我有一个“疯狂”的时刻 - 我无法在 XC8 中将sprintf(32 位)打印为十六进制。
因此,我将相关代码部分剪切并粘贴到在线 C 编译器中,在那里它工作正常: C: #include 《stdio.h》 char text[9]; // Function to reverse bits of num unsigned char reverseBits(unsigned char num) { //unsigned char NO_OF_BITS = sizeof(num) * 8; unsigned char reverse_num = 0, i, temp; for (i = 0; i 《 8; i++) { temp = (num & (1 《《 i)); if(temp) reverse_num |= (1 《《 ((7) - i)); } return reverse_num; } int main() { unsigned long nec_code = 0x18E708F7; unsigned long fullcode = nec_code; unsigned int address16 = nec_code 》》 16; unsigned int command16 = nec_code & 0xFFFF; unsigned char address = nec_code 》》 24; unsigned char inv_address = nec_code 》》 16; unsigned char command = nec_code 》》 8; unsigned char inv_command = nec_code; // reverse codes to correct values command=reverseBits(command); inv_command=reverseBits(inv_command); address=reverseBits(address); inv_address=reverseBits(inv_address); //address16=reverseBits16(address16); sprintf(text,“%08X”,fullcode); printf(“Full code: 0x%s\n”, text); // print nec_code sprintf(text,“%04X”,nec_code》》 16); printf(“NEC code: 0x%s”, text); // print nec_code sprintf(text,“%04X”,nec_code & 0xFFFF); printf(“%s\n”, text); // print nec_code sprintf(text,“%04X”,address16); printf(“Address16: 0x%s\n”, text); // print address16 sprintf(text,“%04X”,command16); printf(“Command16: 0x%s\n”, text); // print command16 sprintf(text,“%02X”,address); printf(“Address: 0x%s\n”, text); // print address sprintf(text,“%02X”,inv_address); printf(“Inverted: 0x%s\n”, text); // print inv_address sprintf(text,“%02X”,command); printf(“Command: 0x%s\n”, text); // print command sprintf(text,“%02X”,inv_command); printf(“Inverted: 0x%s\n\r”, text); // print inv_command } Result: Full code: 0x18E708F7 NEC code: 0x18E708F7 Address16: 0x18E7 Command16: 0x08F7 Address: 0x18 Inverted: 0xE7 Command: 0x10 Inverted: 0xEF Same result in XC8: Full code: 0x000008F7 NEC code: 0x18E708F7 Address16: 0x18E7 Command16: 0x08F7 Address: 0x18 Inverted: 0xE7 Command: 0x10 Inverted: 0xEF 该代码是我目前对红外遥控器进行实验的一部分,这次是 NEC 遥控器。NEC 遥控器的输出是 32 位,前 8 位是地址,第二个 8 位相同但反转,然后是 8 位命令,然后是反转命令。所有最低有效位都排在第一位,因此是翻转顺序的例程,以给出“正确”的值。 我可以剥离两个 16 位值,并将它们组合起来以显示 32 位值(第二行),但为什么第一行不适用于 XC8(C90 模式下的 v2.36)? |
在XC8中,可以使用`%lx`来将32位的十六进制数打印出来。
```c #include char text[9]; // Function to reverse bits of num unsigned char reverseBits(unsigned char num){ unsigned char reverse_num = 0, i, temp; for (i = 0; i < 8; i++){ temp = (num & (1 << i)); if(temp) reverse_num |= (1 << ((7) - i)); } return reverse_num; } int main(){ unsigned long num = 0x12345678; sprintf(text, "%lx", num); printf("Text: %sn", text); return 0; } ``` 在这个例子中,我们将一个32位的十六进制数打印为字符串。我们使用`%lx`来指定输出格式。`%lx`将32位的十六进制数转换为长度可变的字符串。 |
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-初识设备树之设备树组成和结构
503 浏览 0 评论
【敏矽微ME32G070开发板免费体验】点亮WS2812B灯板
476 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-Linux内核移植之内核启动流程
744 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-TF卡烧录流程之烧写过程
1436 浏览 0 评论
2891 浏览 0 评论
12148 浏览 31 评论
GMT+8, 2025-1-9 20:31 , Processed in 0.509688 second(s), Total 44, Slave 38 queries .
