#define BIT0 0x01
#define BIT1 0x02 #define BIT2 0x04 #define BIT3 0x08 #define BIT4 0x10 #define BIT5 0x20 #define BIT6 0x40 #define BIT7 0x80 #define BIT8 0x100 #define BIT9 0x200 #define BIT10 0x400 #define BIT11 0x800 #define BIT12 0x1000 #define BIT13 0x2000 #define BIT14 0x4000 #define BIT15 0x8000 #define BIT16 0x10000 #define BIT22 0x400000 #define BIT24 0x1000000 #define BIT25 0x2000000 #define BIT26 0x4000000 #define BIT27 0x8000000 #define BIT30 0x40000000 void Undef_Handler(void) { } void IRQ_Handler(void) { } void SWI_Handler(void) { } void PAbt_Handler(void) { } void DAbt_Handler(void) { } void FIQ_Handler(void) { } unsigned char szTxData[]={0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39}; unsigned char szRxData[]={0x00}; #include int main(void) { unsigned char ucWaitingForXIRQ0; unsigned int I2CMSTATUS ; unsigned char ucRxCount ; unsigned char ucTxCount ; POWKEY1 = 0x1; POWCON0 = 0x78; // 主频 10.24Mhz POWKEY2 = 0xF4; GP1CON = BIT0 + BIT4; // Select UART functionality for P1.0/P1.1 COMCON0 = BIT7; // Enable access to COMDIV registers COMDIV0 = 0x21; // Set baud rate to 9600. COMDIV1 = 0x00; COMCON0 = BIT0 + BIT1 + BIT2; //========================================== GP0CON0 = BIT4 + BIT12; // Select SPI/I2C alternative function for P0.1 P0.3 GP0KEY1 = 0x7; // Write to GP0KEY1 GP0CON1 = BIT1; // Select I2C functionality for P0.1 P0.3 GP0KEY2 = 0x13; // Write to GP0KEY2 I2CMCON = BIT0 ; I2CDIV = 0x3e3e; // Select 80kHz clock rate ucTxCount = 0; I2CFSTA = BIT9; // Flush Master Tx FIFO I2CFSTA = ~BIT9; I2CMTX = 0x00; I2CADR0 = 0xA0; ucWaitingForXIRQ0 = 1; ucRxCount = 0; while (1) { if (ucWaitingForXIRQ0 == 0) // Wait for XIRQ0 to trigger - cleared in XIRQ0 ISR { ucWaitingForXIRQ0 = 1; ucRxCount = 0; I2CMCNT0 = 9; // Read back 6 bytes I2CADR0 = 0xA1;}// + I2C_RD_BIT; // Begin Read sequence from Slave if(ucWaitingForXIRQ0 == 1) { I2CMSTATUS = 0; I2CMSTATUS = I2CMSTA; if ((I2CMSTATUS BIT2) == BIT2) // If I2C Master Tx IRQ { if (ucTxCount < 8) // Have max 6 bytes been sent? {I2CMTX = szTxData[ucTxCount++]; // Load Tx buffer } ucWaitingForXIRQ0 =0;} if ((I2CMSTATUS BIT3) == BIT3) // If I2C Master Rx IRQ {if (ucRxCount < 8) // Have max 6 bytes been received? {szRxData[ucRxCount] = I2CMRX; // Read Rx buffer while(!((COMSTA0 BIT6)==BIT6)){}; COMTX=szRxData[ucRxCount]; ucRxCount++;} ucWaitingForXIRQ0 =1; } } } } |
在ADuC7060的网页上有参考代码可以下载,里面有一个例程是关于I2C_EPROM的。
根据您提供的代码片段,无法确定为什么aduc7060 IIC接口无法读取at24c04。首先,代码片段中的定义只是一些位掩码,与IIC接口相关的代码并未给出。请提供完整的代码以便进一步分析和帮助解决问题。
同时,如果您遇到问题,可以尝试以下步骤进行排查: 1. 确保IIC接口的硬件连接正确,包括SDA、SCL、上拉电阻等。 2. 检查IIC接口的初始化是否正确,包括设置IIC的时钟频率、模式等参数。 3. 确保正确的IIC通信地址已被设置,确保配置正确,与at24c04的通信地址匹配。 4. 检查是否有其他硬件或软件冲突造成读取失败。 5. 使用适当的调试工具(如串口打印)输出调试信息,检查是否有错误提示或异常情况发生。 如果以上方法都无法解决问题,请提供更多相关的代码和错误信息,以便更准确地分析和解决问题。 |
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-移植前准备之git管理内核源码
1792 浏览 0 评论
【瑞萨RA2L1入门学习】+ MacOS安装e2studio
733 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-本地仓库管理之分支间的操作
784 浏览 0 评论
【RA-Eco-RA4E2-64PIN-V1.0开发板试用】3D 图形显示
656 浏览 0 评论
754 浏览 1 评论
12249 浏览 31 评论
GMT+8, 2025-2-2 18:57 , Processed in 0.722896 second(s), Total 74, Slave 57 queries .
