define MAX6675_CS_Pin GPIO_PIN_12
define MAX6675_CS_GPIO_Port GPIOB SPI_HandleTypeDef hspi2;/ USER CODE BEGIN Includes / / USER CODE END Includes / / Private typedef -----------------------------------------------------------// USER CODE BEGIN TD / / USER CODE END TD / / Private define ------------------------------------------------------------// USER CODE BEGIN Define / / USER CODE END Define / / Private macro -------------------------------------------------------------// USER CODE BEGIN Macro / / USER CODE END Macro / / Private variables ---------------------------------------------------------// USER CODE BEGIN PV / / USER CODE END PV / / Private function prototypes -----------------------------------------------// USER CODE BEGIN PFP / / USER CODE END PFP / / External functions --------------------------------------------------------// USER CODE BEGIN ExternalFunctions / / USER CODE END ExternalFunctions / / USER CODE BEGIN 0 //**
/ USER CODE END SPI2_Init 0 / / USER CODE BEGIN SPI2_Init 1 / / USER CODE END SPI2_Init 1 // SPI2 parameter configuration/hspi2.Instance = SPI2;hspi2.Init.Mode = SPI_MODE_MASTER;hspi2.Init.Direction = SPI_DIRECTION_2LINES;hspi2.Init.DataSize = SPI_DATASIZE_8BIT;hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;hspi2.Init.CLKPhase = SPI_PHASE_1EDGE;hspi2.Init.NSS = SPI_NSS_SOFT;hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;hspi2.Init.TIMode = SPI_TIMODE_DISABLE;hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;hspi2.Init.CRCPolynomial = 7;hspi2.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;hspi2.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;if (HAL_SPI_Init( hspi2) != HAL_OK){Error_Handler();}}/ USER CODE END 0 /void HAL_MspInit(void){/ USER CODE BEGIN MspInit 0 / / USER CODE END MspInit 0 / HAL_RCC_SYSCFG_CLK_ENABLE();HAL_RCC_PWR_CLK_ENABLE(); / System interrupt init/ / USER CODE BEGIN MspInit 1 / / USER CODE END MspInit 1 /} /**
/ USER CODE BEGIN 1 / //MAX6675 片选引脚初始化void GPIO_Init(void){GPIO_InitTypeDef GPIO_InitStruct = {0}; / GPIO Ports Clock Enable /__HAL_RCC_GPIOB_CLK_ENABLE(); HAL_GPIO_WritePin(GPIOB, MAX6675_CS_Pin, GPIO_PIN_SET);/引脚配置 /GPIO_InitStruct.Pin = MAX6675_CS_Pin;GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;GPIO_InitStruct.Pull = GPIO_NOPULL;GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;HAL_GPIO_Init(GPIOB, GPIO_InitStruct);} /**
MAX6675测温不准的原因可能有以下几点:
1. 供电不稳定:MAX6675传感器需要稳定的供电电压,如果供电不稳定,可能会导致测温不准确。 2. 传感器故障:MAX6675传感器可能发生损坏或老化,导致测温不准确。 3. 环境影响:如果MAX6675传感器周围的环境温度或热量较大,可能会影响测温结果。 为解决MAX6675测温不准的问题,可以采取以下措施: 1. 检查供电电压:确保MAX6675传感器的供电电压稳定,可以通过使用稳压电源或者电容滤波器等方法来保证供电电压的稳定性。 2. 检查传感器连接:确保MAX6675传感器的接线正确、稳固,不要有松动或接触不良的情况。 3. 替换传感器:如果经过检查确认MAX6675传感器损坏或老化,可以考虑更换新的传感器。 4. 避免环境影响:如果MAX6675传感器周围有温度较高的元件或热源,应尽量隔离或避开,以减少环境影响。 5. 校准测温:可以通过与其他精确测温设备进行比对,对测温结果进行校准,以提高测温的准确性。 以上方法仅为一般参考,具体解决方案需要根据具体情况进行调试和优化。 |
1909 浏览 1 评论
1678 浏览 1 评论
1172 浏览 2 评论
771 浏览 2 评论
1732 浏览 2 评论
1970浏览 9评论
807浏览 4评论
255浏览 3评论
624浏览 3评论
634浏览 3评论
GMT+8, 2025-1-24 05:33 , Processed in 0.818975 second(s), Total 78, Slave 61 queries .
