer */ TIMER_NONE, /* LifeTimeTimer */ _nodeguardError, /* nodeguardError */ NODE_PREFIX ## _obj100C, /* GuardTime */ NODE_PREFIX ## _obj100D, /* LifeTimeFactor */ {REPEAT_NMT_MAX_NODE_ID_TIMES(nodeGuardStatus_Initializer)}, /* SYNC */ TIMER_NONE, /* syncTimer */ NODE_PREFIX ## _obj1005, /* COB_ID_Sync */ NODE_PREFIX ## _obj1006, /* Sync_Cycle_Period */ /* NODE_PREFIX ## _obj1007, */ /* Sync_window_length */ _post_sync, /* post_sync */ _post_TPDO, /* post_TPDO */ _post_SlaveBootup, /* post_SlaveBootup */ _post_SlaveStateChange, /* post_SlaveStateChange */ /* General */ 0, /* toggle */ NULL, /* canSend */ NODE_PREFIX ## _scanIndexOD, /* scanIndexOD */ _storeODSubIndex, /* storeODSubIndex */ /* DCF concise */ NULL, /*dcf_odentry*/ NULL, /*dcf_cursor*/ 1, /*dcf_entries_count*/ 0, /* dcf_status*/ 0, /* dcf_size */ NULL, /* dcf_data */ /* EMCY */ Error_free, /* error_state */ sizeof(NODE_PREFIX ## _obj1003) / sizeof(NODE_PREFIX ## _obj1003[0]), /* error_history_size */ NODE_PREFIX ## _highestSubIndex_obj1003, /* error_number */ NODE_PREFIX ## _obj1003[0], /* error_first_element */ NODE_PREFIX ## _obj1001, /* error_register */ NODE_PREFIX ## _obj1014, /* error_cobid */ /* error_data: structure s_errors */ { REPEAT_EMCY_MAX_ERRORS_TIMES(ERROR_DATA_INITIALIZER) }, _post_emcy, /* post_emcy */ } |
根据您提供的信息,您在尝试移植CANopen协议时遇到了编译错误。错误提示是关于逗号的,这通常是由于语法错误导致的。以下是一些建议,以帮助您解决这个问题:
1. 检查您的代码中的逗号是否正确。确保在结构体初始化列表中,每个成员后面都有一个逗号,除了最后一个成员。 2. 检查您的CANopen协议库是否与您的项目兼容。确保您使用的库版本与您的项目设置相匹配。 3. 检查您的项目设置,确保编译器和链接器设置正确。这可能包括检查编译器选项、包含路径、库路径等。 4. 检查您的代码中是否有其他语法错误。有时候,编译器可能会在错误的地方报告错误,但实际上问题可能在其他地方。 5. 如果您使用的是第三方CANopen协议库,请查阅相关文档,以确保您正确地使用了库中的宏和函数。 6. 如果问题仍然存在,您可以尝试在其他IDE或编译器中编译您的项目,以确定问题是否与IAR编译器有关。 |
1907 浏览 1 评论
1678 浏览 1 评论
1171 浏览 2 评论
770 浏览 2 评论
1730 浏览 2 评论
1970浏览 9评论
805浏览 4评论
253浏览 3评论
623浏览 3评论
634浏览 3评论
GMT+8, 2025-1-22 23:19 , Processed in 0.862833 second(s), Total 79, Slave 62 queries .
