扫一扫,分享给好友
如下图:
图1 对应的时钟与BPS的关系以及发送的逻辑
图2 对应的数据与BPS的对应关系
图3 要求的循环发送以及时间
对应的具体代码段如下:
module UART_transmit( input wire clk, input wire rst_n, input wire [7:0] data, //外部输入需要发送的数据 output reg uart_tx, output reg led ); parameter CNT_1S_MAX = 26'd50_000_000 - 1; parameter BPS_CNT_MAX = 16'd5208 - 1; //波特率的周期 reg [25:0] counter1; reg uart_state; // 0 busy 1 free reg [3:0] bit_counter; reg [15:0] bps_counter; reg bit_flag; reg [7:0] data_req; //对应的1S计数 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) counter1 <= 26'b0; else if( counter1 == CNT_1S_MAX ) counter1 <= 26'b0; else counter1 <= counter1 + 1'b1; //UART发送状态使能模块 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) uart_state <= 1'b0; else if( counter1 == CNT_1S_MAX || (bit_counter == 4'd10 && bps_counter == BPS_CNT_MAX) ) uart_state <= ~uart_state; else uart_state <= uart_state; //锁定外部输入的发送数据 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) data_req <= 8'b0; else if( counter1 == CNT_1S_MAX ) data_req <= data; else data_req <= data_req; //生成波特率发送信号 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) bps_counter <= 16'b0; else if( uart_state == 1'b1 )begin if ( bps_counter == BPS_CNT_MAX ) begin bps_counter <= 16'b0; end else bps_counter <= bps_counter + 1'b1; end else bps_counter <= 16'b0; //单位数据发送的标志信号 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) bit_flag <= 1'b0; else if( bps_counter == 16'd2603 ) bit_flag <= 1'b1; else bit_flag <= 1'b0; //bit计数 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) bit_counter <= 4'b0; else if( uart_state == 1'b1 ) begin if( bit_flag == 1'b1 ) bit_counter <= bit_counter + 1'b1; else if( bit_counter == 4'd10 && bps_counter == BPS_CNT_MAX ) bit_counter <= 4'b0; end else bit_counter <= 4'b0; //逐位发送数据 always @(posedge clk or negedge rst_n)begin if( rst_n == 1'b0 )begin uart_tx <= 1'b1; end else begin case( bit_counter ) 0 : uart_tx <= 1'b1; 1 : uart_tx <= 1'b0; 2 : uart_tx <= data_req[0]; 3 : uart_tx <= data_req[1]; 4 : uart_tx <= data_req[2]; 5 : uart_tx <= data_req[3]; 6 : uart_tx <= data_req[4]; 7 : uart_tx <= data_req[5]; 8 : uart_tx <= data_req[6]; 9 : uart_tx <= data_req[7]; 10: uart_tx <= 1'b1; default : uart_tx <= 1'b1; endcase end end //变更LED状态 always @(posedge clk or negedge rst_n) if( rst_n == 1'b0 ) led <= 1'b0; else if( bit_counter == 4'd10 && bps_counter == BPS_CNT_MAX ) led <= ~led; else led <= led; endmodule
对应的测试用的code,如下:
`timescale 1ns/1ns module tb_UART_transmit(); //****************** Parameter and Internal Signal *******************// //wire define wire led; wire uart_tx; //reg define reg clk; reg rst_n; reg [7:0] data; //***************************** Main Code ****************************// initial begin rst_n <= 1'b0; data <= 8'b1010_1010; #201 rst_n <= 1'b1; #300_000_00; data <= 8'b0101_0101; #300_000_00; $stop; end // creator clk initial clk = 1'b1; always #10 clk <= ~clk; defparam UART_transmit_inst.CNT_1S_MAX = 26'd500_000 - 1; //*************************** Instantiation **************************// UART_transmit UART_transmit_inst ( .clk ( clk ), .rst_n ( rst_n ), .data ( data ), .led ( led ), .uart_tx ( uart_tx ) ); endmodule
对应的仿真图,如下:
发布
FPGAUart串口fpga
紫光同创FPGA权威开发指南,原厂携手小眼睛科技威廉希尔官方网站 专家联合编著
AIBOX-3588M,为终端提供算力,基于RK3588平台!
教程!FPGA DDR4读写实验(1)
【有奖提问】关于盘古1K2K开发板你有什么想知道的?一起来留言获取答案吧!
盘古22K开发板
盘古200 pro开发板
盘古50 pro开发板
盘古50K开发板
盘古100 pro开发板
FPGA在图像处理领域的优势有哪些?
