使用STM32CubeProgrammer可以连接到芯片,但是不能擦除
15:17:06 : STM32CubeProgrammer API v2.12.0 | Windows-64Bits 15:17:10 : ST-LINK SN : 390A070A2416303030303032 15:17:10 : ST-LINK FW : V2J41S7 15:17:10 : Board : -- 15:17:10 : Voltage : 4.70V 15:17:10 : SWD freq : 4000 KHz 15:17:10 : Connect mode: Under Reset 15:17:10 : Reset mode : Hardware reset 15:17:10 : Device ID : 0x413 15:17:10 : Revision ID : Rev Y 15:17:10 : Debug in Low Power mode is not supported for this device. 15:17:11 : UPLOADING OPtiON BYTES DATA ... 15:17:11 : Bank : 0x00 15:17:11 : Address : 0x40023c14 15:17:11 : Size : 4 Bytes 15:17:11 : UPLOADING ... 15:17:11 : Size : 1024 Bytes 15:17:11 : Address : 0x8000000 15:17:11 : Read progress: 15:17:11 : Data read successfully 15:17:11 : Time elapsed during the read operation is: 00:00:00.007 15:18:01 : MASS ERASE ... 15:18:01 : Error: Mass erase operation failed.Please verify flash protection使用最新版本的STM32CUBEIDE 调试STM32F407ZGT6单片机报错信息 STMicroelectronics ST-LINK GDB server. Version 7.3.0Copyright (c) 2023, STMicroelectronics. All rights reserved.Starting server with the following options: Persistent Mode : Disabled Logging Level : 1 Listen Port Number : 61234 Status Refresh Delay : 15s Verbose Mode : Disabled SWD Debug : EnabledSTM32_SystemReset(), failure reset target.Waiting for debugger connection...Debugger connectedWaiting for debugger connection...Debugger connectedWaiting for debugger connection... ------------------------------------------------------------------- STM32CubeProgrammer v2.13.0 -------------------------------------------------------------------Log output file: C:UsersJohn9AppDataLocalTempSTM32CubeProgrammer_a12424.logST-LINK SN : 390A070A2416303030303032ST-LINK FW : V2J41S7Board : --Voltage : 3.14VSWD freq : 4000 KHzConnect mode: Under ResetReset mode : Hardware resetDevice ID : 0x413Revision ID : Rev YDevice name : STM32F405xx/F407xx/F415xx/F417xxFlash size : 1 MBytes (default)Device type : MCUDevice CPU : Cortex-M4BL Version : 0x91Memory Programming ...Opening and parsing file: ST-LINK_GDB_server_a12424.srec File : ST-LINK_GDB_server_a12424.srec Size : 39.39 KB Address : 0x08000000 Erasing memory corresponding to segment 0:Erasing internal memory sectors [0 2]Error: failed to erase memoryError: failed to erase memoryEncountered Error when opening P:ProgramSTMicroelectronicsSTM32CubeIDESTM32CubeIDEpluginscom.st.stm32cube.ide.mcu.externaltools.cubeprogrammer.win32_2.0.600.202301161003toolsbinSTM32_Programmer_CLI.exeError in STM32CubeProgrammerShutting down...Exit. |
用cubeprogrammer 工具连上后,能读取FLASH 和 option byte 的内容么?如果能读取的话,重点检查一下option byte的内容是否正常。
1975 浏览 1 评论
1760 浏览 1 评论
1232 浏览 2 评论
819 浏览 2 评论
1776 浏览 2 评论
2015浏览 9评论
889浏览 4评论
318浏览 3评论
670浏览 3评论
661浏览 3评论
GMT+8, 2025-2-23 13:02 , Processed in 0.685696 second(s), Total 45, Slave 39 queries .
