嗨,亲爱的工程师、学生和爱好者们,我来啦!欢迎来到神秘的星嵌世界!如果你是一位FPGA工程师或者对嵌入式异构威廉希尔官方网站
感兴趣,那么你来到的地方绝对没错!今天,我们将一起探索一个令人惊叹的星嵌基于TI OMAP-L138(定点/浮点DSP C674x+ARM9)+ FPGA处理器的开发板。编写TI OMAP-L138与FPGA之间的通信驱动涉及到多个复杂步骤。我将为大家提供一个简化的概述。
首先,我们需要了解GPMC(General-Purpose Memory Controller)和EDMA(Enhanced Direct Memory Access)的基本概念。GPMC是ARM与FPGA之间的内存控制器,负责管理FPGA中的存储器。而EDMA是一种高速数据传输方式,可以让数据在内存和外设之间直接传输,提高通信效率。
接下来,我将用VHDL语言编写一个简单的程序,实现FPGA与ARM之间的GPMC通信。由于这个问题的专业性和威廉希尔官方网站
性非常强,且代码量较大,容我慢慢写。不过,现在我可以尝试以一种轻松的方式概述一下主要步骤和关键点。
编写一个完整的FPGA与OMAPL138开发板之间的GPMC(General Purpose Memory Controller)通信的VHDL代码是一项复杂的任务,它涉及到硬件接口、时序控制、协议转换等多个方面:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity FPGA_to_OMAPL138_GPMC is
Port ( FPGA_CLK : in STD_LOGIC;
GPMC_DATA : inout STD_LOGIC_VECTOR (31 downto 0);
GPMC_ADDR : out STD_LOGIC_VECTOR (31 downto 0);
GPMC_CMD : out STD_LOGIC_VECTOR (7 downto 0);
GPMC_BE : out STD_LOGIC_VECTOR (3 downto 0);
GPMC_WAIT : in STD_LOGIC;
FPGA_RESET : in STD_LOGIC;
FPGA_WRITE : in STD_LOGIC;
FPGA_READ : in STD_LOGIC;
FPGA_DATA_IN : in STD_LOGIC_VECTOR (31 downto 0);
FPGA_DATA_OUT: out STD_LOGIC_VECTOR (31 downto 0));
end FPGA_to_OMAPL138_GPMC;
architecture Behavioral of FPGA_to_OMAPL138_GPMC is
signal internal_address : STD_LOGIC_VECTOR (31 downto 0);
signal internal_cmd : STD_LOGIC_VECTOR (7 downto 0);
signal internal_be : STD_LOGIC_VECTOR (3 downto 0);
signal internal_write : STD_LOGIC;
signal internal_read : STD_LOGIC;
signal internal_data : STD_LOGIC_VECTOR (31 downto 0);
begin
process (FPGA_RESET)
begin
if FPGA_RESET = '1' then
internal_address <= (others => '0');
internal_cmd <= (others => '0');
internal_be <= (others => '0');
internal_write <= '0';
internal_read <= '0';
internal_data <= (others => '0');
end if;
end process;
process (FPGA_CLK, FPGA_RESET)
begin
FPGA_DATA_OUT <= (others => '0');
elsif rising_edge(FPGA_CLK) then
if FPGA_WRITE = '1' then
GPMC_DATA <= FPGA_DATA_IN;
internal_write <= '1';
elsif FPGA_READ = '1' then
FPGA_DATA_OUT <= GPMC_DATA;
internal_read <= '1';
else
FPGA_DATA_OUT <= FPGA_DATA_OUT;
internal_write <= internal_write;
internal_read <= internal_read;
end if;
GPMC_ADDR <= internal_address;
GPMC_CMD <= internal_cmd;
GPMC_BE <= internal_be;
end if;
end process;
end Behavioral;
由于编写完整的VHDL代码实现FPGA与OMAPL138开发板通过GPMC接口进行通信的程序相当复杂且篇幅较长。但我可以慢慢写以一种独特的方式概述一下主要步骤和关键点:
entity GPMC_Communication is
Port (
gpmc_clk : in std_logic;
gpmc_cs : in std_logic;
gpmc_addr : in std_logic_vector(31 downto 0);
gpmc_data_i : in std_logic_vector(31 downto 0);
gpmc_data_o : out std_logic_vector(31 downto 0);
end entity GPMC_Communication;
architecture Behavioral of GPMC_Communication is
begin
process(gpmc_clk)
begin
if rising_edge(gpmc_clk) then
if gpmc_cs = '1' then
gpmc_data_o <= our_crafty_response;
end if;
end if;
end process;
end architecture Behavioral;
我在编写FPGA与ARM之间的GPMC通信(开启EDMA)的VHDL代码时,需要考虑几个关键部分:GPMC接口的配置、EDMA的控制、以及与ARM之间的数据交换。
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity fpga_to_arm_gpmc_edma is
Port (
clk : in std_logic;
reset_n : in std_logic;
gpmc_addr : out std_logic_vector(31 downto 0);
gpmc_data_in : in std_logic_vector(31 downto 0);
gpmc_data_out : out std_logic_vector(31 downto 0);
gpmc_write_enable : out std_logic;
gpmc_read_enable : out std_logic;
edma_start : in std_logic;
edma_done : out std_logic;
edma_error : out std_logic
end fpga_to_arm_gpmc_edma;
architecture behavior of fpga_to_arm_gpmc_edma is
signal transfer_in_progress : boolean := false;
signal error_occurred : boolean := false;
begin
process(clk, reset_n)
begin
if reset_n = '0' then
transfer_in_progress <= false;
error_occurred <= false;
elsif rising_edge(clk) then
if edma_start = '1' and not transfer_in_progress then
transfer_in_progress <= true;
elsif edma_done = '1' and transfer_in_progress then
end if;
end if;
end process;
begin
gpmc_write_enable <= '0';
gpmc_read_enable <= '0';
if transfer_in_progress then
if edma_start = '1' then
gpmc_write_enable <= '1';
gpmc_addr <= std_logic_vector(to_unsigned(0, gpmc_addr'length));
elsif edma_done = '1' then
if error_occurred then
edma_error <= '1';
else
edma_error <= '0';
end if;
end if;
end if;
end if;
end process;
end behavior;
在FPGA与ARM的通信中,除了常见的GPMC、AXI等接口方式外,还有一些其他有趣且实用的通信方式,它们可能更加适合某些特定应用场景或提供不同的功能特点。以下是几种有趣的通信方式:
- SPI (Serial Peripheral Interface):
SPI是一种同步串行接口,通常用于短距离、高速通信。FPGA可以作为SPI的主设备或从设备,与ARM处理器进行通信。这种方式简单且功耗低,非常适合小型嵌入式系统。
- I2C (Inter-Integrated Circuit)/SMBus:
I2C是另一种串行通信协议,它使用两条线(SDA和SCL)进行双向通信。虽然速度没有SPI快,但它的优点是引脚少,且支持多主设备通信。FPGA和ARM可以通过I2C进行简单而有效的数据交换。 I2C/SMBus这是一个简单、双向的两线制同步串行总线,非常适合连接微控制器和各种外围设备。你可以想象FPGA和ARM通过“握手”和“点头”的方式来进行通信。
- UART (Universal Asynchronous Receiver/Transmitter):
UART是异步串行通信的常用方式。虽然它的速度可能不如SPI和I2C,但UART通信距离较长,且实现起来相对简单。FPGA和ARM之间通过UART可以实现基本的控制和数据传输。
- Ethernet:
对于需要长距离、高速、稳定通信的应用,以太网是个不错的选择。FPGA和ARM都可以配备以太网接口,通过TCP/IP协议栈进行通信。这种方式非常适合需要远程监控或控制的应用场景。
- 自定义并行接口:
在某些对性能要求极高的应用中,设计人员可能会选择实现自定义的并行接口。这种方式可以根据具体需求,优化数据宽度、传输速率等参数,以达到最佳性能。
- JTAG (Joint Test Action Group):
JTAG接口原本是为了芯片测试而设计的,但它也可以用于FPGA和ARM之间的低速通信。虽然它不适合大数据量的传输,但对于配置、调试或控制等任务来说,JTAG是个方便且实用的选择。
- PWM (Pulse Width Modulation) 或 GPIO (General-Purpose Input/Output):
在一些非常简单的应用中,可以使用PWM或GPIO信号进行通信。例如,通过改变PWM信号的占空比,可以传递不同的信息;而GPIO则可以用来表示简单的开关状态。
- LVDS (Low-Voltage Differential Signaling):
LVDS是一种低电压差分信号威廉希尔官方网站
,它可以在高速下提供稳定的信号传输。对于需要高速、低噪声通信的应用,LVDS是个不错的选择。
- 自定义协议:
如果你有足够的勇气和技能,你还可以设计自己的通信协议。这就像是为FPGA和ARM创造一种全新的“语言”,只有你们两个才能懂。这种方式虽然挑战性大,但可以实现最符合你需求的通信方式。
- DMA(DMA with a Twist):
你知道吗?DMA(直接内存访问)也可以变得很有趣!想象一下,DMA像一个优雅的舞者,在FPGA和ARM之间优雅地穿梭,传递数据。这种通信方式特别适用于需要高效率数据传输的场景,比如视频处理或高速数据采集。
- Ping-Pong Operation:
这是一种双缓冲区的通信方式。你可以想象FPGA和ARM之间有一个乒乓球,它们轮流击打这个球,就像在玩乒乓球一样。当一方在读取或写入数据时,另一方则准备接收或发送数据。这种方式可以有效地避免数据冲突,提高数据传输的可靠性。
- Interrupt-Driven Communication:
在这种通信方式中,FPGA和ARM之间的通信就像是一个闹钟。当FPGA完成某项任务或检测到某个事件时,它会“敲响”一个中断信号,告诉ARM:“嘿,我完成了!你可以来处理了。”这种方式特别适用于需要实时响应的场景。
- Shared Memory Communication:
想象一下FPGA和ARM之间有一块共同的“土地”(即共享内存)。它们可以在这块“土地”上放置和获取数据,就像是在一个集市上交易一样。这种通信方式简单而高效,特别适用于需要频繁交换数据的场景。
- PCIe/AXI:
这些是高速的串行通信协议,就像是一条“高速公路”,FPGA和ARM可以在上面进行大量的数据传输。常用于连接高速设备,如显卡、网卡等。PCIe(Peripheral Component Interconnect Express)是一种高速串行计算机扩展总线标准,用于连接高速外围设备。如果FPGA和ARM都支持PCIe接口,那么它们之间的数据传输速度将会非常快,就像两个人通过高速列车传递包裹一样!
每种通信方式都有其独特的优点和适用场景。在选择时,需要根据具体的应用需求、性能要求、成本限制等因素进行综合考虑。 不过无论选择哪种方式,都要确保FPGA和ARM能够“愉快”地交流,避免出现“沟通障碍”。实际上,随着威廉希尔官方网站
的不断发展,还会出现更多新的通信方式。选择哪种方式取决于你的具体需求和应用场景。
今天先更新到这里...
接上三篇:
【国产FPGA+OMAPL138开发板体验】1.嵌入式异构威廉希尔官方网站
【国产FPGA+OMAPL138开发板体验】(原创)2.手把手玩转游戏机械臂
【国产FPGA+OMAPL138开发板体验】(原创)3.手把手玩转ARM与FPGA通信
我在本论坛内的试读经验 :
《电子工程师必备——九大系统电路识图宝典》+附录2化整为零和集零为整电路分析方法
《运算放大器参数解析与LTspice应用仿真》+学习心得4第三章专用放大器
《Android Runtime源码解析》+深入体会第六章ART的执行(4)
希望上面的设计能对您有所帮助!
谢谢!
还没吃饭中
2024年2月6日
