我手上有一块 32L4R9IDISCOVERY
然后,我在DEMO程序STM32Cube_FW_L4_V1.14.0Projects32L4R9IDISCOVERYExamplesDSIDSI_CmdMode_SingleBuffer基础上,添加了PSRAM初始化。PSRAM工作正常,并可以作为堆使用。 但当我把显存设置到PSRAM上的时候。 发现系统会进入到LTDC Error中断 LTDC_ER_IRQHandler 请问大大有测试过类似的问题吗? 谢谢 附:代码 显存配置 //__attribute__((section(".FrameBufferSection"))) __attribute__((section(".XRAMSection"))) __align(16) uint32_t PhysFrameBuffer[91260]; // 5 char buffer, 5*16 = 80 pixer PSRAM初始化 /* PSRAM device configuration */ /* Timing configuration derived from system clock (up to 120Mhz) for 60Mhz as PSRAM clock frequency */ Timing.AddressSetupTime = 4; Timing.AddressHoldTime = 2; Timing.DataSetupTime = 6; Timing.BusTurnAroundDuration = 1; Timing.CLKDivision = 2; Timing.DataLatency = 2; Timing.AccessMode = FMC_ACCESS_MODE_A; //FMC_ACCESS_MODE_A; psramHandle.Init.NSBank = FMC_NORSRAM_BANK1; psramHandle.Init.DataAddressMux = FMC_DATA_ADDRESS_MUX_DISABLE; psramHandle.Init.MemoryType = FMC_MEMORY_TYPE_PSRAM; psramHandle.Init.MemoryDataWidth = FMC_NORSRAM_MEM_BUS_WIDTH_16; psramHandle.Init.BurstAccessMode = FMC_BURST_ACCESS_MODE_DISABLE; psramHandle.Init.WaitSignalPolarity = FMC_WAIT_SIGNAL_POLARITY_HIGH; psramHandle.Init.WaitSignalActive = FMC_WAIT_TIMING_BEFORE_WS; psramHandle.Init.WriteOperation = FMC_WRITE_OPERATION_ENABLE; psramHandle.Init.WaitSignal = FMC_WAIT_SIGNAL_DISABLE; psramHandle.Init.ExtendedMode = FMC_EXTENDED_MODE_DISABLE; psramHandle.Init.AsynchronousWait = FMC_ASYNCHRONOUS_WAIT_DISABLE; psramHandle.Init.WriteBurst = FMC_WRITE_BURST_DISABLE; psramHandle.Init.ContinuousClock = FMC_CONTINUOUS_CLOCK_SYNC_ASYNC; psramHandle.Init.WriteFifo = FMC_WRITE_FIFO_DISABLE; psramHandle.Init.NBLSetupTime = 0; psramHandle.Init.PageSize = FMC_PAGE_SIZE_NONE; psramHandle.Instance = FMC_NORSRAM_DEVICE; psramHandle.Extended = FMC_NORSRAM_EXTENDED_DEVICE;
因为STM32L4R9-DISCO板上的PSRAM,DEMO中初始化为异步模式,读写速率较慢,直接用作framebuffer会出现带宽不匹配的问题,需要优化PSRAM参数配置,比如配置为burst mode,或同步模式,访问速率会大提高,同时也要结合LTDC配置,使PSRAM带宽与LTDC带宽需求相匹配。
2009 浏览 1 评论
1794 浏览 1 评论
1254 浏览 2 评论
830 浏览 2 评论
1816 浏览 2 评论
2048浏览 9评论
954浏览 4评论
348浏览 3评论
691浏览 3评论
673浏览 3评论
GMT+8, 2025-3-9 22:00 , Processed in 1.270191 second(s), Total 48, Slave 42 queries .
