我想使用 UART RX 信号来触发 ERU 函数。 代码如下所示
这适用于 UART1 P2.0 和 P2.1 const XMC_GPIO_CONFIG_t CYBSP_DEBUG_UART_TX_config = { .mode = (XMC_GPIO_MODE_t)CYBSP_DEBUG_UART_TX_MODE, .output_level = XMC_GPIO_OUTPUT_LEVEL_LOW,};const XMC_GPIO_CONFIG_t CYBSP_DEBUG_UART_RX_config = { .mode = (XMC_GPIO_MODE_t)CYBSP_DEBUG_UART_RX_MODE, .input_hysteresis = XMC_GPIO_INPUT_HYSTERESIS_STANDARD,}; XMC_UART_CH_InitEx(XMC_UART0_CH0, CYBSP_DEBUG_UART_config, true); XMC_UART_CH_SetinputSource(XMC_UART0_CH0, (XMC_UART_CH_INPUT_t)XMC_USIC_CH_INPUT_DX0, 4); XMC_UART_CH_SetSamplePoint(XMC_UART0_CH0, 8U); XMC_USIC_CH_SetInterruptNodePointer(XMC_UART0_CH0, XMC_USIC_CH_INTERRUPT_NODE_POINTER_RECEIVE, 0U); XMC_UART_CH_EnableEvent(XMC_UART0_CH0, XMC_UART_CH_EVENT_STANDARD_RECEIVE); XMC_GPIO_Init(XMC_GPIO_PORT2, 1, CYBSP_DEBUG_UART_TX_config); XMC_GPIO_SetHardwareControl(XMC_GPIO_PORT2, 1, XMC_GPIO_HWCTRL_DISABLED); XMC_GPIO_Init(XMC_GPIO_PORT2, 0, CYBSP_DEBUG_UART_RX_config); XMC_GPIO_SetHardwareControl(XMC_GPIO_PORT2, 0, XMC_GPIO_HWCTRL_DISABLED); NVIC_SetPriority((IRQn_Type)IRQ9_IRQn, 3); NVIC_EnableIRQ((IRQn_Type)IRQ9_IRQn); NVIC_ClearPendingIRQ(IRQ9_IRQn); 请查看数据表,P2.0 是 ERU0.0B0 所以这是我的 ERU 设置。 const XMC_ERU_ETL_CONFIG_t button_event_generator_config = { .input_b = XMC_ERU_ETL_INPUT_B0, .enable_output_trigger = 1, .output_trigger_channel = XMC_ERU_ETL_OUTPUT_TRIGGER_CHANNEL0, .status_flag_mode = XMC_ERU_ETL_STATUS_FLAG_MODE_SWCTRL, .source = XMC_ERU_ETL_SOURCE_B, .edge_detection = XMC_ERU_ETL_EDGE_DETECTION_FALLING,};const XMC_ERU_OGU_CONFIG_t button_event_detection_config = { .enable_pattern_detection = 1, .service_request = XMC_ERU_OGU_SERVICE_REQUEST_ON_TRIGGER_AND_PATTERN_MATCH, .pattern_detection_input = XMC_ERU_OGU_PATTERN_DETECTION_INPUT0,};void ERU_Init(void){XMC_ERU_ETL_Init(ERU0_ETL0, button_event_generator_config);XMC_ERU_OGU_Init(ERU0_OGU0, button_event_detection_config); NVIC_SetPriority(IRQ3_IRQn,NVIC_EncodePriority(NVIC_GetPriorityGrouping(),3, 192)); NVIC_EnableIRQ(IRQ3_IRQn); }void ERU_IRQHandler(void){XMC_ERU_ETL_ClearStatusFlag(ERU0_ETL0);} 从 RX 接收到的数据确实进入了 ERU,但是为什么 UART TX 会针对每个数据触发 ERU 中断一次? 我的设置有什么问题吗? |
UART TX 信号每触发一次 ERU 中断,是因为在每次发送数据时,UART 会产生一个 TX 指示信号,用于表示数据正在发送。
相比之下,UART RX 端口不会像 TX 端口一样产生单独的触发信号。而是当接收到数据时,会通过 RX 端口的中断来触发 ERU 函数。 所以,如果你想使用 UART RX 信号来触发 ERU 函数,你需要在接收到数据时,通过 RX 端口的中断来调用 ERU 函数。在中断处理函数中,你可以检查接收到的数据,并根据需要执行相应的操作。 |
在ZYNQ上跑超炫酷GUI!手把手教你移植LVGL到ZYNQ平台!
190 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之FLEXCAN
821 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之ADC
782 浏览 0 评论
北京君正X系列案例代理商:乐图 PAW GT2支持 PCM 与 DSD 互转
678 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之电阻屏触摸
1210 浏览 0 评论
12453 浏览 31 评论
GMT+8, 2025-3-5 12:39 , Processed in 0.588887 second(s), Total 72, Slave 55 queries .
