扫一扫,分享给好友
pads2007中PCB上元件属性中的Label 项中有5个Res.Des 和5个Part type ,即Res.Des -1 ,Res.Des -2 ,Res.Des -3 ,Res.Des -4 ,Res.Des -5 .除了TOP层有Res.des 外,在Assembly drawing top层也有相同的Res.Des,如C1,打开Assembly drawing top层后,有5个C1。
我将此PCB 导成Powerpcb3.5版本,然后将3.5版本的PCB在导入到protel 99se中,就出现下面错误, 求高手相助,如何让元件属性中Label 中只有一个Res.Des,和一个Part type ? 出现下面的转换错误,如何解决?多谢! Protel Design System: PADS PowerPCB To Protel 99 SE Translator Report PCB ASCII File : IP-7860MT_RevB Date : 12-Jul-2012 time : 16:59:13 Load Errors : 12495 Error loading label visibility attribute from line: 3323 Expected number in line: 3323 at position 5 and found this: Type Expected number in line: 3324 at position 0 and found this: **CRLF** Expected number in line: 3324 at position 0 and found this: **CRLF** Expected integer in line: 3324 at position 0 Expected number in line: 3324 at position 0 and found this: **CRLF** Expected number in line: 3324 at position 0 and found this: **CRLF** Error loading label mirrored attribute from line: 3324 Error loading label text justification attributes from line: 3324 Error loading label right-reading attribute from line: 3324 Error loading label visibility attribute from line: 3325 Expected number in line: 3326 at position 0 and found this: **CRLF** Expected number in line: 3326 at position 0 and found this: **CRLF** |
PADS Layout 在Bottom层添加测试点,被盖了绿油(同样的操作TOP层没有被绿油覆盖),怎么设置才能去掉绿油?
1666 浏览 1 评论
5933 浏览 0 评论
PADS DRC报焊盘之间距离过小,焊盘间距为7,但是规则的安全间距为5
13507 浏览 2 评论
16093 浏览 1 评论
PADS LOGICd 在做元件封装时导入CSV文件提示超出字符
80955 浏览 3 评论
GMT+8, 2024-9-21 04:26 , Processed in 0.522963 second(s), Total 71, Slave 54 queries .
