使用ST-LINK可以下载程序,但是在线调试出错。
STMicroelectronics ST-LINK GDB server. Version 5.8.0 Copyright (c) 2020, STMicroelectronics. All rights reserved. Starting server with the following options: Persistent Mode : Disabled LogFile Name : debug.log Logging Level : 31 Listen Port Number : 61235 Status Refresh Delay : 15s Verbose Mode : Disabled SWD Debug : Enabled Target connection mode: Default Reading ROM table for AP 0 @0xe00fffd0 Hardware watchpoint supported by the target COM frequency = 4000 kHz ST-LINK Firmware version : V2J35S7 Device ID: 0x413 PC: 0x8005ec0 ST-LINK device status: HALT_MODE ST-LINK detects target voltage = 3.16 V ST-LINK device status: HALT_MODE ST-LINK device initialization OK Waiting for debugger connection... Waiting for connection on port 61235... Accepted connection on port 61235... Debugger connected Wrapping read detected. Addr: 0xffffffff; Length: 4 Wrapping read detected. Addr: 0xffffffff; Length: 4 ------ Switching to STM32CubeProgrammer ----- ------------------------------------------------------------------- STM32CubeProgrammer v2.7.0-RC1 ------------------------------------------------------------------- Log output file: C:\Users\lml\AppData\Local\Temp\STM32CubeProgrammer_a06808.log ST-LINK SN : 3A1A151A7115303030303032 ST-LINK FW : V2J35S7 Board : -- Voltage : 3.16V Error: ST-LINK error (DEV_TARGET_NOT_HALTED) Encountered Error when opening D:\RT-ThreadStudio\repo\Extract\Debugger_Support_Packages\STMicroelectronics\ST-LINK_Debugger\1.6.0\tools\bin\STM32_Programmer_CLI.exe ------ Switching context ----- Error in STM32CubeProgrammer Debugger connection lost. Shutting down... |
检查一下,这些信息。gdb.exe跟我不一样的话,就改成我这个。一样就改成另一个路径:
159个成员聚集在这个小组
加入小组【Vision Board创客营连载体验】基于RA8D1-Vision Board的自动路径规划小车
953 浏览 0 评论
【Vision Board创客营连载体验】基于Vision Board的垃圾分类
1392 浏览 0 评论
【Vision Board创客营连载体验】使用 Vision Board 做一个 UVC Camera
1051 浏览 0 评论
【Vision Board创客营连载体验】TinyMaix进行手写数字识别
1286 浏览 0 评论
【Vision Board创客营连载体验】RA8D1-Vision Board使用7寸屏设置为RGB666大端模式模式成功显示摄像头图案
1350 浏览 0 评论
GMT+8, 2025-2-23 13:02 , Processed in 0.389135 second(s), Total 50, Slave 42 queries .
