想用ST MC电机库进行BLDC开发,实际要求电机可以快速切换正反转,但实际实验过程中却无法实现,两方向切换过程中必须要延时一些时间,否则反向无法正常启动。感觉就像是要“缓一下”才行,但这缓
的时间也太长了,我测试时则需500ms或以上(如下程序红色语句所示),想请教下这是什么原因。 开发套件为NUCLEO-IHM01,电机库版本为5.3,测试代码如下: int main(void) { /* USER CODE BEGIN 1 */ int16_t Motor1Speed,Motor1SpeedAverage; int16_t Motor1Dir; uint16_t Motor1State,Motor1Faults; /* USER CODE END 1 */ /* MCU Configuration--------------------------------------------------------*/ /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* USER CODE BEGIN Init */ /* USER CODE END Init */ /* Configure the system clock */ SystemClock_Config(); /* USER CODE BEGIN SysInit */ /* USER CODE END SysInit */ /* Initialize all configured peripherals */ MX_GPIO_Init(); MX_ADC1_Init(); MX_DAC_Init(); MX_TIM1_Init(); MX_USART2_UART_Init(); MX_MotorControl_Init(); /* Initialize interrupts */ MX_NVIC_Init(); /* USER CODE BEGIN 2 */ /* USER CODE END 2 */ /* Infinite loop */ /* USER CODE BEGIN WHILE */ while (1) { /* USER CODE END WHILE */ /* USER CODE BEGIN 3 */ MC_ProgramSpeedRampMotor1(100/6,600); MC_StartMotor1(); HAL_Delay(2000); Motor1Speed = MC_GetMecSpeedReferenceMotor1(); Motor1SpeedAverage = MC_GetMecSpeedAverageMotor1(); Motor1Dir = MC_GetImposedDirectionMotor1(); Motor1State = MC_GetSTMStateMotor1(); Motor1Faults = MC_GetOccurredFaultsMotor1(); if((Motor1State==10)||(Motor1State==11)) { MC_AcknowledgeFaultMotor1(); } MC_StopMotor1(); HAL_Delay(500); MC_ProgramSpeedRampMotor1(-100/6,600); MC_StartMotor1(); HAL_Delay(2000); Motor1Speed = MC_GetMecSpeedReferenceMotor1(); Motor1SpeedAverage = MC_GetMecSpeedAverageMotor1(); Motor1Dir = MC_GetImposedDirectionMotor1(); Motor1State = MC_GetSTMStateMotor1(); Motor1Faults = MC_GetOccurredFaultsMotor1(); if((Motor1State==10)||(Motor1State==11)) { MC_AcknowledgeFaultMotor1(); } MC_StopMotor1(); HAL_Delay(500); } /* USER CODE END 3 */ } |
改一下STOPPERMANENCY_MS 宏的值就可以了
2173 浏览 1 评论
1837 浏览 1 评论
1327 浏览 2 评论
869 浏览 2 评论
2206 浏览 2 评论
2111浏览 9评论
1024浏览 4评论
397浏览 3评论
723浏览 3评论
712浏览 3评论
GMT+8, 2025-4-10 22:07 , Processed in 1.046935 second(s), Total 78, Slave 61 queries .
