我们的设备挂了一个i2c的传感器,psoc6当master,通过以下的示例代码来读写传感器的寄存器
{ cy_stc_scb_i2c_master_xfer_config_t transfer; uint8_t readBuffer [5UL]; uint8_t writeBuffer[2UL] = {0U, 5U}; /* Configure write transaction */ transfer.slaveAddress = 0x08U; transfer.buffer = writeBuffer; transfer.bufferSize = sizeof(writeBuffer); transfer.xferPending = true; /* Do not generate Stop condition at the end of transaction */ /* Initiate write transaction. * The Start condition is generated to begin this transaction. */ (void) Cy_SCB_I2C_MasterWrite(SCB3, transfer, i2cContext); /* Wait for transaction completion */ while (0UL != (CY_SCB_I2C_MASTER_BUSY Cy_SCB_I2C_MasterGetStatus(SCB3, i2cContext))) { } /* Configure read transaction */ transfer.buffer = readBuffer; transfer.bufferSize = sizeof(readBuffer); transfer.xferPending = false; /* Generate Stop condition the end of transaction */ /* Initiate read transaction. * The ReStart condition is generated to begin this transaction because * previous transaction was completed without Stop. */ (void) Cy_SCB_I2C_MasterRead(SCB3, transfer, i2cContext); /* Wait for transaction completion */ while (0UL != (CY_SCB_I2C_MASTER_BUSY Cy_SCB_I2C_MasterGetStatus(SCB3, i2cContext))) { } } 但调试中发现有很大概率在下面的代码中死循环,while (0UL != (CY_SCB_I2C_MASTER_BUSY Cy_SCB_I2C_MasterGetStatus(SCB3, i2cContext))) { } 请问这是啥原因呢?是i2c初始化没做好?还是i2c总线上有冲突?(但总线上我就挂了一个设备)谢谢! |
根据你说的这个现象,会不会跟你连接的GSENSOR有关系,你可以仔细按下他的威廉希尔官方网站
手册,对于初始化是不是需要一个上电的稳定时间之类的。
零知开源——基于STM32F407VET6零知增强板的四路独立计时器
1215 浏览 0 评论
零知开源——STM32F4实现ILI9486显示屏UI界面系列教程(一):电子书阅读器功能
1518 浏览 0 评论
CW32L010 ESC Driver 电机控制套件快速上手指南
1176 浏览 1 评论
1900 浏览 1 评论
1977 浏览 0 评论
13636 浏览 31 评论
GMT+8, 2025-7-8 14:29 , Processed in 0.584380 second(s), Total 39, Slave 33 queries .
